Home » Eclipse Projects » Eclipse Platform » IExtensionRegistry.getExtensionPoint(..) returns null in standalon runtime
IExtensionRegistry.getExtensionPoint(..) returns null in standalon runtime [message #502948] |
Thu, 10 December 2009 11:51 |
I have a problem that IExtensionRegistry.getExtensionPoint(..) returns
null in a standalone runtime, but it works from within a self-hosted
runtime (e.g. in a Run As-Runtime).
This is the set up:
A plugin "..graphics3d" defines an extension point:
<extension-point id="org.eclipse.draw3d.graphics3d"
name="org.eclipse.draw3d.graphics3d"
schema="src/schema/graphics3d.exsd"/>
Another plugin "..lwjgl" defines that extension:
<extension point="org.eclipse.draw3d.graphics3d">
</extension>
In the first plugin "..graphics3d", I try to find all extensions of
that extension point -- and there should be at least one! This is how I
try to locate the extensions, this code can be found in the
"..graphics3d" plugin which defines the extension point:
IExtensionRegistry registry = Platform.getExtensionRegistry();
IExtensionPoint point =
registry.getExtensionPoint("org.eclipse.draw3d.graphics3d");
if (point == null) {
log.severe("Extension point 'org.eclipse.draw3d.graphics3d' not
found"); //$NON-NLS-1$
return;
IExtension[] extensions = point.getExtensions();
When I run Eclipse self-hosted, i.e. "Run As..", in order to test and
debug it, everything is working (i.e. the point is not null). However,
when installing all my plugins in a standalone runtime, it does not
work (i.e. the point is null). According to the console, the extension
point is not found:
... [0x0-0x33033].org.eclipse.eclipse SEVERE: Extension point
'org.eclipse.draw3d.graphics3d' not found
All plugins are installed and listed in the installation details of the
about dialog.
Actually, this problem is reported in a bug report
https://bugs.eclipse.org/297428 and I want to fix it -- but I do not
know why the extension point is not found. Maybe I missed something in
my manifest files? Here are my manifest files:
"..graphics3d":
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Graphical Editing Framework 3D, Graphics3D
Bundle-SymbolicName: org.eclipse.draw3d.graphics3d;singleton:=true
Bundle-Version: 0.8.1
Bundle-Vendor: Eclipse.org
Bundle-RequiredExecutionEnvironment: J2SE-1.5
Require-Bundle: org.eclipse.draw2d;bundle-version>="3.4.0",
org.eclipse.draw3d.geometry;bundle-version>="0.8.0",
org.eclipse.core.runtime;bundle-version>="3.4.0"
Export-Package: org.eclipse.draw3d.graphics3d
Bundle-ActivationPolicy: lazy
"..lwjgl":
Bundle-Name: Graphics3D implementation using LWJGL Plug-in
Bundle-SymbolicName: org.eclipse.draw3d.lwjgl;singleton:=true
Bundle-Activator: org.eclipse.draw3d.lwjgl.Activator
Require-Bundle: org.eclipse.ui,
org.eclipse.core.runtime,
org.lwjgl;bundle-version>="2.0.0",
org.eclipse.draw3d.graphics3d;bundle-version>="0.8.0",
org.eclipse.draw3d;bundle-version>="0.8.1"
Export-Package: org.eclipse.draw3d.graphics3d.lwjgl,
org.eclipse.draw3d.graphics3d.lwjgl.font,
org.eclipse.draw3d.graphics3d.lwjgl.graphics,
org.eclipse.draw3d.graphics3d.lwjgl.offscreen,
org.eclipse.draw3d.graphics3d.lwjgl.util
I have already played around with the Bundle-ActivationPolicy and the
versions, but this had no effect. Do you have any ideas?
Cheers
Jens
Re: IExtensionRegistry.getExtensionPoint(..) returns null in standalon runtime [message #502949 is a reply to message #502948] |
Thu, 10 December 2009 11:54 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Is it possible that you forgot to add it to the build.properties?
Tom
Am 10.12.09 12:51, schrieb Jens v.P.:
> This is the set up:
> name="org.eclipse.draw3d.graphics3d" schema="src/schema/graphics3d.exsd"/>
> </extension>
> In the first plugin "..graphics3d", I try to find all extensions of that
> extension point -- and there should be at least one! This is how I try
> to locate the extensions, this code can be found in the "..graphics3d"
> not found"); //$NON-NLS-1$
> return;
> when installing all my plugins in a standalone runtime, it does not work
> (i.e. the point is null). According to the console, the extension point
> is not found:
> about dialog.
> "..graphics3d":
> "..lwjgl":
> Cheers
> Jens
Re: IExtensionRegistry.getExtensionPoint(..) returns null in standalon runtime [message #503243 is a reply to message #503068] |
Fri, 11 December 2009 10:02 |
Tom, Miles,
thanks for your help. Indeed I forgot the plugin.xml in the
build.properties, and Miles even provided a bugfix. Fixed bug
https://bugs.eclipse.org/297428 thanks to you!
On 2009-12-10 19:38:24 +0100, Miles Parker <milesparker@gmail.com> said:
> This is just another reason to try to get self-hosting / local build
> and PDE build aligned. :)
Yes, you're absolutely right. However I want to wait until JOGL is IP
approved, as I do want to create self-contained releases and builds.
(Besides I have almost no time at the moment for that, since I have to
spend all my time working on my thesis... I will do that as soon as the
thesis is submitted, promised ;-) ).
Cheers
Jens
Re: IExtensionRegistry.getExtensionPoint(..) returns null in standalon runtime [message #503320 is a reply to message #503243] |
Fri, 11 December 2009 15:12 |
Miles Parker Messages: 1341 Registered: July 2009 |
Happy to do it. Goodness knows I've spent enough time dorking around with plugin packaging issues to know what can go wrong..
Quote: | On 2009-12-10 19:38:24 +0100, Miles Parker <milesparker@gmail.com> said:
Quote: | Yes, you're absolutely right.... I will do that as soon as the
thesis is submitted, promised ).
Cheers
Jens
Actually I was talking about getting the <i>PDE and Local build process<i> itself aligned. That's a much bigger can of worms. The basic issue is that there are a lot of things that the self-hosting environment ignores that PDE Build and the platform runtime don't. And OTOH, there are situations where things don't work properly under self-hosting but do work under runtime. Actually it's not really the fault of PDE build per se, since they are following build packaging as defined by developer, but that is much more stringent than what the self-hosting environment requires so you end up with this big potential mis-match between what happens on development environment and otherwise. Actually, you really have three (!) seperate scenarios, because building plugins and features using wizards and installing them locally also has differences!
But this is all as I say a much bigger issue -- one I think the B3 team and others are tackling.
[Updated on: Fri, 11 December 2009 15:12] Report message to a moderator
Current Time: Wed Apr 24 23:31:07 GMT 2024
Powered by FUDForum. Page generated in 0.03880 seconds
