Home » Eclipse Projects » Remote Application Platform (RAP) » NPE on session shutdown
NPE on session shutdown [message #505705] Mon, 04 January 2010 15:21 Go to next message
Thomas Kratz is currently offline Thomas KratzFriend
HI I see the follwoing exception several times in my log, then my server goes up in smoke.
2010-01-04 10:43:52,498 ERROR  /webshop: Could not execute org.eclipse.ui.internal.Workbench$ShutdownHandler.beforeDestroy(SessionStoreEvent).
        at org.eclipse.rap.ui.internal.preferences.SessionScope.getNode(SessionScope.java:67)
        at org.eclipse.ui.preferences.ScopedPreferenceStoreCore.getStorePreferences(ScopedPreferenceStoreCore.java:225)
        at org.eclipse.ui.preferences.ScopedPreferenceStoreCore.getPreferenceNodes(ScopedPreferenceStoreCore.java:267)
        at org.eclipse.ui.preferences.ScopedPreferenceStoreCore.internalGet(ScopedPreferenceStoreCore.java:458)
        at org.eclipse.ui.preferences.ScopedPreferenceStoreCore.getBoolean(ScopedPreferenceStoreCore.java:370)
        at org.eclipse.ui.preferences.ScopedPreferenceStore.getBoolean(ScopedPreferenceStore.java:446)
        at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:814)
        at org.eclipse.ui.internal.Workbench.access$12(Workbench.java:788)
        at org.eclipse.ui.internal.Workbench$21.run(Workbench.java:1054)
        at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:66)
        at org.eclipse.ui.internal.Workbench.close(Workbench.java:1052)
        at org.eclipse.ui.internal.Workbench.close(Workbench.java:1014)
        at org.eclipse.ui.internal.Workbench$ShutdownHandler.beforeDestroy(Workbench.java:133)
        at org.eclipse.rwt.internal.service.SessionStoreImpl.doValueUnbound(SessionStoreImpl.java:174)
        at org.eclipse.rwt.internal.service.SessionStoreImpl.access$0(SessionStoreImpl.java:165)
        at org.eclipse.rwt.internal.service.SessionStoreImpl$1.run(SessionStoreImpl.java:50)
        at org.eclipse.rwt.internal.lifecycle.UIThread.processShutdown(UIThread.java:122)
        at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:127)
        at java.lang.Thread.run(Thread.java:619)
        at org.eclipse.rwt.internal.lifecycle.UIThread.run(UIThread.java:68)
I don't have any preferences in my app, can anyone give me a hint on this ?
Re: NPE on session shutdown [message #505878 is a reply to message #505705] Tue, 05 January 2010 12:57 Go to previous messageGo to next message
I found that it must be something with the embedded jetty I use. If I run jetty with the tanuki wrapper everything seems to be fine. Strange thing, but it works now.
Re: NPE on session shutdown [message #507692 is a reply to message #505878] Thu, 14 January 2010 12:07 Go to previous messageGo to next message
Benjamin Muskalla is currently offline Benjamin MuskallaFriend
Hi Thomas,
do you have any further informations how to reproduce this problem? It
would be great to know if we can do anything about this.
Benny
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Re: NPE on session shutdown [message #507698 is a reply to message #507692] Thu, 14 January 2010 12:26 Go to previous message
Hi Benny,
sadly I have no idea what the heck the problem is. I found that when I run my app (that has jetty embedded and starts it programmatically) with the tanuki wrapper the problem disappears. So no idea how to reproduce it honestly. I saw another entry fromanother user that seems to be the same problem with an embedded jetty, but I don't know the reasons.
Sorry for the bad ideas Sad
Thomas
Re: NPE on session shutdown [message #507753 is a reply to message #507698] Thu, 14 January 2010 09:54 Go to previous message
Hi Thomas,
no problem. Just in case you can reproduce use, feel free to open a bug
report.
Thanks!
Benny
Thomas Kratz wrote:
> Hi Benny,
> Sorry for the bad ideas :(
> Thomas
Previous Topic:Rounded border wouldn't show up on certain widgets
Next Topic:Documentation for RAP on external server ?
Current Time: Tue Apr 16 11:10:14 GMT 2024
Powered by FUDForum. Page generated in 3.43727 seconds
