Home » Eclipse Projects » Simultaneous release » Eclipse Galileo on Kubuntu 9.10(Doesn't work)
Eclipse Galileo on Kubuntu 9.10 [message #506522] Thu, 07 January 2010 10:47 Go to next message
Hi everybody,
I'm Trying to run eclipse ganymede on Kubuntu 9.10. I've downloaded it already and uncompressed on my home folder. when I execute eclipse the eclipse splash appear, but, eclipse doesnt start, instead, a non-text windows appear. I can't close that window even if I click on the x windo button. To close that I had to use ctrl+c on the console.
On the console appears the following when I execute the command "./eclipse"
(eclipse:5093): GLib-WARNING **: g_set_prgname() called multiple times
What can be happening?
by the way, compiz effects are active.
Thnx!
JCrx,
Re: Eclipse Galileo on Kubuntu 9.10 [message #508151 is a reply to message #506522] Sat, 16 January 2010 11:58 Go to previous messageGo to next message
I have the similar problem with the similar warning message since I've upgraded my kubuntu to 9.10. In general, Galileo still works (it was perfect with kubuntu 9.04) but I can't do some essential operations anymore like creating new projects, refactoring some variable names, exporting preferences and many others. For example, if I want to create a new bzr project and I select let's say "Branch as a new project" and then push the "next" button it doesn't respond at all. Is there any solution for this problem? Thanks.
Cheers, Gia
Re: Eclipse Galileo on Kubuntu 9.10 [message #508428 is a reply to message #508151] Mon, 18 January 2010 13:19 Go to previous messageGo to next message
See http://ubuntuforums.org/showthread.php?t=1362942
It's due to the unstable version (2.22.3-0ubuntu1) of libglib2.0-0.
Downgrade it.
Re: Eclipse Galileo on Kubuntu 9.10 [message #510534 is a reply to message #508151] Wed, 27 January 2010 13:38 Go to previous message
gia wrote on Sat, 16 January 2010 11:58
Cheers, Gia
See http://www.eclipse.org/forums/index.php?t=msg&th=161210& amp;start=0&
Previous Topic:Removing EMF Index from Helios
Next Topic:Eclipse Galileo on Kubuntu 9.10
Current Time: Fri Mar 21 01:02:57 EDT 2025
Powered by FUDForum. Page generated in 0.02742 seconds
