Home » Language IDEs » Objectteams » compilation problems with a generic callin binding
compilation problems with a generic callin binding [message #506149] Wed, 06 January 2010 11:10 Go to next message
Eugene Hutorny is currently offline Eugene HutornyFriend
Method designator binds to a method returning T whereas return type T is specified (OTJLD 4.1(c))
			<T extends Specializable> T castAs(Class<T> type) <- replace T castAs(Class<T> type);
			callin <T extends Specializable> T castAs(Class<T> type) {
				return Education.this.castAs(type);
Two other variations with the generic also fail to compile.
Complete sources to reproduce the problem can be found on this link
Other compilation errors:
The return type of implicitly inherited method Education.Specialist.castAs() is not compatible to the return type of explicitly inherited method Education.Specialist.castAs() (1.3.1(k)).
sources
Internal compiler error: java.lang.NullPointerException at org.objectteams.otdt.core.internal.compiler.mappings.CallinI mplementor.createWrapperMethod(CallinImplementor.java:274)
sources
[Updated on: Wed, 06 January 2010 07:28]
Report message to a moderator
Re: compilation problems with a generic callin binding [message #506222 is a reply to message #506149] Wed, 06 January 2010 15:22 Go to previous message
Stephan Herrmann is currently offline Stephan HerrmannFriend
> castAs(Class<T> type); callin <T extends Specializable> T castAs(Class<T>
> type) { return Education.this.castAs(type);
> http://hutorny.in.ua/wp-content/uploads/2010/01/exer4.zip
Thanks for the example. These are in fact variations of an
existing ticket:
https://trac.objectteams.org/ot/ticket/292
In fact, also the "base-call impossible" problem you reported
earlier seems to have the same root cause.
I've scheduled the ticket for the next milestone.
best,
Stephan
Re: compilation problems with a generic callin binding [message #567090 is a reply to message #506149] Wed, 06 January 2010 15:22 Go to previous message
existing ticket:
best,
Stephan
Previous Topic:ArrayIndexOutOfBoundsException with multithreaded use of a callin
Next Topic:Suggestion on callin bindings
Current Time: Wed Feb 26 11:42:21 GMT 2020
Powered by FUDForum. Page generated in 0.01796 seconds
