Home » Archived » M2M (model-to-model transformation) » [ATL] Problems with EMF-Specific VM and Regular VM
[ATL] Problems with EMF-Specific VM and Regular VM [message #503385] Sat, 12 December 2009 11:47 Go to next message
Jean-Pierre Bourey is currently offline Jean-Pierre BoureyFriend
Hi everybody
I'm working on transformations of "large" models (i.e more than 100 models elements) with Eclipse Modeling Tools package ( Version: 3.5.1, Build id: M20090917-0800) including ATL 3.0.1.
I have started by a simple transformation consisting in transforming a 110 classes UML model into another UML Model (just by copying th class name).
My ATL code is the following:
-- @path UML2=platform:/plugin/org.eclipse.uml2.uml/model/UML.ecore
module Class2ClassSimple;
create OUT : UML2 from IN : UML2;
rule Model2Model  {
	from source : UML2!Model
	to target   : UML2!Model (
		name            <-source.name,
		packagedElement <-source.packagedElement)
do {
--just to display some traces on the console
	let s : String = 'RULE:Model2Model => BEGIN' 	in s.println();
	-- display  the current Model  name created
	let s : String = '     => target.name=<' in (s + target.name + '>').println();
	let s : String = 'RULE:Model2Model => END' 	in s.println();
   } -- end of 'do' section
}-- end of rule 'Model2Model'
rule Class2Class {
	from source : UML2!Class
	to   target : UML2!Class (
		name <-source.name)
do {
	let s : String = 'RULE:Class2Class => BEGIN' in s.println();
	-- display  the current class  name created
	let s : String = 'RULE:Class2Class => END' 	in s.println();
I have perfomed some tests and I have encountered 2 problems :
1) when I try to launch this transformation by the menu "Run configurations" using on the "Advanced tab" the "EMF Specific VM" with a small model it works. But with more than 100 classes (98 to be exact) I get the following error :
org.eclipse.m2m.atl.engine.emfvm.VMException: 100
	at __exec__(Class2ClassSimple.atl)
		local variables: self=thisModule, e=org.eclipse.m2m.atl.engine.emfvm.lib.TransientLink@1fbf7cd
	at main(Class2ClassSimple.atl)
Java Stack:
	at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:615)
	at org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperation.java:387)
	at org.eclipse.m2m.atl.engine.emfvm.ASM.run(ASM.java:197)....
It seems that the size of EMF VM is limited to 100, that means only 100 target element can be created. Is true (in that case, how to do to avoid this limit) or a misunderstanding of myself
But when I run it with the "Regular VM with debugger" it works.
Due to my weak knowlegde about EMF and how ATL really works inside, all explanations, documentation or links will be appreciated to light my way
2) The second problem deals with ATL ANT tasks. I have written the following build.xml :
<project name="Class2ClassSimpleWithMoreThan100Classes"
	     default="transfo"
		 basedir=".">
	<property name="inputModel"
		      value="My110Classes"/>
	<target name="loadMetaModels">
			<atl.loadModel modelHandler="UML2"
				           name="UML2MM"
				           metamodel="MOF"
				           nsURI="http://www.eclipse.org/uml2/3.0.0/UML"/>
	</target>
	<target name="transfo"
		    depends="loadMetaModels">
		<atl.loadModel name="sourceModel"
			           metamodel="UML2MM"
			           path="InputModels/${inputModel}.uml"/>
		<atl.launch path="Transformations/Class2ClassSimple.asm">
