Home » Modeling » GMF (Graphical Modeling Framework) » CreateViewAndElementRequest wont create anything
Re: CreateViewAndElementRequest wont create anything [message #502338 is a reply to message #502294] |
Mon, 07 December 2009 17:59 |
Ugo Sangiorgi Messages: 44 Registered: July 2009 |
Member |
Still nothing.
First, i create a CreateElementRequestAdapter (Sketch is my model element):
CreateElementRequestAdapter elementReqAdapter = new CreateElementRequestAdapter(new CreateElementRequest(type));
Sketch sketch = MolicFactory.eINSTANCE.createSketch();
sketch.eSet(MolicPackage.Literals.SKETCH__IMAGE, "what i want to be able to set");
elementReqAdapter.setNewElement(sketch);
If i do this, a node is created, without the model element i've passed:
ViewAndElementDescriptor viewDescriptor = new ViewAndElementDescriptor(
new CreateElementRequestAdapter(new CreateElementRequest(type)),elementReqAdapter,
Node.class, ((IHintedType) type).getSemanticHint(), preferencesHint);
If i do this, then nothing happens:
elementReqAdapter,
preferencesHint);
Either way, im lost =(
Does anybody have a clue?
Ugo Sangiorgi escreveu:
> Hello,
> I have a DragDropEditPolicy and i want to create a command inside
> getDropObjectsCommand to add a node into a compartment.
> But i want to set some parameters of my model before inserting it (i
> mean, to create the EObject, set the properties, and then create the
> EditPart)
> I have a getCreateElementAndViewCommand took from GMF itself, but this
> doesnt seems to work:
> CreateViewAndElementRequest req = new
> CreateViewAndElementRequest(MolicElementTypes.Sketch_3001,ed itor.getDiagramEditPart().getDiagramPreferencesHint());
> this.getCreateCommand(req); //this have canExecute() = false
> Does anybody have a clue on how can i do that?
> thanks
Re: CreateViewAndElementRequest wont create anything [message #502388 is a reply to message #502346] |
Mon, 07 December 2009 22:48 |
Member |
Thank you Artur, i've tried that and although the editor gets to dirty, nothing appears.
i did:
CreateViewRequest.ViewDescriptor viewDescriptor = new CreateViewRequest.ViewDescriptor(
new EObjectAdapter(sketch), Node.class, ((IHintedType)MolicElementTypes.Sketch_3001).getSemanticHint (), true,
editor.getDiagramEditPart().getDiagramPreferencesHint());
viewDescriptor.setPersisted(true);
CreateViewRequest createRequest = new CreateViewRequest(viewDescriptor);
SetRequest reqSet = new SetRequest(
editor.getEditingDomain(),
(EObject)getHost().getParent().getModel(),
MolicPackage.eINSTANCE.getScene_Sketch(),
list);
SetValueCommand cmd= new SetValueCommand(reqSet);
command.add(getHost().getCommand(createRequest));
command.add(new ICommandProxy(cmd));
The idea you suggested is to chain the SetCommand on command? (its a CompoundCommand)
Maybe my SetRequest is wrong. My objects are inside a compartment (getHost()), but my containment is on getHost().getParent(), and 'list' is a list of EObjects, right?
thank you for answering this, im being facing this issue for a long time.
Artur Kronenberg escreveu:
> I had the same problem. I needed to create a view but have a modified
> eObject before. So I also ran into the problem that either nothing
> happened or I got an element that wasn't modified since my eObject was
> ignored completely.
> This is how I solved that (and I think it is not the best way, but it
> works):
> I use two different commands to create my view and eObject and then set
> the object on the parent:
> I use a CreateViewRequest and pass it a CreateViewRequest.ViewDescriptor.
> In the viewdescriptor I add my eObject as first argument:
> new EObjectAdapter(myEobject),
> Node.class, ((IHintedType) ElementTypes
> .getElementType(ElementEditPart.VISUAL_ID)).getSemanticHint( ), true,
> diagramEditPart.getDiagramPreferencesHint());
> This way the passed eObject is created as a view. It will appear on the
> diagram the way you want it to be. Since you are in the DND policy, you
> might wanna set the location on the createViewRequest. You get that one
> by calling the getCommand on the host.
> Now you have the view but it is not added to your parent editPart. You
> need to create a SetCommand with a SetRequest to set the new children on
> the parenteditpart.
> If you wrap both of them into a CompoundCommand you can return it and
> the editPolicy will execute it right. The CompoundCommand will undo
> everything when an error occures so you won't have to worry about what
> happens if you can set a value but not create the view.
> Hope that helps you.
> Artur
Re: CreateViewAndElementRequest wont create anything [message #502532 is a reply to message #502504] |
Tue, 08 December 2009 17:29 |
Member |
--------------070406060309090300090602
Hi Artur,
I saw another suggestion you made on other thread about doing an AbstractEMFOperation. I did, wrapped inside a Command, and now it works.
See attached. I put together the Nebula Gallery view, displaying pictures inside a folder (at the right), you can drag them and create nodes with that picture.
Its at google code, if somebody is interested --> http://code.google.com/p/molic-designer/
here is how i did the AbstractEMFOperation:
Command c = new Command(){
public void execute() {
AbstractEMFOperation emfOp = new AbstractEMFOperation(editor.getEditingDomain(), "Location setting") {
