How to show a custom cursor while hovering over a menu bar? [message #506760] |
Sat, 09 January 2010 11:28 |
Originally posted by: janila.web.de
I want to implement custom cursors for my application.
Shell.setCursor(Cursor) works fine, however while hovering over a menu
bar the cursor changes back to the default picture. Can one change this
behavior?
Also, I would like to use the right side of the menu bar which is quite
empty and draw some over it. Is this possible? Havent found something
for it.
Many regards from someone still learning SWT
Jan
Re: How to show a custom cursor while hovering over a menu bar? [message #507498 is a reply to message #506760] |
Wed, 13 January 2010 16:42 |
Grant Gayed Messages: 2150 Registered: July 2009 |
Hi Jan,
I don't think that having a different cursor show in the menu bar is
currently possible. I'm not sure if it's a platform limitation or
convention, but it is consistent in that it does not work on any of the
platforms. I don't see anything in swt's win32 implementation that
explicitly makes it not show for menu bars, so I suspect that it's native
behaviour, in which case it's "right".
Since MenuBar is a Widget but not a Control, you cannot draw on it directly.
If you really want to put something on the bar then you could create a Shell
with NO_TRIM, position it over a part of the menu bar, and draw on it. For
transparent Shell examples see
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet180.java?view=co
and
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/org. eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet219 .java .
HTH,
Grant
"Jan Keller" <janila@web.de> wrote in message
news:hiaade$b9a$1@build.eclipse.org...
> behavior?
> for it.
> Jan
Re: How to show a custom cursor while hovering over a menu bar? [message #508188 is a reply to message #507498] |
Sun, 17 January 2010 11:33 |
Hi Grant,
Thank you for the answer! I will probably exchange the menu bar by a
tool bar. Its a control, so I can draw on it and the mouse cursor is
displayed as wished, only I will have to provide some custom background
images and on the mac platform the location of the menu won't be the
same, but thats probably okay.
Jan
Am 13.01.2010 17:42, schrieb Grant Gayed:
> Hi Jan,
> and
> HTH,
> Grant
FUDForum. Page generated in 0.02489 seconds