			<inModel name="IN"
				     model="sourceModel"/>
			<inModel name="UML2"
				     model="UML2MM"/>
			<outModel name="OUT"
				      model="targetUmlModel"
				      metamodel="UML2MM"
				      modelHandler="UML2"
				      path="OutputModels/${inputModel}_WithANT.uml"/>
		</atl.launch>
		<atl.saveModel model="targetUmlModel"
	</target>
</project>
When I run this file, I get the following error after the transformation of the 98th class :
BUILD FAILED
C:\__EC-Lille\workspaceEclipse351ATL301\Class2ClassWithProfile\build.xml:22: 100
I guess that this error is related to the EMF specific VM which is use by default.(same problem as mentionned in my first problem
but when I add the following property at the beginning of the build.xml :
<property name="atl.launcher"
		      value="Regular VM (with debugger)"/>
I get the following messages on the console:
Buildfile: C:\__EC-Lille\workspaceEclipse351ATL301\Class2ClassWithProfile\build.xml
loadMetaModels:
[atl.loadModel] Loading model UML2MM from http://www.eclipse.org/uml2/3.0.0/UML
transfo:
[atl.loadModel] Loading model sourceModel from file:/C:\__EC-Lille\workspaceEclipse351ATL301\Class2ClassWithProfile\InputModels\My110Classes.uml
  [atl.launch] Launching transformation C:\__EC-Lille\workspaceEclipse351ATL301\Class2ClassWithProfile\Transformations\Class2ClassSimple.asm using Regular VM (with debugger)
BUILD FAILED
C:\__EC-Lille\workspaceEclipse351ATL301\Class2ClassWithProfile\build.xml:23: null
Total time: 209 milliseconds
Therefore my question is: which step(s) did I miss or what is wrong in what I have written ?
Many thanks in advance for any help and/or explanations
best regards
jean-pierre
Re: [ATL] Problems with EMF-Specific VM and Regular VM [message #503412 is a reply to message #503385] Sun, 13 December 2009 13:14 Go to previous messageGo to next message
Hi everybody,
I looked at the "opened bugs" page and I found an entry on EMFVMs stacksize
limitation ( https://bugs.eclipse.org/bugs/show_bug.cgi?id=245891 ) . In the
comments it is pointed out (if I have well understood) that 'println' (as
opposed to 'debug') can be called safely (from stack point of view).
Nevertheless I have performed more tests with my simple transformation :
when I put the content all my 'do' sections into comments, my transformation
works very well with both VM in interactive mode by using the configutation
dialog box.
My questions are therefore: why? Does "println" have actually no effect on
the stack size ? How can I keep a trace of applied rules and of some
information about the source/target element manipulated by the rules whitout
overflowing the EMF VM stack? Should I use the Regular VM at development
time (using println of logging) and then use the EMF VM (without println
when I need better performances) ?
but when I use my 'buil.xml' with my transformation without 'do' section,
the error is still the same when I try to use
<property name="atl.launcher" value="Regular VM (with debugger)"/>
When I don't use this property (= I use the EMF-VM) it works
My 2nd question of my previous post remains the same: what is wrong in my
'build.xml' file and/or my transformation or in my way to do when I try to
use the Regular VM?
Many thanks in advance for any help.
jean-pierre
<jean-pierre.bourey@ec-lille.fr> a écrit dans le message de
news:hg0hh5$cbk$1@build.eclipse.org...
