Home » Language IDEs » Java Development Tools (JDT) » [ASK] J2ME cannot create jar
[ASK] J2ME cannot create jar [message #503050] Thu, 10 December 2009 11:48 Go to next message
newb here Sad
this is really desperating
been trying fixing this for days and no hope Sad
i just tried to make a simple midlet program, it's succesfully running on emulator WTK but i can not make the executeable jar
all i tried to do:
1. export
2. JAR file
3. mark my resources (which is .classpath, .eclipseme, .project, messenger.jad)
4.specify jar file export destination
5. next next
6. at manifest option page at Main class selection, there's blank page,, cannot choose any class
here's the screen shoot
http://i537.photobucket.com/albums/ff334/makinan/mainClassEmpty.jpg
EDIT:
ok i tried to right click on the package|J2ME|create package
and then it automatically create new folder "deployed" which contains 2 files .jad and .jar
tried to run but still error
http://i537.photobucket.com/albums/ff334/makinan/Untitled-1.jpg
i've added MIDlet-1 line in .jad, it works an emulator but still error when i try to run on my cellphone
[Updated on: Thu, 10 December 2009 13:04] by Moderator
Re: [ASK] J2ME cannot create jar [message #503102 is a reply to message #503050] Thu, 10 December 2009 11:04 Go to previous messageGo to next message
acids wrote:
> newb here :(
> been trying fixing this for days and no hope :(
> all i did is:
> 1. export
> 2. JAR file
> messenger.jad)
> 5. next next
> best regards,
> Ricky Lie
Attachments don't really work in this newsgroup, so I can't see your screen shot.
But from your step 3, it doesn't sound like you included any classes? It
shouldn't be a surprise that you can't select a main class if you don't have any
classes...
Re: [ASK] J2ME cannot create jar [message #503138 is a reply to message #503102] Thu, 10 December 2009 18:51 Go to previous messageGo to next message
Walter Harley wrote on Thu, 10 December 2009 11:04
acids wrote:
> newb here Sad
> all i did is:
> 1. export
> 2. JAR file
> messenger.jad)
> 5. next next
> best regards,
> Ricky Lie
classes...
i chose everything that appears on that page..
how to include this classes to my jar?
Re: [ASK] J2ME cannot create jar [message #503200 is a reply to message #503138] Fri, 11 December 2009 06:06 Go to previous messageGo to next message
hi, i've re-checked the folders and found my Main.class
it's located in,
helloWorld/.eclipse.tmp/verified/classes/helloWorld/Main.cla ss
i've added that Main.class to that step 3 but at the last page i still cannot choose any class
i also tried to copy my Main.class from bin folder but still not work..
is it maybe a bug?
Re: [ASK] J2ME cannot create jar [message #503630 is a reply to message #503200] Mon, 14 December 2009 22:53 Go to previous message
> it's located in,
> is it maybe a bug?
It would be quite surprising if there were a bug that severe (i.e., "can't
export jar files containing classes) in a released, or even a milestone,
version. I strongly suspect that it is either a configuration problem or a
problem of taking a wrong step somewhere. Unfortunately it's often hard to
debug these things over a newsgroup :-(
The path you mention sounds like a red herring to me; that sounds like some
verifier's local cache. The bin directory is the "real" location of your class
files.
Do you have the "export generated class files and resources" checkbox checked,
in the export wizard?
Previous Topic:Using the Eclipse Abtract Syntax Tree not as a plugin
Next Topic:Ant target fails in eclipse, not via command line
Current Time: Tue Apr 22 16:51:59 EDT 2025
Powered by FUDForum. Page generated in 0.03212 seconds
