Home » Modeling » M2T (model-to-text transformation) » migrating from oaw: Workflow problems
icon9.gif  migrating from oaw: Workflow problems [message #503495] Mon, 14 December 2009 14:04 Go to next message
Marc Mising name is currently offline Marc Mising nameFriend
Hi, I'm a little desperate, because I'm migrating from ganymede to galileo all the plugins, including all with transformations too.
First, I like to know if there exist any documentation like the one for 4.3.1 version ( http://www.openarchitectureware.org/pub/documentation/4.3.1/ openArchitectureWare-4.3.1-Reference.pdf).
I want to know if the workflow file has been modified for the components. Before I had the following components:
  • org.openarchitectureware.emf.XmiReader
  • org.openarchitectureware.xpand2.Generator
The beautifier:
  • org.openarchitectureware.xpand2.output.XmlBeautifier
The metamodel class:
  • org.openarchitectureware.type.emf.EmfMetaModel
And a check file I use that extends the following class:
  • org.openarchitectureware.emf.check.EMFChecker
Now, I don't know where are this classes, and the plugins I must use.
There exists any example about workflows and plugins where I can see the plugins dependency list and their uses?
Could anybody help me, please? Thanks a lot!!
Marc
Re: migrating from oaw: Workflow problems [message #503529 is a reply to message #503495] Mon, 14 December 2009 10:38 Go to previous messageGo to next message
Ilyas Keser is currently offline Ilyas KeserFriend
Member
Hi Marc,
there are some blog posts about the migration to oAW5:
http://ekkescorner.wordpress.com/blog-series/modeling-oaw/
http://kthoms.wordpress.com/2009/07/16/oaw-4-migration-with- cartridge-adaption/
http://swissdev.blogspot.com/2009/07/eclipse-and-openarchite ctureware.html
Hope it helps
ILyas
> 4.3.1 version
> The beautifier:
> Marc
Re: migrating from oaw: Workflow problems [message #503532 is a reply to message #503529] Mon, 14 December 2009 15:54 Go to previous message
Thanks ILyas!
And what's about the manual or documentation like the pdf I attached? Isn't exists nowadays?
Marc
Re: migrating from oaw: Workflow problems [message #503596 is a reply to message #503532] Mon, 14 December 2009 15:44 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
hi
have a look at
http:// help.eclipse.org/galileo/index.jsp?topic=/org.eclipse.emf.mw e.doc/help/index.html and http:// help.eclipse.org/galileo/index.jsp?topic=/org.eclipse.xpand. doc/help/ch01.html
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Previous Topic:[XPAND] Couldn't find Model
Next Topic:[Xtend] XtendComponent vs. XtendFacade
Current Time: Wed May 31 00:29:25 GMT 2023
Powered by FUDForum. Page generated in 0.01988 seconds