> Hi everybody
> rule Model2Model {
> name <-source.name,
> do {
> '>').println();
> rule Class2Class {
> from source : UML2!Class to target : UML2!Class (
> name <-source.name)
> do {
> '>').println();
> Java Stack:
> at
> org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperat ion.java:615)
> at
> org.eclipse.m2m.atl.engine.emfvm.ASMOperation.exec(ASMOperat ion.java:387)
> <project name="Class2ClassSimpleWithMoreThan100Classes" default="transfo"
> basedir=".">
> <property name="inputModel" value="My110Classes"/>
> <atl.loadModel modelHandler="UML2" name="UML2MM" metamodel="MOF"
> </target>
> <atl.loadModel name="sourceModel" metamodel="UML2MM"
> path="InputModels/${inputModel}.uml"/> <atl.launch
> <inModel name="IN" model="sourceModel"/>
> <inModel name="UML2" model="UML2MM"/>
> <outModel name="OUT" model="targetUmlModel" metamodel="UML2MM"
> modelHandler="UML2" path="OutputModels/${inputModel}_WithANT.uml"/>
> </atl.launch>
> path="OutputModels/${inputModel}_WithANT.uml"/> </target>
> </project>
> of the 98th class :
> BUILD FAILED
> C:\__EC-Lille\workspaceEclipse351ATL301\Class2ClassWithProfi le\build.xml:22:
> 100
> Buildfile:
> loadMetaModels:
> transfo:
> file:/C:\__EC-Lille\workspaceEclipse351ATL301\Class2ClassWit hProfile\InputModels\My110Classes.uml
> C:\__EC-Lille\workspaceEclipse351ATL301\Class2ClassWithProfi le\Transformations\Class2ClassSimple.asm
> BUILD FAILED
> C:\__EC-Lille\workspaceEclipse351ATL301\Class2ClassWithProfi le\build.xml:23:
> null
> best regards
> jean-pierre
Re: [ATL] Problems with EMF-Specific VM and Regular VM [message #503966 is a reply to message #503412] Wed, 16 December 2009 11:04 Go to previous messageGo to next message
Alfons Laarman is currently offline Alfons LaarmanFriend
Member
Hi Jean-Pierre,
Some ideas below.
On 12/13/09 6:54 PM, in article hg39p6$2m7$1@build.eclipse.org, "Jean-Pierre
Bourey" <jean-pierre.bourey@ec-lille.fr> wrote:
> Hi everybody,
> dialog box.
This is related to your next question.
Println uses and is an expression. After an expression exactly one value is
on the stack, so the interpreter can keep track of this and pop it off if
not needed. The operations in the do block are an entirely different thing,
they may or may not leave a value on the stack (remember you can use
expressions as operations, in this case a value is left on the stack while a
for loop doesnt leave a value). The interpreter cannot thus not know what
unused values are on the stack and can only pop complete stack frames.
If you keep this in mind, you might be able to reduce your stacksize a bit.
If not I advise you to enlarge the maximum stack value in the EMFVM code and
export a new plugin. This worked pretty well for me, no resource problems or
anything.
I would advice against that, since there still exist differences between the
two. Switching between them cost me allot of pain some time ago.
> use the Regular VM?
Can't help you there.
> jean-pierre
Good luck.
Alfons
Re: [ATL] Problems with EMF-Specific VM and Regular VM [message #545589 is a reply to message #503385] Thu, 08 July 2010 10:43 Go to previous messageGo to next message
No real name is currently offline No real nameFriend
I have the same problem. I am working with a transformation that creates more than 100 elements and I have the same error.
Unfortunately, I don't know how to enlarge the maximum stack value. Have you enlarged it?
How have you solved your problem?
Thanks!
Re: [ATL] Problems with EMF-Specific VM and Regular VM [message #545602 is a reply to message #503385] Thu, 08 July 2010 11:48 Go to previous messageGo to next message
Sylvain EVEILLARD is currently offline Sylvain EVEILLARDFriend
This isn't related to the number of elements created.
The solution is to "consume" the stack by using for example a fake variable :
fake <- let s : String = 'RULE:Model2Model => END' in s.println();
That way the result is deleted from the stack.
Re: [ATL] Problems with EMF-Specific VM and Regular VM [message #757664 is a reply to message #545602] Mon, 21 November 2011 08:25 Go to previous message
Ronan B is currently offline Ronan BFriend
I had assumed this bug had been fixed in the ATL VM. However, it still shows up in ATL version 3.2.1. The work around works just fine but it is quite a difficult bug to diagnose in the first place. Is the fix for this in ATL 3.3? I cannot upgrade just yet due to dependencies.
Ronan
Previous Topic:[ATL] Launch UML2OWL on Helios
Next Topic:Incorrect output HOT
Current Time: Mon Jan 20 03:06:26 GMT 2020
Powered by FUDForum. Page generated in 0.02501 seconds
