Home » Eclipse Projects » Platform - User Assistance (UA) » local Eclipse help with remote content
local Eclipse help with remote content [message #505352] Tue, 29 December 2009 20:55 Go to next message
Juergen Weber is currently offline Juergen WeberFriend
Member
I understand you can either have local Eclipse help [1] or access Infocenter on an external server with a browser [2].
I think the best were to have the good GUI of local Eclipse help with remote content. Can you link to HTML files on a web server from a local toc.xml?
Juergen
[1] http://www.eclipse.org/articles/article.php?file=Article-Add ingHelpToRCP/index.html
[2] http://www.ibm.com/developerworks/opensource/library/os-ecli psehelp/index.html
Re: local Eclipse help with remote content [message #506710 is a reply to message #505352] Fri, 08 January 2010 22:20 Go to previous messageGo to next message
Chris Goldthorpe is currently offline Chris GoldthorpeFriend
Juergen Weber wrote on Tue, 29 December 2009 15:55
Juergen
Yes you can specify the hrefs in the toc as fully qualified URLs such as http://www.eclipse.org/forums
Re: local Eclipse help with remote content [message #507128 is a reply to message #506710] Tue, 12 January 2010 09:33 Go to previous messageGo to next message
Member
Thanks, that's great, I got it working.
But, the toc.xml itself cannot be pulled from the web server?
Also, it would be nice if you could set a base url in the toc instead for each html source:
<toc label="My Example Book" topic="index.html" baseurl="http://myserver/help/myapp/">
Greetings,
Juergen
[Updated on: Tue, 12 January 2010 04:41]
Report message to a moderator
Re: local Eclipse help with remote content [message #507340 is a reply to message #507128] Wed, 13 January 2010 00:36 Go to previous message
Juergen Weber wrote on Tue, 12 January 2010 04:33
Greetings,
Juergen
You can also have a remote table of contents. If you go to the help / remote content preference page you can specify an infocenter to use that will provide content for you. For example you can set http://help.eclipse.org/galileo/index.jsp as your remote infocenter and then the documents from that site will appear in your local help system.
This feature is intended to allow products to have some or all of their documentation provided from a remote server.
Previous Topic:Infocenter indexing hangs
Next Topic:Using Eclipse Help System with Maven for a SWT Standalone Application
Current Time: Sun Dec 08 09:42:13 GMT 2024
Powered by FUDForum. Page generated in 0.04639 seconds