protected IStatus doExecute(IProgressMonitor monitor, IAdaptable info) throws ExecutionException {
NodeImpl n = (NodeImpl)getHost().getParent().getModel();
Scene s = (Scene) n.basicGetElement();
s.getSketch().add(sketch);
return Status.OK_STATUS;
try {
OperationHistoryFactory.getOperationHistory().execute(emfOp, null, null);
} catch (ExecutionException e) {}
Then i add it before the command that creates the view:
command.add(c);
In fact im getting an ExecutionException claiming that "this is a read-only context", but my node is persisted fine.
thank you so much, Artur!!
> your SetRequest seems to be right I think.
> How big is the diagram you are dropping on? You didn't set the Location
> on your ViewCommand what could mean that your element is appearing
> somewhere in the diagram you can't see it?
> Best regards,
> Artur
Content-Type: image/jpeg;
name="molic_designer-rich.jpg"
Content-Disposition: inline;
filename="molic_designer-rich.jpg"
/9j/4AAQSkZJRgABAQEASABIAAD//gATQ3JlYXRlZCB3aXRoIEdJTVD/2wBD AAIBAQEBAQIB
AQECAgICAgQDAgICAgUEBAMEBgUGBgYFBgYGBwkIBgcJBwYGCAsICQoKCgoK BggLDAsKDAkK
Cgr/2wBDAQICAgICAgUDAwUKBwYHCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoK CgoKCgoKCgoK
CgoKCgoKCgoKCgoKCgoKCgr/wAARCAKJA5wDASIAAhEBAxEB/8QAHgABAAID AAMBAQAAAAAA
AAAAAAcIBQYJAwQKAgH/xACIEAAABQIDAgMLDxQKCwsJBAsBAgMEBQAGBwgR EhMJFCEVFhgi
MVFXltPU1RcZNkFSVVZYdpGUlZe0tgojMjU3OFRZYXR3eIGTmKGytdHSGjNC U2JxgoSS5CQ0
OXN1hqOks8HWJSZHZWhyprG3xeJDREVGZKXCxPAnZoWiw8bxKGOHSIOZp+H/ xAAbAQEAAwEB
AQEAAAAAAAAAAAAAAQIDBAUGB//EAEgRAAEDAgMEBwYCCAQFAwUAAAEAAhED IRIxUQQTQWEi
MnGBkaHwBRQzscHRQlIGFSNDYpKi8XKC0uEHFlNUsjSTwkRjg7Pj/9oADAMB AAIRAxEAPwCZ
uGF4UW/8I7/Xy94LTp49Vm2KW4H7NQyTk6yyIn4sVQyeqRCIqN1DKImKqYXB ATVRMioB6f4I
YucJXmYCSVwBtbEe8CxApBKKwNz3G4K1FTa3YKGK/wBCibYPoA8o7I9asBwy ksr44PfbExuQ
irBQNR8s0a0D/wCAKvJ8S64b25iJh5jC8nZO4UDNpqHImEJd0jGlEBRdCO0V oukBx6wmARDy
q52NBWriQq7nw24bMhROOXHGXQA1HSXuUR9YH/LUCOM/+Z5oudq6xAuNJVI4 kUTUvqfKYhgH
QQEBkNQEB8qvpY6HLD70Q357qc/37Xye4krlaYiz7RNQwlSmnRCiooJzaAsY OUxhERH6ojqN
Wc0NUBxKmfxwfMv2R7h7fJ/whXqDnmx4GbTuUbrleaSTZRulIc+c5vyIqGIZ RMFOP7QFMZJM
RLroIpkEfkQ0v1wK2IGFtp8FliZC43tCK2jeeLjW0bgWOcC8VQlGrVlxjaHk LuzrEOI+UBRH
qgFSJjVhrYWAnBK428HPZE6ydSGGKVoJXpc6ACVN1Ny8wi4XEddOkTRBsUBH QdnpR+Rq76Dw
5wZeMAHNzgwkcg0VGdLIlwGsUo1RVwzaSZ5AOc0HmSWutwAJnKeZnjg+Zfsj 3D2+T/hCnjg+
Zfsj3D2+T/hCr4XnwbnB+O8cMUODttjL7csPdmHGD/PU2xxeXo6U5oOyoIq6 KsTBxUjcTLAU
TEAB+NqFDZENoIO4XhdY2RjJMoltCU2EjoRANdP2uO0rne8NAIvLgAeBBFW+ udIiCBr26MxO
cAbdEnmI3ZjS4qAyCdOyAPHB8y/ZHuHt8n/CFPHB8y/ZHuHt8n/CFXPwpsaw 8WOCfyeYa4pO
AJbdwZnxYTYGWFMFG6i8gU6YmAQ2QNrs6+VrrWpcKln4zw4V5kcTciFiWbD2 zhPHxq8XC4fM
cPWRmx4kWnyxIpuBWKbZEyoKJnKRMShydKNaVgaT3MzIJA0MMpvM6fEAFjkT ZVoONZuPIcde
u9ggceoScokC5VXfHB8y/ZHuHt8n/CFPHB8y/ZHuHt8n/CFbdwHTsVOFPwjI Jtf91nn5vc1e
q38a8XM/6GcfBrOva8ZcOHuGDC43Nj3s9tlu1Wtx4zcuCtUEXSKZNsd2ntDq InEEhAxjFOID
FYbqkHi5wvfpanhm+pxWFgTackpONXaN3ldje95cBbQYbmeOS5z+OD5l+yPc Pb5P+EK/DjP7
mOdp7p1f86qXXXZUvmeMGv3ZCr4wPBycFnhBhLhbZOZm6LVZSuI+HDedf33L YlyjOcbO3aW0
iEbFoNTsXKBFBAmqygHHUR2R0AD6Jkyyg8H/AI1Ze7fs3DewbDxYxkdOJglx 2/deM0nasspu
VlQbDDtkkTN3ZBQJvhMpyBoO0b5ICXrU30Xvablk5XkgkEDsIvMC4uopvFRj X5B0Z2gESCeR
GknUBVmeZq87VsWDG4nP0L6jrWmnKiERcK1xXIjHv1kxEFCIri9BNU5RKIGA phENkdepWF8c
HzL9ke4e3yf8IVZuEyj2njBkfye4e3XPXFFOr6xvlbenyrXY/XaskuOrpnBs yWWM0braAJd4
mkUxjDqYTajrumMGUfg75vCHN+TC/JnOWlP5e0UIuDn5K+5J4jIOAVVIZ6CJ zFKmofdibdmM
qmJDJmKUgiOtK37JtV9iGSbZkNbTcTp+8aB26Ala02uqOYzIuIF9S97ANfwE m3DWAqYeOD5l
+yPcPb5P+EK/inCB5k1SCkriHPmKYNDFNfc8ICHthV8cHckPBpP7mysYEXxl Sk5S4cecJ1JS
bulviBItiRzpNjv+NJtwOYqipzgYNnUiJAAB3ZupWNwd4OTg5MDMtlkYlZtp K05RS+7smWMh
PXniVKQRopmyeqtdI1Bg2VTduQKQFDEcnIXa6UB0ERLo+k5jiDFiWzwLmuLS B3jMwI4rJj94
0ETcNdHEBzS4HwHCTPDiqL9HXj76L5ft0nO/69ovCCZlSFAhMRbgAoBoABfc 9oAe2FWitTLL
wb2BWTbGvMpiHg+/xjb2BjnzuWY7a3k9hxlo85GwopLnR6UhQBU5znKjvBMX QolAeTnVdFwR
Exc8lL27b5YeOdSCy0fEldnXBkgZQwpob04AZTYKIF2x5Taaj1awDwXAAcAT bLE1rgDzhwym
IM8J1wkNJJ4kduFzmkjlLe+RHGJz8cHzL9ke4e3yf8IU8cHzL9ke4e3yf8IV X3j4+aCnHx80
FWVZKsF44PmX7I9w9vk/4Qp44PmX7I9w9vk/4QqvvHx80FOPj5oKJJVgvHB8 y/ZHuHt8n/CF
eBfPnmEdKCs5vaZUOPVOe9p0RH7ov6gTj4+aCnHx80FEkqeOjrx99F8v26Tn f9Ojrx99F8v2
6Tnf9QPx8fNBTj4+aCiSVPHR14++i+X7dJzv+nR14++i+X7dJzv+oH4+Pmgp x8fNBRJKnjo6
8ffRfL9uk53/AE6OvH30Xy/bpOd/1A/Hx80FOPj5oKJJU8dHXj76L5ft0nO/ 6/aGfPMI1UBZ
te0ymcOodO9p0B9cH9QJx8fNBTj4+aCiSVYLxwfMv2R7h7fJ/wAIVjnOdbGl 5PDdLudfqyYt
iNxkVLumzLiiQxzET3gvtrZKZRQQLroAnMIfJDUHcfHzQU4+PmgoklWCLwgu ZUoAUuItwAAd
QAvue8IU8cHzL9ke4e3yf8IVX3j4+aCnHx80FEkqwXjg+Zfsj3D2+T/hCnjg +Zfsj3D2+T/h
Cq+8fHzQU4+PmgoklWC8cHzL9ke4e3yf8IU8cHzL9ke4e3yf8IVX3j4+aCnH x80FEkqwXjg+
Zfsj3D2+T/hCnjg+Zfsj3D2+T/hCq+8fHzQU4+PmgoklWC8cHzL9ke4e3yf8 IU8cHzL9ke4e
3yf8IVX3j4+aCnHx80FEkqwXjg+Zfsj3D2+T/hCnjg+Zfsj3D2+T/hCq+8fH zQU4+PmgoklW
C8cHzL9ke4e3yf8ACFPHB8y/ZHuHt8n/AAhVfePj5oKcfHzQUSSp/cZ/cxzt IUHd/wA6qQeq
RS+Z4wD9wZCsI6zY4jPrP8Tx8Uy0Bvmq3MNW5JgzPeNhRFsfci92NpIW7cUx 01IKCezpsF0h
vj4+aCnHx80FEkqUS4/S5DioS0o4DG+SMErKaj/nlfrohJz0LsPbeU78qLOP j5oKcfHzQVN1
CmWzs2uJWHck+mcPxPBPJNBBGSdw1yzDVV2miKpkSKmTfFFQpBWWEoGEQKKp xDTaHXYPHDsz
3ZNuPt+n/CFV64+Pmgpx8fNBS6SVYXxw7M92Tbj7fp/whTxw7M92Tbj7fp/w hVeuPj5oKcfH
zQUupkqwvjh2Z7sm3H2/T/hCnjh2Z7sm3H2/T/hCq9cfHzQU4+PmgpdJKsL4 4dme7Jtx9v0/
4Qp44dme7Jtx9v0/4QqvXHx80FOPj5oKXSSrC+OHZnuybcfb9P8AhCnjh2Z7 sm3H2/T/AIQq
