Re: update 1.3M4 and UITests Error [message #505851 is a reply to message #505816] |
Tue, 05 January 2010 11:10  |
Ivan Furnadjiev Messages: 2396 Registered: July 2009 Location: Sofia, Bulgaria |
Hi Maziar,
I can reproduce the javascript error with the Workbench demo and
-Dorg.eclipse.rwt.enableUITests set to true. Please file a bugzilla to
keep track on this issue.
Best,
Ivan
On 1/5/2010 6:16 AM, Maziar Khodaei wrote:
> Hi
> I updated yesterday my framework up to the version 1.3M4 from dec 18.
> I got than following error:
> "Could not evaluate javascript response:
> TypeError: widget is undefined
> var req= org .eclipse.swt. request ............."
> I found out, that when I set the Ui test attributte
> "Dorg.eclipse.rwt.enableUITests=true" then the error is fire, when the
> attribute is false, it work perfect.
> I test it with RAP 1.3M3, thart works without errors, as well UI Test
> is true or false. Only by 1.3M4 come to this error.
> do you have any idee?
> Thanks a lot.
> Maziar
FUDForum. Page generated in 0.10092 seconds
