Home » Modeling » M2T (model-to-text transformation) » [XPand] targetDef.proceed() fails
[XPand] targetDef.proceed() fails [message #503981] Wed, 16 December 2009 17:14 Go to next message
Marc Mising name is currently offline Marc Mising nameFriend
In Galileo, I want to use «targetDef.proceed()» to "call" the parent rule to proceed with the transformation, but I get an error when do the transformation:
Exception (Can't evaluate expression: retured value is OclInvalid:in aspects::xpt::diagram::commands::CreateNodeCommand, line 23) while generating code
My template code is:
«AROUND CreateNodeCommand FOR gmfgen::GenNode-»
«EXPAND xpt::Common::copyright FOR getDiagram().editorGen-»
package «getDiagram().editCommandsPackageName»;
«EXPAND xpt::Common::generatedClassComment»
public class «createCommandClassName» extends org.eclipse.gmf.runtime.emf.type.core.commands.EditElementCommand {
	«EXPAND getEClassToEdit-»
«ENDAROUND»
Could anybody help me please?
Thanks!!
Marc
[Updated on: Wed, 16 December 2009 17:18]
Report message to a moderator
Re: [XPand] targetDef.proceed() fails [message #504032 is a reply to message #503981] Wed, 16 December 2009 21:07 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Hello Marc,
are you using GMF's Xpand (fork?). Search the weg for the error message you posted resulted in org.eclipse.gmf.internal.xpand.ocl.ExpressionHelper. If so this should be a question asked in the GMF forum.
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: [XPand] targetDef.proceed() fails [message #504187 is a reply to message #504032] Thu, 17 December 2009 10:47 Go to previous message
Thanks Christian, I'm waiting for a response in GMF.
Marc
Previous Topic:[Announce] M2T XPAND 0.8.0M4 is available
Next Topic:The Generator does not produce the correct results from the first time!?
Current Time: Tue Nov 29 08:02:14 GMT 2022
Powered by FUDForum. Page generated in 0.01754 seconds