vXHx80FOPj5oKXSSrC+OHZnuybcfb9P+EKeOHZnuybcfb9P+EKr1x8fNBTj4 +aCl0kqwvjh2
Z7sm3H2/T/hCnjh2Z7sm3H2/T/hCq9cfHzQU4+PmgpdJKsL44dme7Jtx9v0/ 4Qp44dme7Jtx
9v0/4QqvXHx80FOPj5oKXSSrC+OHZnuybcfb9P8AhCnjh2Z7sm3H2/T/AIQq vXHx80FOPj5o
KXSSrC+OHZnuybcfb9P+EKeOHZnuybcfb9P+EKr1x8fNBTj4+aCl0kqwvjh2 Z7sm3H2/T/hC
njh2Z7sm3H2/T/hCq9cfHzQU4+PmgpdJKsL44dme7Jtx9v0/4Qp44dme7Jtx 9v0/4QqvXHx8
0FOPj5oKXSSrC+OHZnuybcfb9P8AhCnjh2Z7sm3H2/T/AIQqvXHx80FOPj5o KXSSrC+OHZnu
ybcfb9P+EKeOHZnuybcfb9P+EKr1x8fNBTj4+aCl0kqwvjh2Z7sm3H2/T/hC v4ThC8zaZCpJ
4lXEUpCgUhS37PgBQANAAP8AdDkDSq98fHzQU4+PmgpdJKsL44dme7Jtx9v0 /wCEK8CmfvMY
q/JKq37OGdJoHRTcmvmeFQqZzEMYgG5oagUTJkEQ6giQoj1AqAePj5oKcfHz QUSSpzZ53ccI
4qhY+45JAFVjrKgjeE2XbUOYTHOOj/lMYwiYR6oiIiPVrzdHdmA9GMx26zvf 9QNx8fNBTj4+
aCogaJJU89HdmA9GMx26zvf9OjuzAejGY7dZ3v8AqBuPj5oKcfHzQUgJJU89 HdmA9GMx26zv
f9OjuzAejGY7dZ3v+oG4+Pmgpx8fNBSAklTz0d2YD0YzHbrO9/1+Vs82PDnd 8YuuVU3S6ayW
3ec4OwomcDpnDV/yGKcpTAPVASgIcoVBHHx80FOPj5oKQEkqcLbzqYz2dHpR NoTj6Kat0ypo
No27ptBNMhQ0ApSkfAAAAAAAAdSsl44PmX7I9w9vk/4QqvvHx80FOPj5oKJJ VgvHB8y/ZHuH
t8n/AAhTxwfMv2R7h7fJ/wAIVX3j4+aCnHx80FEkqwXjg+Zfsj3D2+T/AIQp 44PmX7I9w9vk
/wCEKr7x8fNBTj4+aCiSVYLxwfMv2R7h7fJ/whTxwfMv2R7h7fJ/whVfePj5 oKcfHzQUSSrB
eOD5l+yPcPb5P+EKeOD5l+yPcPb5P+EKr7x8fNBTj4+aCiSVYLxwfMv2R7h7 fJ/whX8NwhOZ
coa+KNcPb5P+EKr9x8fNBX5VfjsfJBRJKntThF8y6f8Awg3CP+P0/wB/166n CTZlyf8Ar5cI
/wD8wJ/v+o6wmhsMMQoyXsG6ptCBuNwmDi059/IFQYnWIUwmYujKGBNEioab C4iAEUKUDiBD
iYmGx4JhNakuxsbCyUGYUh2gpXBc5VxFCVfCbVQWpOoVsnyJpnENpXZMoOgH KQtoUSVLB+Ey
zLE/9eLhH/8AmDP9/wBeM3CcZlg/9drh90Kf7/qsi8obUenrbsEI3DCWuRzc ONFzC0tyDaC8
eRrNYCvZk4GAE2Lbq7JlDCAGVEBKkQDnHUQKUyEkqbPHOcy/o1uH3Qp/v6vY juErzLSC5kAv
q4SbKCqmvigT4/IJmPp/b/l7On3ahbGQMHZ224jFTCFVtCHkDGa3BYgu1VTx DtMoDvW51jHU
WaLF6YonMY6ZwOmcRDYOfSrdlTJv1BE4f2i5Dq9dA4VOFJKs0ThM8yx//Xi4 fdBn+/686fCU
ZllOpflw9v8AP9/1VlCROA8p6vPixbOAcVgRcNywLHDUuMJrIjxu+3GbgRaR bY5jlWcsSiQG
3HhTK2E5UziBRW1S1MPT1sM0krVbS4TfNDbk6hOssRbhTUQE2ycLvkXWmpRL +1P1nLc3V/8A
KIn06pdkwFMXrjkvz+jmAwNaXlKmbJyjV2oyl02pFCpb4pSHIoQFOUpVEVEV gJtHFPe7sxjG
IYa+fRpID1doK6W8ExNOXmXSaV2x5LyVJ1fMsGJQ/EFVcFYEqufDNvCG4R3E FJI2ophGFOHL
yDzNbD/1CFe7wbPC843cGbDXZA4WYb2vcDa7nLRw854SuNpA7cqpS7Aoqk5B BUdQEB+RDTTl
17YZOVtm98cy69TF5L4LwFbHj1nDwPy2XBAWlihIXIeWuhF2tBxVq2BM3A6c pNdzxhTdRTRw
dMhN+jqY4FDpw0EeWqiphICtgLrrmQPxV3nA0HZy34agOnII80O+K5fz1wvb inXtwPyEKu/d
qOFgSAQKBzmEw6AIjoGo19OMPnUwDl4BC5V5W5Ylq5fxbJItzYfTUQsLiRfH YM0xRes0lCmU
cJiXlKGwUxFD7KahDmlPjA9cPXqxe6LjIx32JHbBBjmNVUNE2Pr1K+W2EzS4 7W3l6m8qkHfQ
t7BuObRl5qACNam4y8S3e7V35khXJpuidKRQpR2eUB1HX82Vmix0w6wWvLLz Zl8mZWfiAuzW
u+JCObKjIHaqAqgIrKJGVS2TgA/Gzk16g6hyV9SnGB64evWo45Y9YZ5cMNH2 L2L825j4GOWb
IuXDGHdSCwquHCbdFNNu0SVXVOdZVMgFIQw6mDk0qpq9afxQDziAAdcmgdgj IKW0iC2OFxyN
ySNLknvK+eG7eFg4RC+sDFMt11Zpp53Z68aWOcsBbNCuXDQAEu4VelRB0qmJ REolOqIGKIgO
oDpWyYX8Nxwn+C+G8JhHhjmeNF27bsYlHw0aFlwi3F2yZQKQm8WZHUPoAAGp jCI+WNd58Es0
WGeYJzINMP4e+Wp4xNM7obwwun7dKYDiYC7o0sxbAuPSjqCYmEvJtabQa+2z zHYSyN6PsPo6
4nTiWi7jGBkkEIV4cjV+EcSS3SioI7sheKKJnBQTAmJjgmBhUHYqz6rpcXcR JniBaTqBiiTr
zVW02QAI6Nhym5A0sAe7kvmturOBmMvbAmEyz3PiSo5sm3bhWnIeGLGNExby Coqiovv00Srm
ERXVHZFQShtchQ0DSSbm4YLhKLywUeZebpzYTr+05CLPHP2btgxUcuWpyCQ6 Sj0yAujgYoiU
dVREQEQGvoiwxxRsvGPDuDxYw3muaNv3JFoSMK/4uojxhssQDpqbCpSnJqUw DsmKBg15QAaz
vGB64evUOcQHMcM8xrAi45AAX4CFYNOIPBuJg9pk35kydTdfK5gZj1irlsxU iMbMFLo5iXPA
qnViZTiSDncHOmZMw7twQ6ZtSHMHTFEOXXq6VK+ZHhXuELzcWIphhmAzNy81 by5ymdw7SNYx
qDrZMBigsVigjvigYAMBVNoNQAdNQCu6iXCZ5OzXyvYLq/59ms3utW2VpqSw 5nmsIWWTcC1O
05rLMSsBPvyikGi+hj6FKIiIAMx27fUDdUhMRkMq5MtBSXEJIHEeugUq+5SW 0TMqQpVibCxP
jiYmJrtF2topgAXuqUwCJbmNOFx4tvzGoUBgp1TFnZHXjY8eDrcjzXzmYUcL Rwh2CGF7DBvD
HMvJR9vRKB0Yhq4h494tHpmDQSN3Lluou3LpyAVM5QKHU0r8YU8K/wAIJgdh a1wZwpzFu4eA
Yt3CDBJKAjVXTQi5zqKgi7VbGcJbRznNqRQBATCIaV9JfGB64evTjA9cPXo6 s584rznz7dcy
jaQYAG2jLkvmCZZxcdpKxrBwWvLEyVUsnD66DTUCwi0Gzd4xcqriquuk7KkC 5lhExzFFRQwF
MICABpV2c3nDf4f4nZS75y9YY3ZjTfMviC0aRruZxdbwTJCDj0VNsxWyMQUo OV1A1IdZUCnM
AEER6QCj2k4wPXD16cYHrh69RUqb2iabhY3POwF+4AaxbKytTY6nVFRpuMuV y7/yJPbfNfM1
E8IznKg72w4xEi8YxSmMJIE0Nh4753443MhkZIUhS2BbiVfpBENpYFDeXrry 1l8GeFWz/wCX
+CkbYwpzFvWEdKzK8s5Yu4OOfIpvVjmUVXQI7bKFbGMcxjDuQIGoiOlfSdxg euHr1ruKOL1g
4MWqW9sSp/mbGHlWEaVzxVVbV09dpM2yeykQxunXXSJtabJdrUwlKAiFt64u 5me8uIJ/mdBO
pg5qu6AHIR4NBA/lBIGgkCy+aG5s6+aC88K7pwWuvFdzIW5et4jdV1MnUc0M pIy4iURdGXFL
fFHUodIQ5ScnyNRhxg/W/HX1WOcYLAZ4sM8D3E/s3S/t9xNtIviqo7xgguig qtvAJuw2VF0i
7ImAw7eoAIAIh5MRcV7HwmhmdwYgTnM9o/m2EQ0W4sqrtvHrlNq2S0TKYQ21 lUybQgBS7Wph
KACIUa4Q0tHWgDmQcAA1gjABqMPCFZzXXBOUk8p6RPfOI6zPFfKfxg/W/HTj B+t+OvrP4wPX
D16cYHrh69TvOSjAV8mHGD9b8dOMH6346+s/jA9cPXpxgeuHr03nJMBXyYcY P1vx04wfrfjr
6jMdc1uCmXBWIY4p3DJFkJ86xYSEt215GbknwIlKZY6TKNbruDppgYgnUBPY Jtl2hDaDXP4S
4yYc464fx+KWE91oTMFJlPxR8gQ5OmIcyaiZyKFKdJQihDkOmcpTkOQxTAAg IUDy4EgWCFkE
A8V8qnGD9b8dOMH6346+s/jA9cPXpxgeuHr03nJMBXyYcYP1vx04wfrfjr6s H2KtjxuJkbg8
9nNi45aFdy0fHcWUHes2qrdJdXeAXdl2TukA2TGAw7eoAIFMIZ/jA9cPXpjl oMWP0JB8CCO0
EJgMx61+S+TDjB+t+OnGD9b8dfWfxgeuHr04wPXD16bzkmAr5MOMH6346cYP 1vx19Z/GB64e
vTjA9cPXpvOSYCvkw4wfrfjpxg/W/HX1n8YHrh69OMD1w9em85JgK+TDjB+t +OnGD9b8dfWf
xgeuHr04wPXD16bzkmAr5MOMH6346cYP1vx19Z/GB64evTjA9cPXpvOSYCvk w4wfrfjpxg/W
/HX1n8YHrh69OMD1w9em85JgK+TDjB+t+OnGD9b8dfWfxgeuHr04wPXD16bz kmAr5MOMH634
6cYP1vx19Z/GB64evTjA9cPXpvOSYCvkw4wfrfjpxg/W/HX1n8YHrh69OMD1 w9em85JgK+TD
jB+t+OnGD9b8dfWfxgeuHr04wPXD16bzkmAr5MOMH6346cYP1vx19Z/GB64e vTjA9cPXpvOS
