Home » Modeling » M2T (model-to-text transformation) » QVTO helper fails
icon9.gif  QVTO helper fails [message #504189] Thu, 17 December 2009 15:55 Go to next message
Marc Mising name is currently offline Marc Mising nameFriend
Hi!
I have the following qvto file:
modeltype genmodel uses "http://www.eclipse.org/emf/2002/GenModel";
modeltype ecore uses "http://www.eclipse.org/emf/2002/Ecore";
library mutatingUtils;
helper getModelSwitchQualifiedName(gc : genmodel::GenClass) : String {
	return gc.genPackage.basePackage + '.' + gc.genPackage.ecorePackage.name + '.' + gc.genPackage.utilityPackageSuffix + '.' + gc.genPackage.prefix + 'Switch'
And I access to this helper in my xpt file like this:
«DEFINE createMutatingSwitch FOR gmfgen::GenDiagram»
static class EReferenceDiagramSwitch {
	public org.eclipse.emf.ecore.EReference doSwitch(org.eclipse.emf.ecore.EObject modelElement) {
		«getModelSwitchQualifiedName(domainDiagramElement)» aSwitch = new «getModelSwitchQualifiedName(domainDiagramElement)»() {
«ENDDEFINE»
But when execute the transformation, an error occurs:
Exception (Can't evaluate expression: retured value is OclInvalid:in aspects::xpt::diagram::editpolicies::DiagramItemSemanticEditPolicy, line 85) while generating code
Could anybody help me please? I don't know what I'm doing wrong... I'm doing the same like the GMF templates, but I don't know if I must to specify certain plugins or extensions in the plugin dependency list...
Thanks!!
Marc
Re: QVTO helper fails [message #504312 is a reply to message #504189] Fri, 18 December 2009 04:49 Go to previous message
Well, I solved it by adding a '.' string before:
	return '.' + gc.genPackage.basePackage + '.' + gc.genPackage.ecorePackage.name + '.' + gc.genPackage.utilityPackageSuffix + '.' + gc.genPackage.prefix + 'Switch'
Solved!
Marc
[Updated on: Fri, 18 December 2009 04:50]
Report message to a moderator
Previous Topic:[XPAND] perform OAW code without creating physical files
Next Topic:Problems accessing to QVTO operations
Current Time: Thu Apr 25 12:06:24 GMT 2024
Powered by FUDForum. Page generated in 0.03551 seconds
