Home » Modeling » EMF » FeatureMap definition
FeatureMap definition [message #506375] |
Thu, 07 January 2010 05:46 |
Timothy Marc Messages: 547 Registered: July 2009 |
Hi all,
i currently investigate the differences between EMF FeatureMaps and UML
Subsets, so i have several question concerning FeatureMap definitions.
It would be nice, if someone may state some short answers to them:
1. Is it possible to let a feature participate in more than one feature
maps, like it is possible with subsets? In form of {subsets a, subsets
b, ...}?
2. Consider a generalization between class A and B, where A::c is a
feature, that participates in a feature map. Is it somehow possible to
define B::c', where c' will subset c and therefore traversly taking part
in the feature map of class A? I've contemplate about this more
intensively, and i think this won't be possible, since subsetting of one
feature is not possible with feature maps, where maps only intended to
act as a combining mechanism. Subsetting of single feature is not
covered, is it? So, this might be the main difference between feature
maps and subsets from my current point of knowledge. Real subsetting of
single features is not possible...
3. What about generalization behavior of a feature map. Is it possible
to let a feature of B be participate in the feature map of A? I'm pretty
sure, that this is possible.
Thanks a lot in advance, since it is sometime really confusing to me,
what feature maps are really intended for, respectively, in how the
differ from unions and subsets of MOF2.0.
Timothy
Re: FeatureMap definition [message #506401 is a reply to message #506375] |
Thu, 07 January 2010 11:48 |
Ed Merks Messages: 33137 Registered: July 2009 |
--------------030700030205020706080903
Timothy,
Comments below.
Timothy Marc wrote:
> Hi all,
> UML Subsets, so i have several question concerning FeatureMap
> definitions. It would be nice, if someone may state some short answers
> to them:
> feature maps, like it is possible with subsets? In form of {subsets a,
> subsets b, ...}?
Yes. If you look at the list method for create a "view" for some
feature you'll see for the case of a feature that itself is a feature
map, another feature map is created.
public <T> EList<T> list(EStructuralFeature feature)
return
FeatureMapUtil.isFeatureMap(feature) ?
(EList<T>)new FeatureMapUtil.FeatureFeatureMap(feature, this):
new FeatureMapUtil.FeatureEList<T>(feature, this);
> part in the feature map of class A? I've contemplate about this more
> one feature is not possible with feature maps, where maps only
> intended to act as a combining mechanism. Subsetting of single feature
> is not covered, is it? So, this might be the main difference between
> feature maps and subsets from my current point of knowledge. Real
> subsetting of single features is not possible...
Yes, I can't think of a way of mapping this to something that's possible
in XML schema. Certainly if A were a mixed content type there'd be an
overall feature map to which all element-based features would delegate
and both c and c' would participate in that, so I suppose that comes close.
> pretty sure, that this is possible.
In the end, it's what the BasicFeatureMap.**getValidator(EClass
containingClass, EStructuralFeature eStructuralFeature) allows that
determines the valid content.
They're intended primarily (one might say solely) to support XML Schema
features such as mixed content, substitution groups, and complex
particle structures that allow interleaving of different elements.
> Timothy
<html>
<head>
http-equiv="Content-Type">
</head>
Timothy,<br>
<br>
Comments below.<br>
<br>
<br>
Timothy Marc wrote:
<blockquote cite="mid:hi4djn$icf$1@build.eclipse.org" type="cite">Hi
all,
<br>
<br>
<br>
<br>
b, ...}?
<br>
</blockquote>
Yes.
Ed Merks
Re: FeatureMap definition [message #506403 is a reply to message #506401] |
Thu, 07 January 2010 12:33 |
Dear Ed, thanks for responding quickly... let me rerequest some parts of
your answers inline and let me ask another interesting question.
The feature map defines a container for features, that origin from a
particular reference (e.g. @orders, Supplier__Order from the book). In
that case, it should be still possible to add a subtype of Order (e.g.
SubOrder) directly into the feature map (by using the Supplier__Order
feature id). So in that case, the content of a feature map may contain
elements derived by the particpating features as well as elements,
depending on the feature (the type of the attribute itself).
(additional comments inline, as mentioned)
Ed Merks schrieb:
> Timothy,
> Comments below.
> Timothy Marc wrote:
>> Hi all,
>> to them:
>> subsets b, ...}?
> return
Hmm... not directly, since all the elemnts of c' should also be
contained in c and the overall feature map. Correct me, if i'm wrong,
but the situation you described leads to a situation, where elements can
only occur in c and c', but not in c' as well as c.
However, they are quite close to these MOF union/subset capabilities and
to some degree they help to create a more convenient API, from
implementors point of view. In the end, i still think, that the list
framework of UML2 project, which implements these capabilites directly,
is easier to understand for someone, who wants to dig into the code.
>> Timothy
Re: FeatureMap definition [message #506453 is a reply to message #506403] |
Thu, 07 January 2010 15:07 |
Timothy,
Comments below.
> of your answers inline and let me ask another interesting question.
> Ed Merks schrieb:
>> Timothy,
>> Comments below.
>> Timothy Marc wrote:
>>> Hi all,
>>> answers to them:
>>> a, subsets b, ...}?
>> return
>>> to define B::c', where c' will subset c and therefore traversly
>>> taking part in the feature map of class A? I've contemplate about
>>> this more intensively, and i think this won't be possible, since
>>> subsetting of one feature is not possible with feature maps, where
>>> maps only intended to act as a combining mechanism. Subsetting of
>>> single feature is not covered, is it? So, this might be the main
>>> difference between feature maps and subsets from my current point of
>>> knowledge. Real subsetting of single features is not possible...
>> possible in XML schema. Certainly if A were a mixed content type
>> there'd be an overall feature map to which all element-based features
>> would delegate and both c and c' would participate in that, so I
> can only occur in c and c', but not in c' as well as c.
We're talking at a pretty abstract level here. As I said it comes close,
but yes, I don't think it's a form of subsetting.
>>> possible to let a feature of B be participate in the feature map of
>>> A? I'm pretty sure, that this is possible.
>>> me, what feature maps are really intended for, respectively, in how
>>> the differ from unions and subsets of MOF2.0.
>> Schema features such as mixed content, substitution groups, and
>> complex particle structures that allow interleaving of different
>> elements.
> and to some degree they help to create a more convenient API, from
> directly, is easier to understand for someone, who wants to dig into
> the code.
It was certainly designed to be an exact match for those concepts.
>>> Timothy
Ed Merks
Current Time: Fri Apr 19 22:07:40 GMT 2024
Powered by FUDForum. Page generated in 0.02877 seconds
