Re: How to perform Auto UI Testing in RAP? [message #505335 is a reply to message #504590] |
Tue, 29 December 2009 11:35 |
tingel christian Messages: 46 Registered: December 2009 |
Member |
Thanks for your information, Rüdiger:)
I hope the apprieciation were not too late...
Actually, the how to works well in most situation.
however, when I am using the method "qxTableClick" declared in the Qooxdoo user extension with a xpath of a table as the locator parameter, it informs me that the method getWidgetByElement is not a proper function.I found this function in a file named Widget.js from Qooxdoo 1.0 package instead of org.eclipse.rap.rwt.q07.jar. And then I used the table id as the locator following string "qxh=", and was told that the method "getApplication()" is not a proper method.
I used a early version of the user extension without getApplication() dependency tonight. But it does not support using xpath as parameter.
I've got myself lost...could you please give me some suggestion?Thx!
[Updated on: Tue, 29 December 2009 11:46] Report message to a moderator
FUDForum. Page generated in 0.03026 seconds
