Eclipse network problems - debian amd64 [message #505053] |
Fri, 25 December 2009 19:51 |
Originally posted by: gunnar.stahl.gunnarstahl.org
I have a strange problem. I've installed the amd64 version of debian and downloaded and installed the 64bit version of eclipse. I can use eclipse, but the update manager has problems connecting to the internet.
The internet connection itself is working. In eclipse I can open a webbrowser and browse the internet. But as soon as I go to "help -> install new software" I get lots of error messages like:
org.eclipse.equinox.internal.provisional.p2.core.ProvisionEx ception: Unable to read repository at http://download.eclipse.org/tools/mylyn/update/e3.4/content. xml
at org.eclipse.equinox.internal.p2.metadata.repository.CacheMan ager.createCache(CacheManager.java:179)
at org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleM etadataRepositoryFactory.java:60)
at org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository.SimpleMetadataRepositoryFactory.validateAndLoad(Simp leMetadataRepositoryFactory.java:99)
at org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository.SimpleMetadataRepositoryFactory.load(SimpleMetadataR epositoryFactory.java:87)
at org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.factoryLoad(MetadataRepositoryManager.java :54)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractR epositoryManager.loadRepository(AbstractRepositoryManager.ja va:669)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractR epositoryManager.loadRepository(AbstractRepositoryManager.ja va:617)
at org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:92)
at org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:88)
at org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ovisioningUtil.loadMetadataRepository(ProvisioningUtil.java: 88)
at org.eclipse.equinox.internal.provisional.p2.ui.QueryableMeta dataRepositoryManager.doLoadRepository(QueryableMetadataRepo sitoryManager.java:55)
at org.eclipse.equinox.internal.provisional.p2.ui.QueryableRepo sitoryManager.loadRepository(QueryableRepositoryManager.java :195)
at org.eclipse.equinox.internal.provisional.p2.ui.QueryableRepo sitoryManager.loadAll(QueryableRepositoryManager.java:108)
at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryH andler$2.run(PreloadingRepositoryHandler.java:71)
Caused by: java.net.NoRouteToHostException: Das Netzwerk ist nicht erreichbar
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSock etImpl.java:310)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPl ainSocketImpl.java:176)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocket Impl.java:163)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:384)
at java.net.Socket.connect(Socket.java:542)
at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEv entCreateUtil.createSocket(SocketEventCreateUtil.java:43)
at org.eclipse.ecf.internal.provider.filetransfer.httpclient.EC FHttpClientProtocolSocketFactory.createSocket(ECFHttpClientP rotocolSocketFactory.java:81)
at org.eclipse.ecf.internal.provider.filetransfer.httpclient.EC FHttpClientProtocolSocketFactory.createSocket(ECFHttpClientP rotocolSocketFactory.java:73)
at org.eclipse.ecf.internal.provider.filetransfer.httpclient.EC FHttpClientProtocolSocketFactory.createSocket(ECFHttpClientP rotocolSocketFactory.java:65)
at org.apache.commons.httpclient.HttpConnection.open(HttpConnec tion.java:707)
at org.apache.commons.httpclient.MultiThreadedHttpConnectionMan ager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionM anager.java:1361)
at org.apache.commons.httpclient.HttpMethodDirector.executeWith Retry(HttpMethodDirector.java:387)
at org.apache.commons.httpclient.HttpMethodDirector.executeMeth od(HttpMethodDirector.java:171)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpC lient.java:397)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpC lient.java:346)
at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientF ileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java :204)
at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSys temBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:7 1)
... 1 more
The system is:
eclipse.buildId=M20090917-0800
java.version=1.6.0_0
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=de_DE
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.java.product
Does anybody have an idea?
Yt,
Gunnar
(solved) Re: Eclipse network problems - debian amd64 [message #505058 is a reply to message #505053] |
Fri, 25 December 2009 17:46 |
The problem was caused by a pretty unbelievable thing introduced in debian. Found out that java was no longer able to do any sort of network connections anymore. Even connections to localhost failed...
Someone decided to introduce a ipv6-only switch in netbase via /etc/sysctl.d/bindv6only.conf. While this may or may not be a usefull default behaviour for the general the result is that java is no longer able to do networking at all.
So to solve it you have to edit /etc/sysctl.d/bindv6only.conf and change the value of net.ipv6.bindv6only from "1" to "0". Then do a "sudo invoke-rc.d procps restart". After that, java has networking again.
Found that solution on "http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=560056".
Yt,
Gunnar
Gunnar Stahl schrieb:
> Hello,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> erreichbar
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 1 more
> The system is:
> Yt,
> Gunnar
FUDForum. Page generated in 0.08326 seconds