YCvkw4wfrfjpxg/W/HX1n8YHrh69OMD1w9em85JgK+TDjB+t+OnGD9b8dfWf xgeuHr04wPXD
16bzkmAr5MOMH6346cYP1vx19Z/GB64evTjA9cPXpvOSYCvkw4wfrfjpxg/W /HX1n8YHrh69
OMD1w9em85JgK+TDjB+t+OnGD9b8dfWfxgeuHr04wPXD16bzkmAr5MOMH634 6cYP1vx19Z/G
B64evTjA9cPXpvOSYCvkw4wfrfjpxg/W/HX1n8YHrh69OMD1w9em85JgK+TD jB+t+OnGD9b8
dfWfxgeuHr04wPXD16bzkmAr5MOMH6346cYP1vx19Z/GB64evTjA9cPXpvOS YCvkw4wfrfjp
xg/W/HX1n8YHrh69OMD1w9em85JgK+TDjB+t+OnGD9b8dfWfxgeuHr04wPXD 16bzkmAr5MOM
H6346cYP1vx19Z/GB64evTjA9cPXpvOSYCvkw4wfrfjpxg/W/HX1n8YHrh69 OMD1w9em85Jg
K+TDjB+t+OnGD9b8dfWfxgeuHr04wPXD16bzkmAr5MOMH6346cYP1vx19Z/G B64evTjA9cPX
pvOSYCvkw4wfrfjpxg/W/HX1n8YHrh69OMD1w9em85JgK+TDjB+t+OnGD9b8 dfWfxgeuHr04
wPXD16bzkmAr5MOMH6346cYP1vx19Z/GB64evTjA9cPXpvOSYCvkw4wfrfjp xg/W/HX1n8YH
rh69OMD1w9em85JgK+TDjB+t+OnGD9b8dfWfxgeuHr04wPXD16bzkmAr5MOM H6346cYP1vx1
9Z/GB64evTjA9cPXpvOSYCvkw4wfrfjpxg/W/HX1n8YHrh69OMD1w9em85Jg K+TDjB+t+OnG
D9b8dfWfxgeuHr04wPXD16bzkmAr5MOMH6346cYP1vx19Z/GB64evTjA9cPX pvOSYCvkw4wf
rfjpxg/W/HX1n8YHrh69OMD1w9em85JgK+TDjB+t+OnGD9b8dfWfxgeuHr04 wPXD16bzkmAr
5MOMH6346/h1lDhoAgH8YjX1ocYHrh69OMD1w9em85JgK+SVZk6W+Rctw/5x j/6i16qtuP1v
kZRgX/nHV/1J19cnGB64evTjA9cPXqd5yTAV8ih7Mk1B+XcWH8ai/ca/A2LJ iHy/ifvjjuFf
XdxgeuHr04wPXD16b3km7K+RDnDlPP8AifvrjuFeVrZkq1UFQs9EiIkMX9tc fuiiH7x9Wvrq
4wPXD16cYHrh69N6dE3ZXyLEs2QTHlm4wf4lF+415krcepfJSbEf+aor/rTr 64+MD1w9enGB
64evTe8kwFfJKixcoj0zpuP/ADTH/wBZQrpRwQJxUy1Tgj6OXPvNlXbLjA9c PXqgeKZ9vNpj
SP8A99474MQlMWJThIW68DrBQFo4S4m27bNtRcMxbYrm3EbDYcPbSbo7UBCm HZiXxzOGoiYw
mNvTCZUxjK8gKAFZjN/gtjHi5nbwXlML8TrzsRrE2fd5JS9bSgY95xUyp4nd NVTSLN02T3u7
UEoCQDm3JtkeQ1bNlQlCs8R8dkRZvVP/ALXkR2m8esqUP961v8mpCiAD9Tq1 n8X8rGULMJcq
F54+ZRbMviYasSsm0teGFyMm5SbFOdQqBVXLU5ypgdRQwEAdkDKGHTUw65F7 RVDtJ8wR9Vdr
Tu49ZquGNmB2NjXG+cTXb3hewkksHANdzy3kwUlOI3Q+Xerm4k3Sb6opHIor ukyFSIYpjAUB
1HQspOAWO8LnhhbqvyAkI+84/EG53193SzwQk2ikzDrcdBog8udeVFlJMzFU ZGQbINzqIGRT
LukATUNV98NrOwywastlhthBhS3tS3Y3eczoC27QOxZNd4oZVTdoIIlTJtKH Oc2yAamOYw8o
iNZzm8TzrlPaZz3OlKtu3SNXH+YMEaR0BaLzCPph7C08Q0fy4h2z0jBmQYKy +/DzVVx4WC37
wu7JDPxNhsLlcSSdy206INn2+eVk26aE8wWVcN2iaK5lzpJpnV2N0oAgmOpD BqFTvzeJ51yn
tM57nWqYv4T4G5hLaQszHzAeIviHavivW0TeFi802yTkpDplXKk5QOQqgEUU KBwDaAqhg10M
OtMQkGciD4EFXjX15FU5xMkLuxfwVd21J4iZj8ZLbZXrb8hiDa+IOAa9uLu7 dTcn423ZpIwU
YMmBjCios1LvzqJIGIUnTiU+v5c8vUe5xYTSw/ym3TbOGUjmOmH8db1y2O6Z NiQi+H4st6Zm
5TDirJRwJ0SJKFIUgnBESEMG7C5WEGVjKFl7uVe88A8otmWPMOmJmTmWs/C5 GMcqtjHIoZAy
rZqQ5kxOmmYSCOyJkyjpqUNJH5vE865T2mc9zqS5m7qMH4wQcuO7+W7EaFzj eREYXEtJOWXg
7z6Zk8QGi0GYb4Lu0UMN+D3wlsAuHTu0nMNZzdnK2+/t1WKWbSCYmK8E7dVN MwCdyCym82dF
tvelMcqgHNPe/DzVYjm8TzrlPaZz3OnN4nnXKe0znudWqVt7ULzmTPijWBoA GQXPmXnrxncp
uOGRaHy54ovL7xBxQvRpBKucL5dtCoISUy5O3lDy67YjEG6aahXAHKsYwgQA IUxhAK9nMLhd
ey0jels3zl5XuS2JvMWV88kLhwymbrjSNk7SYIou1YSNOmpLIHcpnRAxjGQR WLvD9MkGljPG
4uDT+lw4Q+4bH95VMdsNrXsi2o6zLMspaIh4hiiyiYmLttZu2ZNkiAmkgikm kBE0yEKUpSFA
ClKUAAAAKqHMAHE4Qw9jTTIjQ/s/E6ABCHF7jq57u9+Ke0dLwHMlcyLDsAGe FNg23nEy0YgX
Vb1uWDd8VbVsFw+fnWgJ4k4qZo7BmXeCxILAW6bWR2xbtSkMUHRNoDDlsB8A Zqay/r47Hy7z
d4TUTkxshjYae9eIb54qwlknqbNdASmF0CCyZTGQHfgRUCkMXehtXox4y1YD ZlHLF/i1Y1zO
HUczcskHsJITcQudm42OMNFVY9RA67ZTdpiduoJkjiQoiUdArfYI0HbEIztu 3bYeso+Paptm
LJrBOCJoIplApEyFBPQpSlAAAA6gBVt6HUKjXZuPdnVJJyud7H+EBsmJLCW1 WubkPpu4Azt+
zv8AxEnjA5kYdZeJ+Rh8QMH4PL/LtbKuO9sLZNjF2xgTNWXDOUEZwCSyqbB0 dVVI5UiJi5Oq
cipyE3pibvQ4ybg/knt/BvHW3L/w0y2uYB1D5ppdvGyMfbyyIRlorQjwdwgI FAG8SZ0cDAmT
ZbCscBANsQGr6c3iedcp7TOe505vE865T2mc9zq7NowVC8cf/wCX/wAaWHse 7WFm6iHUTT4f
dtQfOpi7Wt0WX34eaqvnCe2JfmKWUteycNCTYTDm/bQUburdjSO3jEiVxxyq rsiR0lSG3KZD
rCKiZ0ylTETgJQNU2c3iedcp7TOe51qmL+E+BuYS2kLMx8wHiL4h2r4r1tE3 hYvNNsk5KQ6Z
VypOUDkKoBFFCgcA2gKoYNdDDriHNxtOhB8CD9FoWmCNQfNU1zOZWc7EPi5e Diwsf8R8SZmT
y0XJGW/ck7b8SyCOfHko04MkFolmwTBwskRUSFUOCmpNSHIACYNPwWy+39HW 5LyGGWGctG2u
5xLwzVTtaCwBlrIjyOmc8ms/kE46QkHbk6hUBT4y73aSJwQIfbVEhzhdDDbJ jkdwavVliThB
kjw+tS4o3eczp+28I2rF613iZklN2ug0KoTaTOchtkQ1KcxR5BEKlXm8Tzrl PaZz3Or0q253
cfgIOkxVdVg8pdGuTplVq096HA/i/wBDWW4/hHKCRELmtkXsO2pjFDDm6cGc u94ROIMfjXeb
rEbEtxbLpCPf2zx6ZSBqeUOXcPUjKmZlSZEOc6KiInFNPZE5uoG/DzVaThnZ 1h4PWinYmHNo
SkdFJPXbtNrzPfLaLOnKrpc20qUxumWWUPproG1oAAAAAZ/m8TzrlPaZz3Oq h4bSbTHD7AW0
FpgWkkjOFJZNVz9fuTfU3idA0cJOX34eapvw81WI5vE865T2mc9zpzeJ51yn tM57nUYwrYVX
TPi3YRuLdiYhydlYuxvMyHlWrHFXBWOXmJSCWWO1MLBzEosnnGmrgEgPvDt1 iJqNSAJS7YGq
pmLuHGZzFSGsi68xWDIylklbXcmwYTOXCQuJy7fLSKR2Es/gYZ6zNHSbhsCp iuzFAqJzKCYG
p1uTp9zeJ51yntM57nTm8TzrlPaZz3OqtLQ0A3if6pkxqJ6JECQC5rnXUukm 1su23CdDx45g
FoMLljm5wTx9kLBi4G6MDriuW/LQwPtwlrXrIYQS9xzj2SQFVZyLJ40eqMbd fImITen213Do
TFAhltlMoylizlkVuWbxlzASeAN0zaE1jjb57iaEgHhpGbsYsbCHetWjQxQU XQMultOG6RBO
vxVRExTmKCdWnxJyY5HcZb1e4k4v5I8PrruKS3fNGfuTCNq+eut2mVJPeLrt DKH2UyEIXaEd
CkKUOQACpHthta9kW1HWZZllLREPEMUWUTExdtrN2zJskQE0kEUk0gImmQhS lKQoAUpSgAAA
BW52iau8tMk8pdUY8yOIOANIkSC7W2QpQ3DwgDnAYWCDwIklpvBg8FRO1snW BGOWL1usiZJL
ijcJGNkX4a3LWvi2XKTBBdd7Ci3MSOcJl5mlUMR0q2ZqkIonuzKkTIIBsXBy Rt7yism+FMXi
M0lG0+2w7hkppvNpqEeJOiskgVKuVXpwVA4CBgP02oDry1vPN4nnXKe0znud ObxPOuU9pnPc
6q2tgo7oZW8jUM9p3kHLIQALKTTmpjOd/PDbs6PnckrL78PNU34earEc3ied cp7TOe505vE8
65T2mc9zqmMK+FZffh5qm/DzVYjm8TzrlPaZz3OnN4nnXKe0znudMYTCsvvw 81Tfh5qsRzeJ
51yntM57nTm8TzrlPaZz3OmMJhWX34eapvw81WI5vE865T2mc9zpzeJ51ynt M57nTGEwrL78
PNU34earEc3iedcp7TOe505vE865T2mc9zpjCYVl9+Hmqb8PNViObxPOuU9p nPc6c3iedcp7
TOe50xhMKy+/DzVN+HmqxHN4nnXKe0znudObxPOuU9pnPc6YwmFZffh5qm/D zVYjm8TzrlPa
