Integration with the History view [message #51007] |
Fri, 27 June 2008 12:08 |
Marcelo Paternostro Messages: 602 Registered: July 2009 |
I am starting to use Mylyn (at least trying to ;-). I am quite impressed
by the quality of the tools you guys a re providing. Congrats!
In EMF we use the following pattern when entering the comment for our
CVS commits (ignore the single quotes): '[bugzilla number] comments'
(ie, the bugzilla number in square brackets, followed by a space, and
then a text usually describing the changes on the files). So I've set
'Task>Team>Comment Template' to '[${task.key}] ${task.description}'.
My question, as hinted on the subject, is regarding "Mylin's integration
with the History view. In my workspace, the bugzilla # in this view is
not a link and I get a 'Unable to match task. Open Repository Task
dialog?' when I right click a version and hit 'Open Corresponding Task'.
Is this the expected behavior or should I be seeing a nicer integration
here ;-) ? Btw, I did set the project's task repository to Eclipse.org.
I am using Eclipse 3.4 with Mylyn 3.0 (3.0.0.v20080619-1900).
Thanks in advance,
Marcelo
Re: Integration with the History view [message #51197 is a reply to message #51007] |
Fri, 27 June 2008 20:50 |
Steffen Pingel Messages: 706 Registered: July 2009 |
Hi Marcelo,
Thanks. Great to hear that you are trying it out :).
The Bugzilla hyperlink detector expects a prefix ("task" or "bug") to
recognize task ids. You could file a new feature request if using "#" as a
prefix is a common convention in EMF.
I am not sure why 'Open Corresponding Task' is failing though, it should
work based on the specified commit comment template. Please file a new bug
report and we can investigate further:
http://www.eclipse.org/mylyn/bugs/
Steffen
Re: Integration with the History view [message #51743 is a reply to message #51197] |
Wed, 02 July 2008 22:55 |
<html>
<head>
<title></title>
</head>
Thank you for the quick answer! I've opened the feature request
(239376) as you've suggested.<br>
<br>
Cheers,<br>
Marcelo<br>
<br>
Steffen Pingel wrote:
<blockquote cite="mid:g43jr8$elc$6@build.eclipse.org" type="cite">
<pre wrap="">Hi Marcelo,
</pre>
<blockquote type="cite">
<pre wrap="">I am starting to use Mylyn (at least trying to ;-). I am quite impressed
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
<pre wrap="">In EMF we use the following pattern when entering the comment for our
</pre>
</blockquote>
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/mylyn/bugs/">http://www.eclipse.org/mylyn/bugs/</a>
Steffen
</pre>
</blockquote>
</body>
</html>
Re: Integration with the History view [message #590553 is a reply to message #51007] |
Hi Marcelo,
Steffen
Re: Integration with the History view [message #590723 is a reply to message #51197] |
<html>
<head>
<title></title>
</head>
<br>
Cheers,<br>
Marcelo<br>
<br>
</pre>
</pre>
</blockquote>
</pre>
</pre>
</blockquote>
Steffen
</pre>
</blockquote>
</body>
</html>
FUDForum. Page generated in 0.03553 seconds
