Home » Language IDEs » ServerTools (WTP) » Disable XML Comment Autocompletion(How do I disable XML comment autocompletion?)
Disable XML Comment Autocompletion [message #504805] Tue, 22 December 2009 18:47 Go to next message
Dan Forward is currently offline Dan ForwardFriend
This is a major annoyance. I want to comment out some XML code, so I begin typing <!-- and the editor immediately appends " -->" with my cursor in the middle.
I then have to press Delete four times and Backspace once to get rid of it so I can place the closing tag where it belongs at the end of the XML block.
I tried modifying the XML comment template, unchecking it, and turning Auto Insert off, but the behavior remains. How do I turn off or modify this behavior?
Re: Disable XML Comment Autocompletion [message #505356 is a reply to message #504805] Tue, 29 December 2009 22:34 Go to previous messageGo to next message
David Carver is currently offline David CarverFriend
You can turn off comment autocompletion by going to:
Preferences->XML Files->Editor->Typing.
Uncheck the check box that says Automatically close "Comments".
Re: Disable XML Comment Autocompletion [message #505358 is a reply to message #505356] Tue, 29 December 2009 22:51 Go to previous message
Thank you! That is exactly what I needed.
Previous Topic:Contribution of enhancements and bug fixes to the Web Page Editor
Next Topic:JSPs throwing incorrect compiler warnings
Current Time: Tue Sep 26 03:49:10 GMT 2023
Powered by FUDForum. Page generated in 0.02682 seconds
