Re: buckminster and the delta pack [message #505226 is a reply to message #505218] |
Mon, 28 December 2009 17:28 |
Hi Ted,
I strongly recommend that you don't use the delta pack and instead set up our target platform for the build so that it
contains the multi-platform setup that you use. This is normally the case when you use target.os, target.arch, and
target.ws set to '*'. You can also achieve this by installing this feature into your TP using a 'Software Site'.
The buckminster launcher doesn't care about the delta-pack at all unless you mix your runtime with your target platform
(not recommended). Buckminster comes with two launchers, one shell script for Linux and a bat file for Windows. You
normally don't need an executable to launch Buckminster.
Thomas Hallgren
On 2009-12-28 17:49, Ted Kubaska wrote:
> We're (Eclipse/ECF) using Hudson/Buckminster for our builds. One of
> (will be more) of our builds needs to use the delta pack ... we want to
> build for both Windows and Linux.
> Does the delta pack work with the eclipse exe that came with
> Buckminster? I tried bringing up an osgi console with this eclipse as
> /eclipse -Console
> saw the osgi> prompt but then got a seg fault. I guess what I'm trying
> to do is install an additional plugin via the command line. Can we do
> this (or should we) with the eclipse that Buckminster uses?
> -ted
FUDForum. Page generated in 0.03316 seconds