Zz3OnN4nnXKe0znudMYTCsvvw81Tfh5qsRzeJ51yntM57nTm8TzrlPaZz3Om MJhWX34eapvw
81WI5vE865T2mc9zpzeJ51yntM57nTGEwrL78PNU34earEc3iedcp7TOe505 vE865T2mc9zp
jCYVl9+Hmqb8PNViObxPOuU9pnPc6c3iedcp7TOe50xhMKy+/DzVN+HmqxHN 4nnXKe0znudO
bxPOuU9pnPc6YwmFZffh5qm/DzVYjm8TzrlPaZz3OnN4nnXKe0znudMYTCsv vw81Tfh5qsRz
eJ51yntM57nTm8TzrlPaZz3OmMJhWX34eapvw81WI5vE865T2mc9zpzeJ51y ntM57nTGEwrL
78PNU34earEc3iedcp7TOe505vE865T2mc9zpjCYVl9+Hmqb8PNViObxPOuU 9pnPc6c3iedc
p7TOe50xhMKy+/DzVN+HmqxHN4nnXKe0znudObxPOuU9pnPc6YwmFZffh5qm /DzVYjm8Tzrl
PaZz3OnN4nnXKe0znudMYTCsvvw81Tfh5qsRzeJ51yntM57nTm8TzrlPaZz3 OmMJhWX34eap
vw81WI5vE865T2mc9zpzeJ51yntM57nTGEwrL78PNU34earEc3iedcp7TOe5 05vE865T2mc9
zpjCYVl9+Hmqb8PNViObxPOuU9pnPc6c3iedcp7TOe50xhMKy+/DzVN+Hmqx HN4nnXKe0znu
dObxPOuU9pnPc6YwmFZffh5qm/DzVYjm8TzrlPaZz3OnN4nnXKe0znudMYTC svvw81Tfh5qs
RzeJ51yntM57nTm8TzrlPaZz3OmMJhWX34eapvw81WI5vE865T2mc9zpzeJ5 1yntM57nTGEw
rL78PNU34earEc3iedcp7TOe505vE865T2mc9zpjCYVl9+Hmqb8PNViObxPO uU9pnPc6c3ie
dcp7TOe50xhMKy+/DzVN+HmqxHN4nnXKe0znudObxPOuU9pnPc6YwmFZffh5 qm/DzVYjm8Tz
rlPaZz3OnN4nnXKe0znudMYTCsvvw81Tfh5qsRzeJ51yntM57nTm8TzrlPaZ z3OmMJhWX34e
apvw81WI5vE865T2mc9zpzeJ51yntM57nTGEwrL78PNU34earEc3iedcp7TO e505vE865T2m
c9zpjCYVl9+Hmqb8PNViObxPOuU9pnPc6c3iedcp7TOe50xhMKy+/DzVN+Hm qxHN4nnXKe0z
nudObxPOuU9pnPc6YwmFZffh5qm/DzVYjm8TzrlPaZz3OnN4nnXKe0znudMY TCsvvw81Tfh5
qsRzeJ51yntM57nTm8TzrlPaZz3OmMJhWX34eapvw81WI5vE865T2mc9zpze J51yntM57nTG
EwrL78PNU34earEc3iedcp7TOe505vE865T2mc9zpjCYVl9+Hmqb8PNViObx POuU9pnPc6c3
iedcp7TOe50xhMKy+/DzVUKxIPt5scax1/8AXmO+DEJV3ubxPOuU9pnPc6o1 ezkHeanGtYEl
Sa33HdKsiZMwf72IPqlMACH3Qq7HAlVcICspkdbJM7yx5aonUMUmMqQAKyxl DeRW3h5TGERH
q+WNTgtKKFv17aqaRQQawUc8BQR1OZRwZxth1tkASJoGmvyWojqABCOSUdb8 x+DrYzo/BO3a
mRb5scv6k4T8p7Q2j1wVBxWXpXqTzlVnBvXaBxKdJoochg8oQKIgNeCNJEEd vUl1nA7twUiY
HkVh0LuyG8s/XMb/AOgqQJVSYWSpWERWRRmgKycLiU0mKOh3aigCTiwqCGhj CHyfLqHU6nUr
N0IhAZSlanfuIVuw8wwshwrJmevpGPKqEfHOzkQQWdbOqzhEgkalOCSxCmUO TbMXZKImEAHR
1swloKXeu4suQk0WscxRXk4XmmxnFHSfGk0DCiizfOXu9/skogUiJimFMpPk zlKbUbJt7246
dIubbQGDxAMSOy+gKzNfZ2uwueAfVrZd6mSvSu2UUt6w7iupskVReIgnDxsm cekMoQvSgbTl
Euo8oAICPXDq1/LcuOIuyIJOQa6ijc6iifx5soioRRNQyahDpqFKchinIYol MACAlEBCvWxN
+Y5e3qTefkhWT2uYSHCCJWrSHQRkVl6UrX8QsT7RwyjyPrndOBUWKoLVkxZq OXC+wACbZTTK
I7ICJQE46EKJyAYwbQa0e9tNpc42Cs1rnuDRmtgpVf7pm76v9iS9bevEVHsz CqEtGJgp54iK
EgKg7KSyZBIlso7vRc6xFTCZRQuy3BuIL7Hifnryt4I3bcljYy4ptbVlLZiU ZNVpPInbnlGi
odIpHAYNZEd5qiJG4KHBbRMSgY5AN5Psn2zQ9rmpumkYImecxOhiCRMiQHAG y7Nt2GpsQaXG
cU+UTGomRORgxIupdpXo2zOpXRbcfcyEa+ZkkWKTojOTaGbuUAUIBwTVSP0y ahddDEHlKICA
9Sver2FwpSlKIlKUoiUpSiJSlKIlKUoiUpSiJSlKIlKUoiUpSiJSlKIlKUoi UpSiJSlKIlKU
oiUpSiJSlKIlKUoiUpSiJSlKIlKUoiUpSiJSlKIlKUoiUpSiJSlKIlKUoiUp SiJSlKIlKUoi
UpSiJSlKIlKUoiUpSiJSlKIlKUoiUpSiJSlKIlKUoiUpSiJSlKIlKUoiUpSi JSlKIlKUoiUp
SiJSlKIlKUoiUpSiJSlKIlc7sW4xs+zh44qrKuCiW+4wuiLxRMPIrBD1CmAP L6tdEa564mjr
nBx1DrX9GfBSBqzUVjckQ639mBDrY0o/BK3KmZb5scv6k4T8p7UMZIQ0v/MF 9mpH4JW5Uxtm
89z7TN5TjFqg2Ui2TNmkycqOFDkbC4HeGLui7JjAqXpC7eggIajya1dw9cFI 4r3LqKoe2JIi
RDGMLBYClKGoiOwOgAFaZLXFbr54sq4kGpiItinKdJZDaUNqfUvTpqbWgFLo AaD03l6hptB7
/ttMwkOZ8UQ6oDEOQEP8nTxQbY/fH3tQ57nQVGjioLHHgsDas6yfPolgk5bb 0j5baSbnJ1Cp
LABhAugcoaDqAAA68mmulbxWF8UG2P3x97UOe508UG2P3x97UOe51Be08VIY 4cFAubfG5hgV
iku5vW05ZzBXLbcYk2fsXBEEwdMnjxYSb4yyQkULvkTlAo6iGo9QBqLk8/OD ZHKDlSHuhYW7
lJdJN1eBVibxM4HIYSHkBKbQxSjoICGoVcvxQbY/fH3tQ57nTxQbY/fH3tQ5 7nX0uyfpBsWz
7M2nUoYiBBIfE8MsJ4LyK/sraatYvbUgHhhnzkLWssEhNTWDDC5Z+DeRriYk 5STKykEthZNJ
1IuXCW2XUdkRTUIbTXk1raMTfmOXt6k3n5IV+PFBtj98fe1DnudeG/130/h/ L2zbBo1RabjF
WRjyEgZAqBFC/tnSpnExgEA6QQLrqPTBpoPz+0127RWqVQIxEmNJ4L1KNI0m NYeEDwWwVGGN
2B7dXCK4caG0pIr34eK443iYxdZ2mqmikYxIsrfUfkum0UKUpwWOY+glMdA0 k80o76PQ++h+
mnNKO+j0Pvofprztq2Q7Q9j21C0tmIyk2kjiQJABteSCQI6KVU0gREgxPYOH fx7FFOUnAiYw
kteRuK+m6BbjuOQ467RIYFDR6QooplaioAiUxgBEDnEnS7ZtkBUKmVQ2631g thHifcltXhiL
hrCTkrZsoaStSRlI1NdaJdmTFMVkDHARTPsj1Q8sCj1SlENh5pR30eh99D9N OaUd9HoffQ/T
XTTp06U4ABJJPCSTJPaTmq1alSs6XmeHYBkO5ealeHmlHfR6H30P005pR30e h99D9NXkKkFe
aleHmlHfR6H30P005pR30eh99D9NJCQV5qV4eaUd9HoffQ/TTmlHfR6H30P0 0kJBXmpXh5pR
30eh99D9NOaUd9HoffQ/TSQkFealeHmlHfR6H30P005pR30ej99D9NJCQV5q V+DuG6SYKqLk
KUeoYxgABr8c0o76PQ++h+mpUQV5qV4eaUd9HoffQ/TTmlHfR6H30P01EhTB XmpXh5pR30eh
99D9NOaUd9HoffQ/TSQkFealflJZFcu2gqU4dchtQr9VKhKUpREpSlESlK/i iiaKZlVTgUpQ
ETGMOgAAdURGiL+0r+nKYhhIcogYB0EBDlAa/lESlKURKUpREpSlESlKURKU pREpSlESlKUR
KUpREpX82i7ZU9Q2jCIFL5Y6AIjp9wBH+IBr+0RKUpREpX8UUTRTMqqcClKA iYxh0AADqiI1
+jlMQwkOUQMA6CAhygNEX8pSlESlKURKUpREpSlESlKURKUpREpSv4UxTkBQ ggJREQAwdQdB
EB9YQEP4wGiL+0pSiJSlfwDFMYxSiAiQAEwB5Wuumv8AHoPrD1qIv7SlKIlK UoiUpSiJSlKI
lKUoiUpX82i7ZU9Q2jCIFL5Y6AIjp9wBH+IBoi/tK8artq3NsruUyCPUA5wC vzzSjvo9D76H
6aSEgrzUrw80o76PQ++h+mnNKO+j0PvofpqJCmCvNSvDzSjvo9D76H6ac0o7 6PQ++h+mkhIK
81K8PNKO+j0PvofppzSjvo9D76H6aSEgrzUrw80o76PQ++h+mnNKO+j0Pvof ppISCvNSvDzS
jvo9D76H6ac0o76PQ++h+mkhIK81K8PNKO+j0PvofppzSjvo9D76H6aSEgrz Urw80o76PQ++
h+mnNKO+j0PvofppISCvNSvDzSjvo9D76H6ac0o76PQ++h+mkhIK81K8PNKO +j0PvofppzSj
vo9D76H6aSEgrzUr8IuWzjXi7gh9OrsHAdPWr91KhK554lDrnDx4DrYgRnwT gK6GVzyxIDTO
Jjz9kGM+CcBVmorJ5J4iWgsQMwMXOSbd46SxoR3rlozM3TPraVuCGiZlFBLo AgHyY6iAjya6
BMUu+dkxHmWBFzFQb2lFKoolHQhVDi8E5wAOTaNsl1N1R2SgPUDSBeDmWnXj nG2WuV+s5eSG
L6L1RVc4mMBV7Vt5UhNRER0KU5SgHlAUA8qp1mPmpT/qMh//AJ2qumLiOWls lYRJgz/dang1
gXg1deD9p3hd2D1qzMvNWywkZaVmLdbO3Lpyu2TWVOdRYhjDqY46BroUNAAA AACtk6G7Lz6X
