Product export problem [message #506825] |
Sun, 10 January 2010 20:52 |
I can't export a RCP product I took back.
Here is the log I get at each time I try to export :
Quote: | D:\dev\workspace-3.5-RCP-xxxxx\.metadata\.plugins\org.eclips e.pde.core\temp\org.eclipse.pde.container.feature\package.or g.eclipse.pde.container.feature.win32.win32.x86.xml:90: The following error occurred while executing this line:
D:\dev\workspace-3.5-RCP-xxxxx\.metadata\.plugins\org.eclips e.pde.core\temp\org.eclipse.pde.container.feature\package.or g.eclipse.pde.container.feature.win32.win32.x86.xml:1024: The following error occurred while executing this line:
D:\Program Files\eclipse-3.5-rcp-xxxxx\configuration\org.eclipse.osgi\b undles\314\1\bundlefile\scripts\genericTargets.xml:268: A Problem occured while running the director.
at org.apache.tools.ant.ProjectHelper.addLocationToBuildExcepti on(ProjectHelper.java:508)
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:418)
at org.apache.tools.ant.taskdefs.CallTarget.execute(CallTarget. java:105)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
at sun.reflect.GeneratedMethodAccessor106.invoke(Unknown Source)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:357)
at org.apache.tools.ant.Target.performTasks(Target.java:385)
at org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1337)
at org.apache.tools.ant.Project.executeTarget(Project.java:1306 )
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:41)
at org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
................... etc
at org.eclipse.pde.internal.core.exports.ProductExportOperation .run(ProductExportOperation.java:105)
Caused by: D:\dev\workspace-3.5-RCP-xxxxx\.metadata\.plugins\org.eclips e.pde.core\temp\org.eclipse.pde.container.feature\package.or g.eclipse.pde.container.feature.win32.win32.x86.xml:1024: The following error occurred while executing this line:
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:416)
... 25 more
Caused by: D:\Program Files\eclipse-3.5-rcp-xxxxx\configuration\org.eclipse.osgi\b undles\314\1\bundlefile\scripts\genericTargets.xml:268: A Problem occured while running the director.
at org.apache.tools.ant.taskdefs.Exit.execute(Exit.java:142)
... 38 more
--- Nested Exception ---
at org.eclipse.ant.core.AntRunner.run(AntRunner.java:378)
at org.eclipse.pde.internal.core.exports.FeatureExportOperation .runScript(FeatureExportOperation.java:422)
at org.eclipse.pde.internal.core.exports.FeatureExportOperation .doExport(FeatureExportOperation.java:286)
at org.apache.tools.ant.Project.executeTargets(Project.java:118 9)
... 38 more
I've tried a hundred of times to export that product without any success. I can launch the product into Eclipse anyway.
I don't know how to get more information about the problem.
How can I make to detect the source of the problem ?
Thanks in advance for your help.
Laurent
Re: Product export problem [message #507327 is a reply to message #506825] |
Tue, 12 January 2010 22:58 |
I solved my pb...
If I uncheck the "Generate metadata repository" it's ok.
Well, I had already tried to uncheck that option before but the export hadn't worked anyway, certainly because of something else.
Ok, that option must not be checked, but why ?...
FUDForum. Page generated in 0.03505 seconds
