Home » Eclipse Projects » Rich Client Platform (RCP) » How to trim down application size?
Re: How to trim down application size? [message #539799 is a reply to message #505910] |
Sun, 13 June 2010 12:44 |
Mauro Condarelli Messages: 428 Registered: September 2009 |
On 05/01/2010 15.53, Paul Webster wrote:
> Are you using org.eclipse.ui.ide? If not, get rid of it (it contains
> mostly code to work with core.resources, which you haven't included).
> Are you using org.eclipse.help? And org.eclipse.text, that's the text
> editor support.
> As for com.ibm.icu, if you don't need the i18n support you can replace
> it with com.ibm.icu.base (a plugin listed on the
> http://download.eclipse.org/eclipse/downloads/drops/R-3.5.1- 200909170800/index.php
> page, for example).
> PW
I have an EMF model. Does it count as Resource?
I do *not* have a workspace, just I just open a model file in the filesystem.
I tried getting rid of help, but I got the error:
Cannot complete the install because one or more required items could not be found.
Software being installed: Writer Application 1.0.0 (it.condarelli.writer 1.0.0)
Missing requirement: Workbench 3.5.2.M20100113-0800 (org.eclipse.ui.workbench 3.5.2.M20100113-0800) requires 'bundle org.eclipse.help [3.2.0,4.0.0)' but it could not be found
Cannot satisfy dependency:
From: Writer Application 1.0.0 (it.condarelli.writer 1.0.0)
To: org.eclipse.ui.workbench [3.5.2.M20100113-0800]
Is there an "approved Way" to find out what can be deleted from dependencies?
The automated Writer.product->Dependencies->Add Required Plug-ins pulls in a lot of things obviously not needed.
Is there something better available?
TiA
Mauro
Re: How to trim down application size? [message #540159 is a reply to message #540102] |
Tue, 15 June 2010 07:48 |
>> filesystem.
> No, I'm just curious why you have org.eclipse.ui.ide in there. Remove it
> if you can, it's for providing workbench services that deal with
> IResources (the org.eclipse.core.resources plugin). That's for
> workspaces, which you don't have.
The culprit was usage of FileStoreEditorInput which is in
org.eclipse.ui.ide. (why????)
I wrote my own LocalEditorInput/LocalEditorInputFactory and I managed to
get rid of ide (almost).
> A quick glance through the original list and it looks like the only
> other thing you can do is to replace com.ibm.icu with com.ibm.icu.base
> (so it is significantly smaller).
My current dependencies for my plugin is:
it.condarelli.writer.model,
org.eclipse.core.runtime,
org.eclipse.ui,
org.eclipse.jface.databinding,
org.eclipse.emf.databinding,
org.eclipse.ui.forms,
org.eclipse.core.filesystem,
org.eclipse.core.databinding.property,
org.eclipse.jface.text,
org.eclipse.ui.editors,
org.eclipse.nebula.widgets.ganttchart
Unfortunately the dependencies for the whole product (trimmed down by
hand, the automated dependency generator produces a *much* larger set) is:
<plugin id="com.ibm.icu"/>
<plugin id="it.condarelli.writer.model"/>
<plugin id="org.eclipse.compare"/>
<plugin id="org.eclipse.compare.core"/>
<plugin id="org.eclipse.core.commands"/>
<plugin id="org.eclipse.core.contenttype"/>
<plugin id="org.eclipse.core.databinding"/>
<plugin id="org.eclipse.core.databinding.observable"/>
<plugin id="org.eclipse.core.databinding.property"/>
<plugin id="org.eclipse.core.expressions"/>
<plugin id="org.eclipse.core.filebuffers"/>
<plugin id="org.eclipse.core.filesystem"/>
<plugin id="org.eclipse.core.filesystem.win32.x86" fragment="true"/>
<plugin id="org.eclipse.core.jobs"/>
<plugin id="org.eclipse.core.resources"/>
<plugin id="org.eclipse.core.resources.compatibility" fragment="true"/>
<plugin id="org.eclipse.core.resources.win32.x86" fragment="true"/>
<plugin id="org.eclipse.core.runtime"/>
<plugin id="org.eclipse.core.runtime.compatibility.registry"
fragment="true"/>
<plugin id="org.eclipse.core.variables"/>
<plugin id="org.eclipse.ecf"/>
<plugin id="org.eclipse.ecf.filetransfer"/>
<plugin id="org.eclipse.ecf.identity"/>
<plugin id="org.eclipse.ecf.provider.filetransfer"/>
<plugin id="org.eclipse.ecf.provider.filetransfer.ssl" fragment="true"/>
<plugin id="org.eclipse.ecf.ssl" fragment="true"/>
<plugin id="org.eclipse.emf.common"/>
<plugin id="org.eclipse.emf.databinding"/>
<plugin id="org.eclipse.emf.ecore"/>
<plugin id="org.eclipse.emf.ecore.xmi"/>
<plugin id="org.eclipse.equinox.app"/>
<plugin id="org.eclipse.equinox.common"/>
<plugin id="org.eclipse.equinox.p2.artifact.repository"/>
<plugin id="org.eclipse.equinox.p2.core"/>
<plugin id="org.eclipse.equinox.p2.engine"/>
<plugin id="org.eclipse.equinox.p2.jarprocessor"/>
<plugin id="org.eclipse.equinox.p2.metadata"/>
<plugin id="org.eclipse.equinox.p2.metadata.repository"/>
<plugin id="org.eclipse.equinox.p2.repository"/>
<plugin id="org.eclipse.equinox.preferences"/>
<plugin id="org.eclipse.equinox.registry"/>
<plugin id="org.eclipse.equinox.security"/>
<plugin id="org.eclipse.equinox.security.win32.x86" fragment="true"/>
<plugin id="org.eclipse.help"/>
<plugin id="org.eclipse.jface"/>
<plugin id="org.eclipse.jface.databinding"/>
<plugin id="org.eclipse.jface.text"/>
<plugin id="org.eclipse.nebula.widgets.ganttchart"/>
<plugin id="org.eclipse.osgi"/>
<plugin id="org.eclipse.osgi.services"/>
<plugin id="org.eclipse.swt"/>
<plugin id="org.eclipse.swt.win32.win32.x86" fragment="true"/>
<plugin id="org.eclipse.text"/>
<plugin id="org.eclipse.ui"/>
<plugin id="org.eclipse.ui.editors"/>
<plugin id="org.eclipse.ui.forms"/>
<plugin id="org.eclipse.ui.ide"/>
<plugin id="org.eclipse.ui.views"/>
<plugin id="org.eclipse.ui.win32" fragment="true"/>
<plugin id="org.eclipse.ui.workbench"/>
<plugin id="org.eclipse.ui.workbench.texteditor"/>
<plugin id="Writer"/>
where org.eclipse.ui.ide is back with some strange friends
(org.eclipse.ecf.*).
Two questions:
Is there any way to trim down this beast? It seems to me a refactoring
of some classes (e.g.: FileStoreEditorInput) would be beneficial for all
of us wanting to use RCP "just" as an Application Framework.
You said I should "replace com.ibm.icu with com.ibm.icu.base", but I
didn't find a way to do that. Can You tell me how to achieve that?
Many Thanks.
Mauro
> You might be right, as long as you use org.eclipse.ui.workbench you
> can't get rid of help.
> Later,
> PW
Current Time: Fri Apr 19 06:01:39 GMT 2024
Powered by FUDForum. Page generated in 0.02005 seconds
