Home » Eclipse Projects » Eclipse 4 » Develop reusable Custom Widgets In XWT
Develop reusable Custom Widgets In XWT [message #503761] |
Tue, 15 December 2009 11:10 |
Jinshan Messages: 24 Registered: December 2009 |
Thanks for the answers from Yves YANG in e4 developer mailing list.
For example:
In your example, DecoratedText have property ,text, then the widgets will be used as following:
<Composite xmlns:c="clr-namespace:ext.custom">
<c:DecoratedText text="newWidgets" />
</Composite>
and :
DecoratedText.java
package ext.custom;
public class DecoratedText {
private String text;
// event handling methods
DecoratedText.xwt
<Composite x:Class="ext.custom.DecoratedText">
<Label text={xxxxxx??}/> <!-How to do? Label.text="newWidgets"->
<Text/>
</Composite>
How to get the property text in DecoratedText.xwt and set it into a Label or others.
[Updated on: Tue, 15 December 2009 11:13] Report message to a moderator
Re: Develop reusable Custom Widgets In XWT [message #504071 is a reply to message #503851] |
Wed, 16 December 2009 15:03 |
Yves YANG Messages: 688 Registered: July 2009 |
The simple solution is you create a "String text" property in DecoratedText.
In the setter, you can update the content in your widget text or label.
It should be possible to express in XAML. But we need to add a keyword in
binding expression "self". It is not yet supported in XWT.
The code should be:
<Label name="myText"/>
<Text text="{Binding source=self,path=text}" />
</Composite>
Best regards
yves
"Jinshan" <jinshanl@gmail.com> wrote in message
news:hg9hge$rl5$1@build.eclipse.org...
> Thanks.
> Are there some way to bind DecoratedText.java's properties to
> DecoratedText.xwt.?
> For example:
> then
> <Text/>
> </Composite>
> "myText" Label is changed automatic and I need not handle "text" changed
> event. I know the SilverLight is OK.
> Yves YANG wrote on Tue, 15 December 2009 18:00
>> Here is the bug for this feature:
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=297586
>> yves
>> "Yves YANG" <yves.yang@soyatec.com> wrote in message
>> news:hg90to$fq7$1@build.eclipse.org...
>> >> Label or others.
>> > By now, you need to give them a name. and then call
>> > XWT.findElementByName(context, "<name>");
>> > <Label name="myText" text={xxxxxx??}/>
>> > <Text/>
>> > </Composite>
>> > protected void eventHandle(Object sender, Event event) {
>> > Text text = (Text) XWT.findElementByName(event.widget,
>> > "myText");
>> > We are considering to provide automatic solution to initialize the
>> > class Field to avoid the manuel research call
>> > Best regards
>> > Yves YANG
>> > news:hg8ce9$hmb$1@build.eclipse.org...
>> >> For example:
>> >> </Composite>
>> >> and :
>> >> DecoratedText.java
>> >> package ext.custom;
>> >> DecoratedText.xwt
>> >> <Text/>
>> >> </Composite>
>> >> Label or others.
>> >> Thanks
Re: Develop reusable Custom Widgets In XWT [message #504262 is a reply to message #504071] |
Thu, 17 December 2009 22:14 |
This should work.
name="root">
<Text text="{Binding elementName=root,path=text}" />
</Composite>
yves
news:hgc6jo$s73$1@build.eclipse.org...
> DecoratedText. In the setter, you can update the content in your widget
> text or label.
> The code should be:
> </Composite>
> Best regards
> yves
>> Thanks.
>> DecoratedText.xwt.?
>> For example:
>> then
>> <Text/>
>> </Composite>
>>> yves
>>> >> Label or others.
>>> > <Text/>
>>> > </Composite>
>>> > "myText");
>>> > Best regards
>>> > Yves YANG
>>> >> For example:
>>> >> </Composite>
>>> >> and :
>>> >> DecoratedText.java
>>> >> package ext.custom;
>>> >> DecoratedText.xwt
>>> >> <Text/>
>>> >> </Composite>
>>> >> Label or others.
>>> >> Thanks
Re: Develop reusable Custom Widgets In XWT [message #504272 is a reply to message #504262] |
Fri, 18 December 2009 01:28 |
name="root">
</Composite>
I have checked. This solution works.
yves
news:hgeah2$sfm$1@build.eclipse.org...
> This should work.
> name="root">
> </Composite>
> yves
>> text or label.
>> The code should be:
>> </Composite>
>> Best regards
>> yves
>>> Thanks.
>>> DecoratedText.xwt.?
