Home » Language IDEs » PHP Development Tools (PDT) » debugger doesn't show values inside a function
icon5.gif  debugger doesn't show values inside a function [message #506338] Thu, 07 January 2010 01:53 Go to next message
Ethereal1m Mising name is currently offline Ethereal1m Mising nameFriend
Member
Dear all,
I'm new in Eclipse environment and I'm learning using Eclipse PDT with Xdebug. I have a problem that puzzles me. Looks very simple but I cannot figure it out.
Suppose I have this code:
function sum($a,$b) {
	$c=1;
	return $a+$b+$c;
$result=sum(1,2);
And I want the debugger to show $a, $b, and $c. When I step into sum function, instead of showing the variable values, "variables view" says that $a, $b, and $c are uninitialized.
Why is that doing that? How can I make it display the values?
Joe
Re: debugger doesn't show values inside a function [message #506376 is a reply to message #506338] Thu, 07 January 2010 10:42 Go to previous messageGo to next message
Originally posted by: dkel50.hotremovemail.com
Are you using php 5.3 ? There appears to be a bug on the version of
xdebug for php 5.3 that causes this. The xdebug author is aware of this
but I don't know when the next official build of xdebug is going to be made.
you could check www.xdebug.org for more info about xdebug
Dave Kelsey
On 07/01/10 01:54, soebagio@gmail.com wrote:
> Dear all,
> figure it out.
> $c=1;
> return $a+$b+$c;
> $result=sum(1,2);
> Regards,
> Joe
Re: debugger doesn't show values inside a function [message #506465 is a reply to message #506376] Thu, 07 January 2010 16:00 Go to previous messageGo to next message
Member
yes i use 5.3...
do you think i should use a different version of xdebug?
Re: debugger doesn't show values inside a function [message #506500 is a reply to message #506465] Thu, 07 January 2010 18:08 Go to previous messageGo to next message
You need to locate a version of xdebug for php 5.3 that has the fix in
it. I don't know if there is one available yet, other people have been
compiling it themselves from svn on linux.
Dave Kelsey
On 07/01/10 16:00, Ethereal1m wrote:
> yes i use 5.3...
Re: debugger doesn't show values inside a function [message #506501 is a reply to message #506465] Thu, 07 January 2010 18:09 Go to previous messageGo to next message
Or alternatively drop down to php 5.2 and xdebug 2.0.5 this combination
doesn't have this problem.
Dave Kelsey
> yes i use 5.3...
icon5.gif  Re: debugger doesn't show values inside a function [message #506568 is a reply to message #506338] Fri, 08 January 2010 03:14 Go to previous message
Member
Great, thanks Razz
Previous Topic:java.net.SocketException: Network is unreachable AND Unable to connect to repository
Next Topic:PDT error
Current Time: Tue Mar 28 13:32:45 GMT 2023
Powered by FUDForum. Page generated in 0.02327 seconds