mwu0ph3GorzUMQDgcL5+NgOmWl4Gg9QdLfNVbYLBbE/K5l4hcTsFsjeAOXq8 bilrKtqMxGw2
Vazcg8aSkzHtnZHKKsGxApTJnA4hvVNTgHKAlA9XoUxUdgi8sA5l5LRnAzAm 83sDEGKz92Gu
nPGewMwk5ST1tIEXN1ebobsvPpebC7SmHcadDdl59LzYXaUw7jVKHua/PRB5 k5e2426brlIm
wsYbesFyhLksZjCTrVwlHg5ePjrO28qWSXB2s4QIyQI3HYSTKgqAnEPPl4zo 5ysRse7fui8F
rmaWjdmIF229K2/JhZ6UVFsowsgCR4orZ6aecSCQs0hXTXRUKcFVTFSRKVMR YW7oVBEEEgmw
jCxwmcsQe2JiL4ohQXOa5zTMgwYveXAgRnGAzEzaJV0Ohuy8+l5sLtKYdxp0 N2Xn0vNhdpTD
uNc+MtFs4HZU5HBDG6Rt+wrhQux65RhMwuGVxOELhvEVox44OpcsS5biu8SE iZlldHS50F0y
Du0QIIB5oXPXnOgLExCl1MYbrkFH2VuVxIs6Vvm2LWag3epLIFau49lFHVWS j1COdSoyZlHA
7oAE2oHCtNxLywC4xTaILWOeW3uDhYSA4AmNLqMZkXscMcw5wYDpAcRJBMTr ZdAehuy8+l5s
LtKYdxp0N2Xn0vNhdpTDuNVLxTxczr4SSuI2BkRmmG4ptNvYUhb83NR1vRck kaYfvm76NjBV
bpR51zEY/wBhlfFU0Opsqqq8g1Yvg/sUJ7GLAJR7eV+z9xT0BdMrBzrm6rcY Rko1ctnJi8Vd
pxqqjFVdIgkIddoIIKiG0UpNRKBtEOxRHR+mGY5AuAJykjUTU1oDSfxR5gke IBIGdjoY2nob
svPpebC7SmHcadDdl59LzYXaUw7jUjcQDzI04gHmRqmAaK+MqOehuy8+l5sL tKYdxp0N2Xn0
vNhdpTDuNSNxAPMjTiAeZGmAaJjKjnobsvPpebC7SmHcadDdl59LzYXaUw7j UjcQDzI04gHm
RpgGiYyo56G7Lz6Xmwu0ph3GnQ3ZefS82F2lMO41I3EA8yNOIB5kaYBomMqO ehuy8+l5sLtK
Ydxp0N2Xn0vNhdpTDuNSNxAPMjTiAeZGmAaJjKjnobsvPpebC7SmHca8auXb Lym6bNhy72F/
ZChybXOWw6XZSOp+88vyGn3akriAeZGvSkmgJykV0vyT1QP81XoWAIHlaN0N 2Xn0vNhdpTDu
NfxTLXl5UIJBy+WKXUPkk7OYlMH8QgkAgP1QrRs0OWPGnMviS0i7QznzmGcT aUc2loiMsEiA
SLiaMquCLiUFcDlcxpSpbJWQFIVc2/3hx3ZALMWF43FLYbQEpeM3CSks4hmy knJ20UwRztwZ
IoqKtQOc5tyY2piamMOyIaiPVpuwmMqEMOLYhsQJy17Bv2IbzcLHRV2KIxcs kDhA5mU+kxaC
oQ+oK7tucxS7YDy6G6oANSP0N2Xn0vNhdpTDuNatgUz/APtQiSbPUh73/HdS A1S/heLYfwmI
2M2JL3CGPxAn4rCaIdYVXA3vONavsLpIqz0COitnDlN2id26BEUVmSSyjlRH i59khQGsqQBL
QRme/KbcJtxIHPKdSCZgx8rkC/jwB7FfnobsvPpebC7SmHca8Enl6y8x0a4k By62EfcIHU2O
cxgG1sgI6a7nk6lSDbzSSVgGKs0lsvDM0hdlAOQFdgNoPX1rx3WyAlrSRtnq R6w//kGtn0gw
kWssKdXeMa64mFpi+WrLyiudEMvdhDsHEuvOUw5dB/vNfjobsvPpebC7SmHc a8ObPDTEbF6z
GmEuHeOo4dhc8wLOdn44pebJo7cLKLoRRziJEXhwIAAsYigpJb5QpdshTB+M qmGWI2EliPsI
8RMdRxEC2ZXiUFPyJS82Sx24RUQQlTkECLPCAoICsUiYqpblQxds5jC3YVsZ Xp4b21CWLite
Nk2jDtoyGRiYR82i2KBUm6C655FNYyaZQApNorZHUCgAak101Ea3qtdZt9xj zeA6aa21bwf5
aX/TWeetEn7NViudUpFkjJnMisZM4AIaCJTkEDFHrGKICHVAQGsgALKSZPrR eSlcwMBsyePt
yZUsKLthsa7p8UOexkJFLzlzyb0IVeO1U227lVxqzNqAE2Uyf2SYQHdgOhwr p/Xqe1PZdX2X
UwPcDdw/lMT2Hge1efsG3s29mJoiwPiJ8RxSlKiDPvfbjDnKHfNxxbmSSlDx IMoE0PJLtHXN
JyqRu0FJRAxVAEF1ExECiG0ACA9KI1w7PRdtO0MpNzcQPEwuutVFGi6ocgCf BS/XqXB8oX31
mr+QNYLBjD55hbhfCWNK3TKzb5hHIpyUvMzDh8u8cgQoKrCq4OY+hjgYwF1A pddClKHJWduD
5QvvrNX8gazqBrXENMjXVXYXFoJEFZKU+WTj+/n/AChrwV55T5ZOP7+f8oah 7OTiYSx8K0rO
jcSmNpTV7yJIGIuF8+TbliwUKY7l6B1FCAB0Gqa6hA2g2lSpEAQE4DWlCi7a K4pt4nw1PdmV
nVqNo0i88PUd6lqlQhwe2OktjrlqjnV3TCEhc1qP3FsXW+avSuUnL9kIJmXK sURKsCqYpLbZ
R2TCqIhyaVi8xWb3HHL5iiGHjPKBct8o3YVJvhhLWasVVs4kt0IrM5hRQChF EKJTKg6HepmQ
BQf2xPdnnadmqbLtD6L82kjwShWZXotqtyIlWDpXo2ye5FLbjz3kgxSlzMUh lUoxU52xHOwG
9BIxylMZMD7WyJgARDTUAHkr2H79nFs1H8g4KkikGpzm8rygD6oiPIAByiI6 BWC1XmpUZSIX
Bbc0W6DtlWpnCLtw2MCKYArtLAciTkdraN0giUA/c6FEvyJxDarevh5eNoLT 9tw5BeIqCTiT
hfZKY5dkRKBwDyyjyCIdUeXkqSCBKgGVsdKwtp3PLXWZR+a13cawIUUyDJk3 bhVYDaG2Uw10
TLoIbYj0xvkQEAEazVVBkKSISlKqBfWOGIWN2bCy8KbTxDUh7TutMrloWHkV 0H4xiKSjtY6w
IKEFIXhUUyJqbe9QSOQdEVTLJG7Nl2KtteMsFmgknQAE/Qrnr7TS2ctDjdxg duX1Vv6VXzMV
m9xxy+Yohh4zygXLfKN2FSb4YS1mrFVbOJLdCKzOYUUAoRRCiUyoOh3qZkAU H9sT3Z51tk9y
KW3HnvJBilLmYpDKpRipztiOdgN6CRjlKYyYH2tkTAAiGmoAPJXLC6F71Kx9 0TMjb8EvLxNq
SE44R2d3Fxajci6+pgKOyLlVJINAETDtHLyFHTUdAHUfFixE9Klf/tjb3hWt GUX1BII7yB8y
FRzw0wZ8Ct+pUP2TjZjziRlaVxZsnBVspeJETnibfmpUjJpPlSUD48gsmZfc JuEgMKInExQM
Yo7aiOyup6OVXNTiNmpnJO5G2Wq6bDsiLQOyB3iG24hMPplNbYXRRZFE4A1Q 2TkM4MpoqrqC
ZTEIJzKtF9Go5jswYPFGPbUYHNyN1NRvlox/vq3vVav2c5EyCoocClKGpjGH QADr1+DfLRj/
AH1b3qtXgnz7uCeqeZaKD/8AlGshl65LRfsktFKHBNOTbmMYdClKsUREet1a /TGRj5NEXEa+
RcJlOJBOgqBwAwdUNQ8sOtWvy90syqncJSSaxS7IlTK81Aw8aAwAAb43Ls+X scgeWUOkDzoM
pCMux3OKqm3bxJBJRqVMwJlMVQU9vbFENo3TBoAm1ENR5S7GzaFWVlLg+UL7 6zV/IGslKfLJ
x/fz/lDWNuD5QvvrNX8gayUp8snH9/P+UNVUrQrVzFYN3tgarmSti8eNWWjG vX6s1zPcE2W7
QypXB9ydMFR2BRU5NjU2z0oDqGq6sxWDdk4GpZkrnvHitlrRrN+lNcz3B9pu 7MkVufckTFUN
sVk+TY1LtdMAaDpAXNDFjELFaLtzEKybZw/vC7lgmCuhudpITFqoMV2KHE0F QaqJKqOUwO4S
II7swKugOQ26OCkqyGYa+Y2AuGybdsaJu/FC2Qb/AO9WMuFGObzaSipSi6QW XMcG+ie8UUbK
iZVE6ewIqEUQcr+1X9m06TmYOlNyMTbNmOtGHO2PK04YheZS217w7FaLCxuY nqzOV8OfCZUv
UqvmYrN7jjl8xRDDxnlAuW+UbsKk3wwlrNWKq2cSW6EVmcwooBQiiFEplQdD vUzIAoP7Ynuz
zrbJ7kUtuPPeSDFKXMxSGVSjFTnbEc7Ab0EjHKUxkwPtbImABENNQAeSvGhe mverGXPe1mWQ
2SeXpd0ZEIrH2EVZR+m3KobTXZKKhgAR05dArVsfL9LYEPCPX96GtyMfToNZ eeIVD+w0eKOV
CjtOCHSJtLJop7RyjrvNkNDGKIRkjiddkq7Lifh1e8ZdzWHln1vRjmRFTeSa blrGvDGSGMZr
AsdI6DgogREA2CmExgFM216mx+y6m0sbUceiZ1nlwi55zxhcG07c2i4sA6Q9 azkrAxUtFT0c
jMQcm3etHBAO3dNFiqJqlHqGKYoiBg+qFexUQ2pcOLEPlymZbC214i474Yyc g952pB26jEFn
C7070zIVXDciiJxQcAUiiiJSiYyZhACG1DH5Vc1OI2amck7kbZarpsOyItA7 IHeIbbiEw+mU
1thdFFkUTgDVDZOQzgymiquoJlMQgnNw7RR3Nd9McCQuujU3tJrtQpurAscS 7RkZ0lvNXD3f
KvFmiC6kO6I2WcI7zepJuDJgiocu6V1KU4j8bP5kdM9VeVpu4IDGCJUsjCPE u8YBKQuKWRJD
zFvmjY6VTfLMl09s66ZxMcXTxTdquQMTbAoJCdJYjXzdoZ7VfVpDY2tLcXTx GIbxIkgTAOt4
suhr9lYxxrEgxaBN+cA8YVhqVCaeaaWUxCQsyagS23ILTTJkS0pxBFWSOksK ICvvWjxVHZAF
DnDY3gAVMQMJTbQExGYrN7jjl8xRDDxnlAuW+UbsKk3wwlrNWKq2cSW6EVmc wooBQiiFEplQ
dDvUzIAoP7Ynuz9TXBznNH4TB7eWo5iRzXHR2mlXLg3hb14cYPJWDrxx/wAq 0P76599LV6ts
nuRS24895IMUpczFIZVKMVOdsRzsBvQSMcpTGTA+1siYAEQ01AB5K9qP+VaH 99c++lqnj65L