>>> For example:
>>> then
>>> <Text/>
>>> </Composite>
>>>> yves
>>>> >> Label or others.
>>>> > <Text/>
>>>> > </Composite>
>>>> > "myText");
>>>> > Best regards
>>>> > Yves YANG
>>>> >> For example:
>>>> >> </Composite>
>>>> >> and :
>>>> >> DecoratedText.java
>>>> >> package ext.custom;
>>>> >> DecoratedText.xwt
>>>> >> <Text/>
>>>> >> </Composite>
>>>> >> Label or others.
>>>> >> Thanks
Re: Develop reusable Custom Widgets In XWT [message #504304 is a reply to message #504272] |
Fri, 18 December 2009 09:00 |
My e4 version is eclipse-e4-SDK-incubation-I20091022-2100-win32. but the fellowing does not work:
Widget:
<Composite xmlns="http://www.eclipse.org/xwt/presentation"
xmlns:x="http://www.eclipse.org/xwt" xmlns:c="clr-namespace:allegro.ui.widgets"
xmlns:j="clr-namespace:java.lang" x:Class="allegro.ui.widgets.Image" name="root">
<Composite.layout>
<FillLayout />
</Composite.layout>
<Label name="imageLabel" image="{Binding elementName=root,path=source}" />
</Composite>
Using:
xmlns:c="clr-namespace:allegro.image"
xmlns:a="clr-namespace:allegro.ui.widgets"
x:Class="allegro.image.ImageTest">
<Composite.layout>
<GridLayout numColumns="4" />
</Composite.layout>
<a:Image source="logo.gif"/>
</Composite>
Yves YANG wrote on Thu, 17 December 2009 20:28 | <Composite x:Class="ext.custom.DecoratedText"
name="root">
</Composite>
yves
> This should work.
> name="root">
> </Composite>
> yves
>> text or label.
>> The code should be:
>> </Composite>
>> Best regards
>> yves
>>> Thanks.
>>> DecoratedText.xwt.?
>>> For example:
>>> then
>>> <Text/>
>>> </Composite>
>>>> yves
>>>> >> Label or others.
>>>> > <Text/>
>>>> > </Composite>
>>>> > "myText");
>>>> > Best regards
>>>> > Yves YANG
>>>> >> For example:
>>>> >> </Composite>
>>>> >> and :
>>>> >> DecoratedText.java
>>>> >> package ext.custom;
>>>> >> DecoratedText.xwt
>>>> >> <Text/>
>>>> >> </Composite>
>>>> >> Label or others.
>>>> >> Thanks
Re: Develop reusable Custom Widgets In XWT [message #504398 is a reply to message #504304] |
Fri, 18 December 2009 16:58 |
The code seems correct. It should work. Please test it with the last build?
Best regards
Yves YANG
news:hgfgbu$sjd$1@build.eclipse.org...
> Widget:
> name="root">
> <Composite.layout>
> <FillLayout />
> </Composite.layout>
> </Composite>
> Using:
> <Composite.layout>
> </Composite.layout>
> </Composite>
>> name="root">
>> </Composite>
>> yves
>> > This should work.
>> > name="root">
>> > </Composite>
>> > yves
>> >> in binding expression "self". It is not yet supported in XWT.
>> >> The code should be:
>> >> </Composite>
>> >> Best regards
>> >> yves
>> >>> Thanks.
>> >>> DecoratedText.xwt.?
>> >>> For example:
>> >>> then
>> >>> <Text/>
>> >>> </Composite>
>> >>> changed event. I know the SilverLight is OK.
>> >>>> yves
>> >>>> >> a Label or others.
>> >>>> > <Text/>
>> >>>> > </Composite>
>> >>>> > "myText");
>> >>>> > the class Field to avoid the manuel research call
>> >>>> > Best regards
>> >>>> > Yves YANG
>> >>>> >> list.
>> >>>> >> For example:
>> >>>> >> </Composite>
>> >>>> >> and :
>> >>>> >> DecoratedText.java
>> >>>> >> package ext.custom;
>> >>>> >> DecoratedText.xwt
>> >>>> >> <Text/>
>> >>>> >> </Composite>
>> >>>> >> a Label or others.
>> >>>> >> Thanks
Re: Develop reusable Custom Widgets In XWT [message #566190 is a reply to message #566128] |
The code should be:
</Composite>
Best regards
yves
> Thanks.
> DecoratedText.xwt.?
> For example:
> then
> <Text/>
> </Composite>
>> yves
>> >> Label or others.
