Home » Language IDEs » PHP Development Tools (PDT) » java.net.SocketException: Network is unreachable AND Unable to connect to repository
icon13.gif  java.net.SocketException: Network is unreachable AND Unable to connect to repository [message #506180] Wed, 06 January 2010 13:23 Go to next message
Edo  is currently offline Edo Friend
(Sorry if this post is discussed in other topics, i can't find a solution)
hi, i have several problems from my debian ustable system to run eclipse pdt. The problem persist after a total format of the disk.
I use eclipse pdt galielo or eclipse pdt helios (M4), same problems.
I use java jdk 1.6.0_17
I use debian ustable
If i create a new connection eclipse respond: "Unable to connect to host.domain.it" (this domain is verified from shell ssh)
If i click "Install new software" i have the error:
Unable to connect to repository http://download.eclipse.org/releases/galileo/site.xml
In preferences:
General->Network connection is setting to Native
If i set "Direct," the problem persists
If i restart eclipse, this option is already setting to "Native"
I can't install software, develop from ssh, accessing my svn....
Any suggestion?
Re: java.net.SocketException: Network is unreachable AND Unable to connect to repository [message #506283 is a reply to message #506180] Wed, 06 January 2010 18:51 Go to previous messageGo to next message
Paulo Vital is currently offline Paulo VitalFriend
I have the same problem. Not only for 'Install Software', but when accessing CVS repositories too.
Running on Debian, with Java 1.6.0_17 (IBM) and Eclipse SDK Galileo (all 64bits installations).
Regards, Paulo Vital
Re: java.net.SocketException: Network is unreachable AND Unable to connect to repository [message #506330 is a reply to message #506180] Thu, 07 January 2010 02:31 Go to previous messageGo to next message
No real name is currently offline No real nameFriend
debian unstable, eclipse 3.5.1, jvm1.6: faced the same issue
seems that this IPv6 config related
possible solution:
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=560142
hope this helps.
Re: java.net.SocketException: Network is unreachable AND Unable to connect to repository [message #506381 is a reply to message #506330] Thu, 07 January 2010 11:11 Go to previous messageGo to next message
It's a Debian bug, not Eclipse. I found a another workaround in [1] that works for me.
[1] http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=560056
Re: java.net.SocketException: Network is unreachable AND Unable to connect to repository [message #506423 is a reply to message #506381] Thu, 07 January 2010 14:04 Go to previous message
Tnx for replies and workaround....
ALLELUJA, it's work!
I report the solution:
su (root pass)
vim /etc/sysctl.d/bindv6only.conf (and set net.ipv6.bindv6only = 0 )
invoke-rc.d procps restart
It's all.
Thank You Again!
[Updated on: Thu, 07 January 2010 17:59]
Report message to a moderator
Previous Topic:info about pdt 2.2?
Next Topic:debugger doesn't show values inside a function
Current Time: Mon Jun 14 16:19:34 GMT 2021
Powered by FUDForum. Page generated in 0.01850 seconds
