Re: unsupported content file" error [message #504382 is a reply to message #503923] |
Fri, 18 December 2009 15:25 |
Ali Asghar Toraby wrote:
> I've installed aptana plugin in my eclipse for jquery support. it works.
> but one problem exist.
> when i want to open html file by html editor i see the "unsupported
> content file" error dialog.
> what is the problem?
> I think installation of aptana cause this inconsistency. Am i right?
Most likely. If you bring up the Properties dialog of the file,
does the Resource page still say it's of type "File (HTML)"?
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: unsupported content file" error [message #504447 is a reply to message #503923] |
Sat, 19 December 2009 12:23 |
Ali Asghar Toraby Messages: 2 Registered: December 2009 |
Junior Member |
I have checked source file type. it is html.
when i use fresh copy of eclipse i don't have any problem. but when i install aptana plugin i cant open files with traditional eclipse html editor.
this is log file:
!ENTRY org.eclipse.wst.sse.ui 2 2 2009-12-19 15:49:08.703
!MESSAGE StructuredTextEditor being used without StructuredDocument
!ENTRY org.eclipse.wst.sse.ui 2 2 2009-12-19 15:49:08.718
!MESSAGE Input Name: test.html
!MESSAGE Unexpected IDocumentProvider implementation: org.eclipse.ui.editors.text.TextFileDocumentProvider
!MESSAGE Unexpected IDocument implementation: org.eclipse.core.internal.filebuffers.SynchronizableDocument
!ENTRY org.eclipse.ui 4 0 2009-12-19 15:49:08.765
!MESSAGE Unable to create editor ID org.eclipse.jst.pagedesigner.PageDesignerEditor: An unexpected exception was thrown.
!STACK 0
at org.eclipse.wst.sse.ui.StructuredTextEditor.createModelDependentFields(StructuredTextEditor.java:1305)
at org.eclipse.wst.sse.ui.StructuredTextEditor.update(StructuredTextEditor.java:2836)
at org.eclipse.jst.pagedesigner.editors.HTMLEditor.sash_createAndAddDesignSourcePage(HTMLEditor.java:269)
at org.eclipse.jst.pagedesigner.editors.HTMLEditor.createPages(HTMLEditor.java:430)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:357)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:662)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:462)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1608)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:778)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:677)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:638)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2854)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2762)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2754)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2705)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2701)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2685)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2676)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
at org.eclipse.dltk.internal.ui.editor.EditorUtility.openInEditor(EditorUtility.java:394)
at org.eclipse.dltk.internal.ui.editor.EditorUtility.openInEditor(EditorUtility.java:141)
at org.eclipse.dltk.internal.ui.actions.OpenActionUtil.open(OpenActionUtil.java:45)
at org.eclipse.dltk.ui.actions.OpenAction.run(OpenAction.java:256)
at org.eclipse.dltk.ui.actions.OpenAction.run(OpenAction.java:237)
at org.eclipse.dltk.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:259)
at org.eclipse.dltk.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:235)
at org.eclipse.dltk.internal.ui.scriptview.ScriptExplorerActionGroup.handleOpen(ScriptExplorerActionGroup.java:304)
at org.eclipse.php.internal.ui.explorer.PHPExplorerActionGroup.handleOpen(PHPExplorerActionGroup.java:93)
at org.eclipse.dltk.internal.ui.scriptview.ScriptExplorerPart$4.open(ScriptExplorerPart.java:662)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:842)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:840)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1101)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1205)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:264)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:258)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:298)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3473)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
[Updated on: Sat, 19 December 2009 12:25] Report message to a moderator
FUDForum. Page generated in 0.01839 seconds
