Home » Eclipse Projects » Platform - User Assistance (UA) » Product Name on window/tab
Product Name on window/tab [message #502369] Mon, 07 December 2009 16:12 Go to next message
Hi -
I'm running into an issue with something that should be simple - which probably means I'm missing something obvious...
I'm trying to get my help product name to appear on the title bar/tab label of a browser window.
I have the following settings:
in config.ini:
eclipse.product=com.myproduct.docs.helpProduct
in plugin.xml for com.myproduct.docs:
<extension point="org.eclipse.core.runtime.products" id="com.myproduct.docs">
<product name="%productName" application=""/>
</extension>
in plugin.properties for com.myproduct.docs:
name=My System Help
providerName=MY_company
productName=My System
in MANIFEST.MF:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Localization: plugin
Bundle-Name: %name
Bundle-Vendor: %providerName
Eclipse-LazyStart: true
Bundle-SymbolicName: com.myproduct.docs; singleton:=true
Bundle-Version: 1.0
starting either standalone help or infocenter mode, with -plugincustomization plugins\com.myproduct.docs\plugin_customization.ini or without, and with org.eclipse.help.base/windowTitlePrefix=true or =false, I get the same result.
With true, window/tab title is "Help - "
With false, window/tab title is the url of help/index.jsp.
Other customizations (banner, help home, etc.) work fine.
In the log file, I find the following:
!ENTRY org.eclipse.equinox.app 0 0 2009-12-07 14:54:35.184
!MESSAGE Product com.myproduct.docs could not be found.
What am I missing?
Thanks for the help...
Rob Kimm
Re: Product Name on window/tab [message #502493 is a reply to message #502369] Tue, 08 December 2009 09:26 Go to previous messageGo to next message
Hi Rob,
One thing I see is that the id in the <extension> element should be the
ultimate portion of the eclipse.product; that is, it should be your
"helpProduct" portion. For example:
<extension point="org.eclipse.core.runtime.products" id="helpProduct">
</extension>
Then, windowTitlePrefix should be set to "false" to pick up your title.
While I don't know if anything else is amiss, certainly the
<extension>'s id should be helpProduct given what is in your config.ini
file.
Best,
Lee Anne
http://www.linkedin.com/in/leeannekowalski
Rob Kimm wrote:
> Hi -
> in config.ini:
> </extension>
> name=My System Help
> in MANIFEST.MF:
> Bundle-Name: %name
> Bundle-Version: 1.0
> With true, window/tab title is "Help - " With false, window/tab title is
> What am I missing?
> Rob Kimm
Re: Product Name on window/tab [message #642754 is a reply to message #502493] Thu, 02 December 2010 10:42 Go to previous messageGo to next message
Bumping this question.
Having the exact same problem. Tried Lee Anne's suggestion but with no luck. Sad
Anyone willing to work me through it?
Re: Product Name on window/tab [message #643421 is a reply to message #642754] Mon, 06 December 2010 14:23 Go to previous message
I sometimes get this error message when the plugin that actually contains my product definition cannot be found or started. You can enable the osgi prompt by adding -console to your eclipse run arguments. When the app starts up you will get an osgi prompt. Type ss <plugin id> to see if your plugin is found, and type start <plugin number found in ss> to try and start it - you will see an exception if it fails.
Example:
osgi> ss org.eclipse.help.base
Framework is launched.
id	State       Bundle
7	RESOLVED    org.eclipse.help.base.nl2_3.5.2.v201009231809
	            Master=207
44	RESOLVED    org.eclipse.help.base.nl1_3.5.2.v201009231809
	            Master=207
50	RESOLVED    org.eclipse.help.base.nl2a_3.5.2.v201009231809
	            Master=207
207	ACTIVE      org.eclipse.help.base_3.5.2.v201009090800
	            Fragments=7, 44, 50, 209
209	RESOLVED    org.eclipse.help.base.nlBidi_3.5.2.v201009231809
	            Master=207
osgi> start 207
osgi>
Previous Topic:how to update recursively using CVS?
Next Topic:Jetty IO exceptions accessing help
Current Time: Sat Jun 21 00:20:27 EDT 2025
Powered by FUDForum. Page generated in 0.04113 seconds