p4LyUqFs27h5FSNrTidkxFyoC5LGHhbhaq8T3z+SjGSDkVuLrJEUTUXKGwYA UMkquZPa3Ryj
i4DJNNJS9l3Zc2Pcy8f2/JtZCcZnt+FOhJKJNkkxR3wMCODE3rVgYDrqKn0Y NzAILooOEfQb
sdD3VtZ9UCZtBOXZ3ZwL8bxxO2mrv3U205iLyOPo+Cn2vG1/tx//AHpp/wBb mtfwbZczcIbV
juIcU4vbbFPivFOL7nZbkDY3XFmu70002OLN9nTTcpabsuwNf7cf/wB6af8A W5rhe3A8t0XW
04mAryUpWqL4nbl+qx5h67t88bbXGeruEAW2tNn91rpp5XV5epVYlStl5oMO P8y+Oo8a3O94
tvA3m71029nq7OvJr1Na81YOwY1gjBJT6ILHcy6Sbt45dKAdVQxigIFEwFKG hQHZKAABQAOQ
A1Gs5REr8OHDdo3O7drkSSSIJ1VVDAUpCgGoiIjyAAB5da5iU4lY5GMlIB8o k+CSTbt0zrGB
utveQSLEDXUoiAdOAbZB6YuobRD+hHT8XirINYx7GuU2zVM68gxOuUSA4IYm yisUCjtl0MCh
RA2wcNB6cNBCY4otybuEHSBHTVYiiShAOmomYBKYohqAgIdUBDy6/dK0PG5K 0V5GyUr8geac
Qa7h46y5jqP94Xma/wBPjCZDmU0NobkKOmm1yaahpQpb6sGTErOtU3VIviYW +UrSOY2S7sH/
AP8Ap+R7xrWm0jN2xZeJctlWwyjn75lcSS1v2rKpqwSLwxY2OMqh8cRAzY6g b3YMdPZ2zFMb
pBE1de0bDuKWOT3tjzlcuz7Zv6mGB3Gfopcrxm+WjH++re9VqhXKrmpxGzUz kncjbLVdNh2R
FoHZA7xDbcQmH0ymtsLoosiicAaobJyGcGU0VV1BMpiEE5pqN8tGP99W96rV 58QQu4LSsH8F
sJccMQsSZfGTDiFuhaHuxCNieb0cm7IzahFsl9hMqgCUmqrhUwiAAI7QaiOg aSB0FeUD0r1g
dqTTudYDLgzlnb/GJpASqbF8vehSsnqrbfFbqjCRwEUFPaLvAKbQdnaDXTTU OrVWoTFDMgGQ
9Wy75zGXHJXFcWbV1YE7iExVGPfN4pW8DslOKCmYeI6ty8XS3RgFHeFEhgMU DV0bO0VHNpgD
E7CBPEuqNpi94u8SdMpVazjTZvCbAmY4AMe8nnZhga6K4nQV5QPSvWB2pNO5 06CvKB6V6wO1
Jp3OqUxsxidL4+IcHU8x/wASOcJvmNkYQLlSv6RTuBeJSstCeTiDTRVgfjsv HBg3u+34ooAm
Kghta/20YjOHiHgPB43dFU9b2zhNc11wkvcs1fMmwdJs4S53SBJdZuySOlcS yscz4sZs9EiY
nEVgMKhxrUCkcLiIa4NdMZNLQ6TzGINgTe84eks3Gq0GLmSIHF2JwAHc0uvF oABccKur0FeU
D0r1gdqTTudOgrygelesDtSadzqP8mWaCyr6uGVw4vbEOWWxJm5F7Myduv45 +DGIAm5IaIZO
lUgZrqskTNk3STVU5iuDKqKFKKg1Y2rGk0AEjMA+jxg2kWMWUCoSSAciR60n ODfUKMugryge
lesDtSadzp0FeUD0r1gdqTTudSbSowM0U4naqMugrygelesDtSadzp0FeUD0 r1gdqTTudSbS
mBmiYnaqMugrygelesDtSadzp0FeUD0r1gdqTTudSbSmBmiYnaqMugrygele sDtSadzp0FeU
D0r1gdqTTudSbSmBmiYnaqMugrygelesDtSadzp0FeUD0r1gdqTTudSbSmBm iYnaqMugryge
lesDtSadzp0FeUD0r1gdqTTudSbSmBmiYnaqMugrygelesDtSadzp0FeUD0r 1gdqTTudSbSm
BmiYnaqumA2HVhWDasmFlWREQ4r3hcKCx4yNSQMqkhOSCSCZzEKAmKmmAEIA 6gQoaF0Ct3rE
Yfpbq1XQ6fJXpdA/+/n4/wCuqWZyODQxjzCZg8XcYrPsjCfmFeWE7e1VLFnJ iRTY4mSO0AoS
d0ii1NxXmT8kwNHl5oHMQAGRapbKKfEAMlsSZV6q574jWjdk9nBx3eQVzxzJ EuIEYQyTuHUc
GEwWnADtAYrhMADQQDTQeoPLy6Bc7LHhPe2BOXyz8HcSMcJ3EqdtyCQYyl9X MkmR9MLELoKy
gJh/JKJzKKiUpRVWXVE6ylWJgNM1ePA9fEaO+Cdv1pSaHOgqriQJU75TWDSL xQx+jWCAJIIY
vtU0Uy9QpC2jbgAH3ACpNmPmpT/qMh//AJ2olyVEs8l7Y8BYIMAifFiS4pzM 2Nx5Fre2tnY6
X5La108vWpFG6sM4m6ZiTnsY49Z88STZOG7+VZp8TTQMrsolKQpBDZFU4Dt7 RuQNR1Csqrpd
J4lXpiBAW3YTWXbd55Y7Vs68bdYy0TKWDHs5OLk2hF27xuoxTIoiqmcBKoQx REpimAQEBEBD
StmmMN7IuGFaW5P2ZEvo6PctXLBg8jklUWyzZQijdRMhiiUh0lCEOmYAASGI US6CADUVWxiz
HWVANLTtjMRYwRscgVvHpybAjhZJEoaETFROQSA+yUAKA7ADoAa6jy17/RAu /TDYbe0g+Fa0
ZXY1o7tOGXHhwUOY4nx88/HitqlctOX6dxbZY/TeBVmvL7jW/F469XVsNFJd qloIbtN4ZMVi
F0MYNkpwDQw9ekFlpy/WvitJY72zgVZsdfEyhuZe8mNsNEZV8n0vSLOyJgsq XpS8hjCHSh1g
rVeiBd+mGw29pB8K06IF36YbDb2kHwrUivTbEcJ0458ePHVQabnZ8vLLw4aL M2dk7yp4d4kS
GMmH+WPDyCu+W3vNS6oay2LWSebz9s3rlNIqqm1+62jDr5etehA5EMldqpro 2xk/wtjSOkHq
DkjDD+NRBZJ4UpXZDARENoq4EICoDyKAQoG10CvV6IF36YbDb2kHwrTogXfp hsNvaQfCtBXp
tiOAjhlpnlyQ03EydZ79e3mtvvbLzgbiWwmYvEfBe0rga3FHt2FwNpu3WztO TaNznOg3cFVI
YFkkzqKGIQ+pSCoYSgAmHXI4d4T4c4QWcyw6wmw/g7Xt+NTEkdBW7FIsmbUo iJhKmiiUpCAI
iI6FAOURGo/6IF36YbDb2kHwrTogXfphsNvaQfCtSNoYJjj2fdN24x60Ut8R +oFOI/UCok6I
F36YbDb2kHwrTogXfphsNvaQfCtRv6fqPum7cpb4j9QKcR+oFRJ0QLv0w2G3 tIPhWnRAu/TD
Ybe0g+Fab+n6j7pu3KW+I/UCnEfqBUSdEC79MNht7SD4Vp0QLv0w2G3tIPhW m/p+o+6btylv
iP1ApxH6gVEnRAu/TDYbe0g+FadEC79MNht7SD4Vpv6fqPum7cpb4j9QKcR+ oFRJ0QLv0w2G
3tIPhWnRAu/TDYbe0g+Fab+n6j7pu3KW+I/UCsbOtdiUhuQOWSOH+ar1G3RA u/TDYbe0g+Fa
dEC79MNht7SD4Voa9M+h90DHLD5ruDvwTzdXJDXjeE7dltS0emDGXk7EuZeI cXFCGMJ1oSRU
QEDOWChh2hTEQMQRMKZybZ9qZbYsq27JtthZ1nW+yioiKZpNIyMjmxUW7Rum UCJpJpkACkIU
oAUCgAAAAABUZdEC79MNht7SD4Vr+GzAOzAJeiIw3DXyywo6h/FrKj/1U94Z 6j7pu3LFYFtN
cWY4unUiby/HcyQ1IV65b8BMSr7gsUsRsD7Pn7mtc+3bNxzdtNXb+INrtatX CqZlG468upDF
5ajaJubDS2HUbM2pjtbraTjkXaR3j503cJugdL8YcbxIqyYhtLaHDZOGzsgH KGuud6IF36Yb
Db2kHwrWdKq1kajLJXe0ukcCpb4j9QKxt5s9mz5Y2gckauP+TNUbdEC79MNh t7SD4Vp0QLv0
w2G3tIPhWtDXpkR9vuqhjpWbzL5XsN81mGC+GuIoSDQSuCPYG4oF8ZnK2/Ip gO4kGDonTtnK
YmHZOXkEBMQwGIc5TfzLRlcw3yq4YI4Z4dA/didwd7PXFPPjPJW4JFQA38g/ dH6dy5UEobRz
cgABSFApCEKXC9EC79MNht7SD4Vp0QLv0w2G3tIPhWp94p+o+6jduWQdIbnH O6x06tuQIf5a
V/TWQekeKM1SR66STgUjAgqskKhCH06UTFAxRMADpqAGDXqah1a1ONxIw6Tm ZG57hxptl/Jy
ZG6bhZs8QbIkSQBTdJkTFdQQ0FVUwiJzCIn8oAAK9/xXcJ+yfbvt0h+vWGNs zKsWuVW7c4J9
43ytRWTy8cwhH9nNLoNMyisbaHFJB7020VAqyjtYiJQERETAmYw6F5QADAa4 ta94ruE/ZPt3
26Q/Xp4ruE/ZPt326Q/Xrs2v2ltO3ma75uTkBd0SbAXMDwXNs+xUNkEUmxYD ibDIXnKVsNRX
mSwDv3HaVs0YLE6Kg4u07uY3Eqwd2yq9UkHTQxjIkMoR4iBEgMYD7OwYdtMg 7WgCUdz8V3Cf
sn277dIfr08V3Cfsn277dIfr1hQ2l2zVRUpkAjsPzla1aDazCx4se0fJbDXq XB8oX31mr+QN
YnxXcJ+yfbvt0h+vXrymKeFb2McMksULcAyyByFE02hoAiUQDXpqxLmxmtQ1 05LcJT5ZOP7+
f8oa0J7hNKyOPjDGl/eJVWsXb7iLjoA8aAkb79RNRZyVXb1BYwopkEdnQEy7 IAAmMYcy8xjw
lcO1XBMTreAp1DGABmkNdBHXzdePxXcJ+yfbvt0h+vWjK+7JLSLgjhkc1m6l jADhlfwWm4cZ
bXuGuYm98d4fEIRa36LY8zbBYkhG5VW6IJJLpqbYmKqJQHbN8ioJhESgIFEs p1r3iu4T9k+3
fbpD9eniu4T9k+3fbpD9eprbS7aHB1R0kADhkBAy0EBRToNotIYIEk8cyZPm thr8rIouETt3
CRVE1CiU5Dl1AwDyCAgPVCsB4ruE/ZPt326Q/Xp4ruE/ZPt326Q/XrLG3VaY XaLxOMPRk7jB
/OSqjxgiQot2i4iYxjeZUMPyZQ0Dq8puobXQdrNxEKwhCOCMUxDjTtRyuYw6 iZQ46iP/AFAH
1ACsT4ruE/ZPt326Q/Xp4ruE/ZPt326Q/XqTUaeKYTothpWveK7hP2T7d9uk P16eK7hP2T7d
