Home » Eclipse Projects » Buckminster dev » [buckminster-dev] Buckminster Aggregator - mvn2 repo to p2 repo help
[buckminster-dev] Buckminster Aggregator - mvn2 repo to p2 repo help [message #507040] Mon, 11 January 2010 18:29 Go to next message
Chris Aniszczyk is currently offline Chris AniszczykFriend
--001485f5af8c419db1047ce7b915
Content-Type: text/plain; charset=UTF-8
I'm trying to convert an existing maven2 repo to a p2 repo using the
aggregator (which is a cool little tool btw)
This is my current model:
<aggregator:Aggregator xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:aggregator="http://www.eclipse.org/buckminster/2009/aggregator">
<configurations/>
<configurations operatingSystem="macosx" windowSystem="cocoa"/>
<contributions description="JGit Latest" label="JGit">
<repositories location="
https://build.eclipse.org/hudson/job/jgit/lastSuccessfulBuil d/artifact/.repository/"
nature="maven2"/>
</contributions>
</aggregator:Aggregator>
For some reason, I can't contact the site... even if I try a local URL too
(i.e., /Users/chrisaniszczyk/.m2/repository/org/eclipse/jgit)
Any thoughts? Is this an intended usage pattern?
Chris Aniszczyk
http://aniszczyk.org
Content-Type: text/html; charset=UTF-8
Content-Transfer-Encoding: quoted-printable
I&#39;m trying to convert an existing maven2 repo to a p2 repo using the ag=
gregator (which is a cool little tool btw)<br><br>This is my current model:=
<br><br>&lt;?xml version=3D&quot;1.0&quot; encoding=3D&quot;UTF-8&quot;?&gt=
;<br>
&lt;aggregator:Aggregator xmi:version=3D&quot;2.0&quot; xmlns:xmi=3D&quot;<=
a href=3D"http://www.omg.org/XMI">http://www.omg.org/XMI</a>&quot; xmlns:ag=
gregator=3D&quot;<a href=3D"http://www.eclipse.org/buckminster/2009/aggrega=
tor">http://www.eclipse.org/buckminster/2009/aggregator</a>&quot;&gt;<br>
=C2=A0 &lt;configurations/&gt;<br>=C2=A0 &lt;configurations operatingSystem=
=3D&quot;macosx&quot; windowSystem=3D&quot;cocoa&quot;/&gt;<br>=C2=A0 &lt;c=
ontributions description=3D&quot;JGit Latest&quot; label=3D&quot;JGit&quot;=
&gt;<br>=C2=A0=C2=A0=C2=A0 &lt;repositories location=3D&quot;<a href=3D"htt=
ps://build.eclipse.org/hudson/job/jgit/lastSuccessfulBuild/a rtifact/.reposi=
tory/"> https://build.eclipse.org/hudson/job/jgit/lastSuccessfulBuil d/artifa=
ct/.repository/</a>&quot; nature=3D&quot;maven2&quot;/&gt;<br>
=C2=A0 &lt;/contributions&gt;<br>&lt;/aggregator:Aggregator&gt; <br><br>For =
some reason, I can&#39;t contact the site... even if I try a local URL too =
(i.e., /Users/chrisaniszczyk/.m2/repository/org/eclipse/jgit)<br><br >Any th=
oughts? Is this an intended usage pattern?<br clear=3D"all">
<br>-- <br>Cheers,<br><br>Chris Aniszczyk<br><a href=3D"http://aniszczyk.or=
g">http://aniszczyk.org</a><br>
--001485f5af8c419db1047ce7b915--
Re: [buckminster-dev] Buckminster Aggregator - mvn2 repo to p2 repo help [message #507080 is a reply to message #507040] Mon, 11 January 2010 19:22 Go to previous messageGo to next message
Filip Hrbek is currently offline Filip HrbekFriend
Yes, this pattern is correct.
The repository cannot be loaded because of several reasons:
1) The hudson web page format
If the maven2 repository is not indexed by nexus (for which we have an optional non-eclipse extension), then we must parse whatever is delivered upon a http/https request. We were prepared for simple directory listings (such as the default Apache Web Server directory listing). However, the hudson format is more complicated. I can adopt the reader so that it would parse this format properly (although I'm not sure how to distinguish between a link to a file and to a folder right now, in the "standard" listing folders end with a slash which is not the hudson's case).
2) The maven-metadata.xml file is not found
We look for maven-metadata.xml files. These files are not available in your repository, but maven-metadata-local.xml files are. I can add a rule to recognize this file as well.
3) MD5 and SHA1 checksums are missing
We require checksums to be present and correct, otherwise the components are refused. Should we ignore the checksums? Should we add properties to choose if (and which) checksums are required/checked? What do you think?
Once we fix these three issues, you will see your components in the repository view. Then we can talk about the displayed content.
Cheers
Filip
Chris Aniszczyk napsal(a):
> <configurations/>
> <repositories
> location=" https://build.eclipse.org/hudson/job/jgit/lastSuccessfulBuil d/artifact/.repository/"
> nature="maven2"/>
> </contributions>
> too (i.e., /Users/chrisaniszczyk/.m2/repository/org/eclipse/jgit)
> Cheers,
> Chris Aniszczyk
Re: [buckminster-dev] Buckminster Aggregator - mvn2 repo to p2 repo help [message #507423 is a reply to message #507080] Wed, 13 January 2010 13:11 Go to previous messageGo to next message
Hi Chris,
the three issues are fixed:
1) Hudson web page format:
- only links containing sigle path segments are considered (to avoid skipping folder layers)
- if a link does not end with a slash (which normally denotes a folder), it is tested whether a http redirect is required to a folder with a slash at the end - if so, then it is a folder
2) Maven metadata file:
The maven-metadata-local.xml is recognized in addition to maven-metadata.xml
3) Missing or bad checksums are considered as warnings instead of errors
Now I am able to load your repository.
The fixes are available on our update sites (both for 3.5 and 3.6).
Please, try it out and tell me what you would like to change/add/improve.
Filip
Filip Hrbek napsal(a):
> hudson's case).
> Cheers
> Filip
>> <?xml version="1.0" encoding="UTF-8"?>
>> <configurations/>
>> <repositories
>> nature="maven2"/>
>> </contributions>
>> Cheers,
>> Chris Aniszczyk
Re: [buckminster-dev] Buckminster Aggregator - mvn2 repo to p2 repo help [message #508013 is a reply to message #507423] Fri, 15 January 2010 14:24 Go to previous message
Hi Chris,
did you have time to think about it?
Filip
> Hi Chris,
> maven-metadata.xml
> Filip
>> What do you think?
>> Cheers
>> Filip
>>> <configurations/>
>>> <repositories
>>> nature="maven2"/>
>>> </contributions>
>>> URL too (i.e., /Users/chrisaniszczyk/.m2/repository/org/eclipse/jgit)
>>> Cheers,
>>> Chris Aniszczyk
Previous Topic:iX CeBIT Forum 2010 Talk
Next Topic:[buckminster-dev] junit tests in headless buckminster
Current Time: Sun Nov 29 16:33:18 GMT 2020
Powered by FUDForum. Page generated in 0.01957 seconds