>> > <Text/>
>> > </Composite>
>> > "myText");
>> > Best regards
>> > Yves YANG
>> >> For example:
>> >> </Composite>
>> >> and :
>> >> DecoratedText.java
>> >> package ext.custom;
>> >> DecoratedText.xwt
>> >> <Text/>
>> >> </Composite>
>> >> Label or others.
>> >> Thanks
Re: Develop reusable Custom Widgets In XWT [message #566259 is a reply to message #504071] |
This should work.
name="root">
</Composite>
yves
> text or label.
> The code should be:
> </Composite>
> Best regards
> yves
>> Thanks.
>> DecoratedText.xwt.?
>> For example:
>> then
>> <Text/>
>> </Composite>
>>> yves
>>> >> Label or others.
>>> > <Text/>
>>> > </Composite>
>>> > "myText");
>>> > Best regards
>>> > Yves YANG
>>> >> For example:
>>> >> </Composite>
>>> >> and :
>>> >> DecoratedText.java
>>> >> package ext.custom;
>>> >> DecoratedText.xwt
>>> >> <Text/>
>>> >> </Composite>
>>> >> Label or others.
>>> >> Thanks
Re: Develop reusable Custom Widgets In XWT [message #566271 is a reply to message #504262] |
name="root">
</Composite>
yves
> This should work.
> name="root">
> </Composite>
> yves
>> text or label.
>> The code should be:
>> </Composite>
>> Best regards
>> yves
>>> Thanks.
>>> DecoratedText.xwt.?
>>> For example:
>>> then
>>> <Text/>
>>> </Composite>
>>>> yves
>>>> >> Label or others.
>>>> > <Text/>
>>>> > </Composite>
>>>> > "myText");
>>>> > Best regards
>>>> > Yves YANG
>>>> >> For example:
>>>> >> </Composite>
>>>> >> and :
>>>> >> DecoratedText.java
>>>> >> package ext.custom;
>>>> >> DecoratedText.xwt
>>>> >> <Text/>
>>>> >> </Composite>
>>>> >> Label or others.
>>>> >> Thanks
Re: Develop reusable Custom Widgets In XWT [message #566299 is a reply to message #504272] |
Widget:
<Composite.layout>
<FillLayout />
</Composite.layout>
</Composite>
Using:
<Composite.layout>
</Composite.layout>
</Composite>
> name="root">
> </Composite>
> yves
> > This should work.
> > name="root">
> > </Composite>
> > yves
> >> text or label.
> >> The code should be:
> >> </Composite>
> >> Best regards
> >> yves
> >>> Thanks.
> >>> DecoratedText.xwt.?
> >>> For example:
> >>> then
> >>> <Text/>
> >>> </Composite>
> >>>> yves
> >>>> >> Label or others.
> >>>> > <Text/>
> >>>> > </Composite>
> >>>> > "myText");
> >>>> > Best regards
> >>>> > Yves YANG
> >>>> >> For example:
> >>>> >> </Composite>
> >>>> >> and :
> >>>> >> DecoratedText.java
> >>>> >> package ext.custom;
> >>>> >> DecoratedText.xwt
> >>>> >> <Text/>
> >>>> >> </Composite>
> >>>> >> Label or others.
> >>>> >> Thanks
Re: Develop reusable Custom Widgets In XWT [message #566352 is a reply to message #566299] |
Best regards
Yves YANG
> Widget:
> name="root">
> <Composite.layout>
> <FillLayout />
> </Composite.layout>
> </Composite>
> Using:
> <Composite.layout>
> </Composite.layout>
> </Composite>
>> name="root">
>> </Composite>
>> yves
>> > This should work.
>> > name="root">
>> > </Composite>
>> > yves
>> >> The code should be:
>> >> </Composite>
>> >> Best regards
>> >> yves
>> >>> Thanks.
>> >>> DecoratedText.xwt.?
>> >>> For example:
>> >>> then
>> >>> <Text/>
>> >>> </Composite>
>> >>>> yves
>> >>>> >> a Label or others.
>> >>>> > <Text/>
>> >>>> > </Composite>
>> >>>> > "myText");
>> >>>> > Best regards
>> >>>> > Yves YANG
>> >>>> >> list.
>> >>>> >> For example:
>> >>>> >> </Composite>
>> >>>> >> and :
>> >>>> >> DecoratedText.java
>> >>>> >> package ext.custom;
>> >>>> >> DecoratedText.xwt
>> >>>> >> <Text/>
>> >>>> >> </Composite>
>> >>>> >> a Label or others.
>> >>>> >> Thanks
Current Time: Thu Apr 18 08:29:26 GMT 2024
Powered by FUDForum. Page generated in 0.02836 seconds
