Re: What means if my folders have a square (and a cross inside of it) in the explorer? [message #504041 is a reply to message #504029] |
Wed, 16 December 2009 21:55 |
tirengarfio wrote:
> what means if my folders have a square (and a cross inside of it) in the
> explorer?
> Bye
> Javi
In the Package Explorer view?
And, you mean a black square with a white asterisk inside?
This signifies that a) your folder (and most likely its contents) are
under source code control and b) either the folder or one of its
children has been modified (is different from the version in the
repository).
You can detect the divergent file by opening the folder and looking for
another icon carrying the same black flag with white asterisk. Any time
a dependent file is different from its repository copy, all the folders
that subsume it (are hierarchically superior to it) will carry the same
black flag on their icon.
You can right-click on the file or folder, choose Team, then Commit,
Update, Revert, etc.
Hope this helps,
Russ
Re: What means if my folders have a square (and a cross inside of it) in the explorer? [message #504214 is a reply to message #504104] |
Thu, 17 December 2009 17:09 |
tirengarfio wrote:
> Thank Russ, but im talking about a folder icon with a square and a cross
> (a square divided in four little squares).
> Javi
As Eric notes, you're probably talking about a "package". This is a
folder (in the filesystem) that specifically represents a Java package
path AND, I believe, is only thus marked in Eclipse source directories.
Whether a subdirectory supplies recognized source code to an Eclipse
project is governed by the Source tab in the Java Build Paths dialog.
Not all folders in the file system of a project are source folders.
For more information see what Eric advised. You can also read about icon
modifications at
http://www.windofkeltia.com/notes/eclipse.html#icons
Hope this helps a little more.
Russ
FUDForum. Page generated in 0.07746 seconds
