Home » Modeling » EMF » cross resouce containment and validation
cross resouce containment and validation [message #505489] |
Thu, 31 December 2009 10:42  |
Simon Bernard Messages: 339 Registered: July 2009 |
I have 2 problems with emf validation because I use cross resource
containment.
1) When you have cross containment resource, you can have objects
which contain objets which are proxy, but the validation don't verify
that the object which will validate is a proxy or not.. so a lot of
errors are raised but not really relevant. (ex : a feature with an empty
value)
2) Unresolve proxy are not detected because the method
"validate_EveryProxyResolves" of EObjectValidor verify only proxy on
reference but not in containement.
I propose two solution :
1) add a test to verify that the objet is not a proxy before to validate
it in the validator generated by EMF.
* Calls <code>validateXXX</code> for the corresponding classifier of the
* model. <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
protected boolean validate(int classifierID, Object value,
DiagnosticChain diagnostics, Map<Object, Object> context)
if (value instanceof EObject && ((EObject) value).eIsProxy())
return true;
switch (classifierID)
case MyPackage.MY_OBJECT:
return validateMYOBJECT((MyObject) value, diagnostics, context);
2)In EObjectValidator add test through containment to the
"validate_EveryProxyResolves" :
for (EObject content : eObject.eContents())
if (content.eIsProxy())
result &= false;
if (diagnostics != null)
diagnostics.add(createDiagnostic(Diagnostic.ERROR,
DIAGNOSTIC_SOURCE, EOBJECT__EVERY_PROXY_RESOLVES,
_UI_UnresolvedProxy_diagnostic", new Object[] {
getFeatureLabel(content.eContainingFeature(), context),
getObjectLabel(eObject, context), getObjectLabel(content, context)
}, new Object[] { eObject, content.eContainingFeature(), content },
context));
else
break;
If you are agree, I open two bug ?
Re: cross resouce containment and validation [message #505498 is a reply to message #505489] |
Thu, 31 December 2009 11:55   |
Ed Merks Messages: 30691 Registered: July 2009 |
Simon,
Comments below.
Simon Bernard wrote:
> containment.
> empty value)
> validate it in the validator generated by EMF.
> * @generated
> @Override
> return true;
> context);
> result &= false;
> getObjectLabel(content, context) }, new Object[] { eObject,
> content.eContainingFeature(), content }, context));
> else
> break;
Yes, please open a bugzilla about the whole issue. I'm not totally sure
about generating the guard for case 1 though; we just shouldn't visit
such objects, so perhaps that guard should be in the Diagnostician.
I'll investigate more fully.
Re: cross resouce containment and validation [message #505511 is a reply to message #505498] |
Thu, 31 December 2009 15:27  |
Thx Ed Merkrs, The bug is open :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=298678
Ed Merks a écrit :
> Simon,
> Comments below.
>> Hi,
>> containment.
>> empty value)
>> * @generated
>> @Override
>> return true;
>> context);
>> result &= false;
>> else
>> break;
Current Time: Wed Dec 11 18:59:16 GMT 2019
Powered by FUDForum. Page generated in 0.02041 seconds