9ukP16jE3VMLtFH8hgNmHm8EpTDC581RZeWml91IT76x26RCx5iiVVqig1WR FMygDsmWFQxg
KJtjdm2Tk9vLZlRtXL6pKXW9nFbkvG4FTHnrrfNipKLFE21uUUwEQQRAem2A ERE2gmMOyQC7
r4ruE/ZPt326Q/Xp4ruE/ZPt326Q/Xruf7U2l9F1LEA1xkgBrZy/KBawtlyX K3YKDajamElz
RAJJMeJN755rYaVr3iu4T9k+3fbpD9eniu4T9k+3fbpD9euHE3VdWF2i2Gla 94ruE/ZPt326
Q/Xp4ruE/ZPt326Q/XpibqmF2i2Gla94ruE/ZPt326Q/Xp4ruE/ZPt326Q/X pibqmF2izpvl
ox/vq3vVavJWtjizhSL1s48U+3dlE6gmDm2hqO0ioQNOn65w+5rX78V3Cfsn 277dIfr0xNjN
Thdov04ty5U3LhtHTiAxrhF0JmzhARUKqroIaHAfkQMJx6nIAiGhtQEn7NCz Sz4js7Rmn05d
sxVgEQKC4KjpoiUw8oCGm1p5Y6jy14vFdwn7J9u+3SH69PFdwn7J9u+3SH69 TvG6quA6LLXB
8oX31mr+QNZKU+WTj+/n/KGtPlMU8K3sY4ZJYoW4BlkDkKJptDQBEogGvTV7 jzGPCVw7VcEx
Ot4CnUMYAGaQ10EdfN1GJuqnC7RQpJYa5jMTML5q+ritsbakZxwWZk8LG8uV R6o9Zbojds3m
2zhJNqDgrFsO+BMTIiscdoBKAlNMNcxmGuGcFfdp22NxPoNwMywwreS5SviP XpVSOWy844cK
JuAb8ecm3xktpbcF1MJjCY0z+K7hP2T7d9ukP16eK7hP2T7d9ukP169X9dbR gwdHDpFoiMOc
5WmccfiXB+raWLFfFrxnOcozvEYf4VsNK17xXcJ+yfbvt0h+vTxXcJ+yfbvt 0h+vXlYm6rvw
u0Ww1q+KViXBezOKcWndqMNKQsrx5k7cxwu0RMLdduYh0iqpGMAkcHENDl0M BR5QAQHz+K7h
P2T7d9ukP16eK7hP2T7d9ukP160pVzRqB7Dcdh+arUpCqwtcLFethVYdy2Q1 mHF4XghNSc1L
8edOmkYZokQQbINykImZVUQACNyiIicdRMPUDQK2qte8V3Cfsn277dIfr08V 3Cfsn277dIfr
0q1zXqF7yJPYPlZKdIU2BrRYLYah/EXD7Nqk9ULhBi/bLWJNDzZl2EpBO3Dt Z+4eb9pu11Xp
hSAiJjpFNrukjAIg3OmdJFrLjN40kGiT9g6TXQXTKoisicDEUIYNQMUQ5BAQ EBAQ6tYLxXcJ
+yfbvt0h+vV6O0HZ3hwg8iAR4HtVKlEVmwZ7iQfJazgYzxBbzc2vctm3BBRB 2rIsaxuS5Cya
5nIGccYUKcHTkSEEgtgAonANSGEChyiaR617xXcJ+yfbvt0h+vTxXcJ+yfbv t0h+vTadpG01
jUMCYyysI4knzzU0aBo0wwSY1Ww144/5Vof31z76WrBeK7hP2T7d9ukP16/D XFnClBkm3Pif
bomIdYREJtDTp1lDh+76xg+7rWGJs5rXC7RalmLy9tceZK3iyaLkGsQ5TXOv HXQrEuSGLJRr
nQqqDY6xibDVU+wVZIoqJojoCoIOme2spTF5Ti/NGxrbS2tzxrcXU4U3evFN 7sasS7eztvtn
XZ2+LN9djjKnFv34ruE/ZPt326Q/Xp4ruE/ZPt326Q/Xrf3qababoIExc8c+ Kx3EPLxYnPu7
l5sNLddWhhxb9pPmrZBaLhGjRZBkKQopmTRKQSp7pBunsAJdA2EES6abKSYa EDLtf7cf/wB6
af8AW5rBeK7hP2T7d9ukP16/COLOFKa7lU2J9u6LEQAuk2hybAq669P/APxA 9YaydUa5xcTm
tGsLWwAs3LmlixqwwSbYzzY0bg7OYqYG65hKAjoHV0Dq6aahrqHit6HXhI0G jyXcv1zHFRw6
cnEROceUdkvUTL1iF5AD7ojjPFdwn7J9u+3SH69PFdwn7J9u+3SH69Vxt1U4 XaLYaVr3iu4T
9k+3fbpD9eniu4T9k+3fbpD9emJuqYXaL23cTOydyJuncnxeMZ7J27ZmsYqj pXTlFYQANCF8
pMBEDDymHqFryPrYYPJ9rcySyzZ62KKZ1m5gDjCPKO5VAQEDkAw7Qfuijrsi G0YDeh4ruE/Z
Pt326Q/Xp4ruE/ZPt326Q/XqcbdUwu0Ww1r19RF0PJO27htNhHu3EDPC+UaS T87YiyYs3LcS
goRFUSm1XAfkBAQKPUp4ruE/ZPt326Q/Xp4ruE/ZPt326Q/Xq1Otunh7TcKr 6W8YWuFisp4p
GMnYhtXt6c+DKx1mxtzpS9x3JdcbHsnE7NkeJs42QO6IimRk1bAAqHRSETCL cxvkAAAMAajX
48V3Cfsn277dIfr08V3Cfsn277dIfr1tU2x1RuEkeu9Z09lZTdLQthrxm+Wj H++re9VqwXiu
4T9k+3fbpD9evwOLOFIvWzjxT7d2UTqCYObaGo7SKhA06frnD7mtc2Jsi63D XaLN5WibNy4n
m81fKQ/+6Y8P9VZSUyhZdZrCO4sC5TDgi1r3VPvJyajjSboDqSTp6L5V2muC u+bqg6HfEOic
gonKUU9jZLpHcNiNbdlzkvM4d5gLMYknXJHMk0mEU3xBXKmVLeJim9biTVMi ZRAdoOkAQ01H
XJ9ERcXpksL+1w/hitqdak1kHs4ZSD8wD2gKrmPc6RqDxziJ7YJE6E6rJLcH xlNWweb4Hjh9
KEiGlxmuFvJo3rLpzhJg20B5HmyV2EkLsxTnIZwLjeGTMKYmEg7NbZD5ZMC7 ewehcAYTD9Br
Z9vuGi8ZBoulyplUbOSukjKG29tcd+QFT70x96bUVNvaNroPREXF6ZLC/tcP 4Yp0RFxemSwv
7XD+GK1G1MHHiDwzEAHPMACNIss9wT5+Zk+JJJ1JK3Gz8o2X+wsaZLMFatlO G90SguTLrqT7
5Zmgo5MmZ0s2YqLmatFVzJJisqgkmdYSgKhjDUk1AvREXF6ZLC/tcP4Yp0RF xemSwv7XD+GK
gbTTDQ0ZCwysNBdSaTy4uOZuc7nUqeqVAvREXF6ZLC/tcP4Yp0RFxemSwv7X D+GKe80/UfdN
071KnqlQL0RFxemSwv7XD+GKdERcXpksL+1w/hinvNP1H3TdO9Sp6pUC9ERc XpksL+1w/hin
REXF6ZLC/tcP4Yp7zT9R903TvUqeqVAvREXF6ZLC/tcP4Yp0RFxemSwv7XD+ GKe80/UfdN07
1KnqlQL0RFxemSwv7XD+GKdERcXpksL+1w/hinvNP1H3TdO9Sp6pUC9ERcXp ksL+1w/hinRE
XF6ZLC/tcP4Yp7zT9R903TvUqeqVAvREXF6ZLC/tcP4Yp0RFxemSwv7XD+GK e80/UfdN071K
zFnpbq0lR0+SvG5h/wDfbwf9de9Wl2piVZsJFqRc/jlZ8iU0i8epGZimzEij pyq5WAdp2ttF
21RAodKJShoInEdQyfiu4T9k+3fbpD9euYvaeK0wuWw1R+bDTNTjqPXxEjvg pAVc+Bu+07q3
vOvc8dJbjZ3/ABB6mtu9rXZ2tgR010HTXq6D1qplPBpmnxzHr4hR3wVga2oE F1lR9gpRwMvW
CuVhmavfD27Wkg0UxDWVj5eGflVTMYloQRdpNVIwgIlOUQ1AeQxR8sKkpziN b9pwwLPJFnGR
zNMiZTKqFRRQJyFKXUdClDqFAP4gCqfcDfp0BOMogOut9THL/wDgEZUuL4gI ITVvLunIAkne
UGdQwAI6FCTbCI6B1eSs6lV1KnVqNzAkTlxWraYe9rOcfJS1FY+2BOP04qEx Ah3jpXXdNmso
koofQBEdClMIjoACP8QDWY5+w+iB9eoYYYm27nJzVtohvKXS0s1/aTl23ZqT KhSKum7oqaT9
BETmI2MJAAA0KU4DtG0AxhEdOcY+qWpgUfFWf3j08baQyr1NEoAdcU2u+OBQ ANAE2g6AAaaj
WdLbK7HOFcDCASHCRIbGKWySIkEXMzwi/VtXs/c1W0mdY4ZBixcJF8tQdIvy sxz9h9ED69Of
sPogfXrlhc2ejNfhXdsNjtjNI2zJxS2A09dETaVlA/QRF0ZzEbhu6KdZcHZk gWApXaaZBEFV
gKiX9148U84GbXFjBW6cOXNxmt1+lcFoJt76j8NLntYjhrIy6bRyxTSfOW7s iqWhRM4QcfHE
lhAoInHaJ6eF4cGkdKYjQ4ywjuLSTwjIm0+YCwtxz0ddQQCD34hbPWIMdU+f sPogfXpz9h9E
D69c4LO4Q/GVbHhhYbp/bE1bMvIT8bHKw9mzaRWR45u4VSUGYdKcUkjqcWOV RFAgCkYRDeqb
AmNjccs9+L9y5Xmzhk/ZwsjdeWeUvJ1IwSjhs6YSaZI8CcVUBYTJJgLtUQ12 jgJSaHDQdYac
Z6Ok+LXuHlTd5KwaZhwi8ebR83BdMefsPogfXpz9h9ED69UWy2Yu4xBilj64 vjEZtMxkTeDQ
ttRwsnBBjycwY9cUwMo6ULux3hREpCJgKu+V/wDK7BIea8IRn3Xw7SvpY+EZ OMYIlxIIiW3J
Q26TTKAqRY/2eG2dTaKYrrpQS0EooLch6gOBMcgeyWuf5Na4nsgSSATGF7ZA 4x23a0eLnNHf
e0ldSufsPogfXpz9h9ED69c8XefzHxxLP8VYmKtBPDyExFibQkIJw0dGm3J3 Z2aJ3qboFwRT
BNZ6TZbi3OKiaZjb0gmKAR/bueDErCSJNeknJP7kWZQeIjls1lp92Ka7hG7k GbFNTVQUwSTK
sUgHFMx0kiiVMSl2imkYi5ojOfJm882kEdsZghVBaWyNQPElvkQQftddTufs PogfXpz9h9ED
69VUwOxQx843N2tmAnbIkn7A7ZaPkbMbrsyqoKpiIlWZuHDhRExDkOUD70Sq l0MBSCBih6OL
cUxvzMBhWrcV6X8nHSco5tRnBYcXc7jpFOWk1WZmc8m2SOLeWCMKycrrsnqS zUrFZ+6VIqVm
LZwJgwguJhW55+w+iB9evSPcvNO/LWBFXRQ0k4SOco6GMkLJwcyYj5ZROmkY S9QTJkHqlDSr
mMuD17YQ5scPbQxCxtuaUvaMi3V13DcTJ3IQNq3DEnRexaUDFwAPl264tl1m 8i9euVHDpusr
HEKcUH6CLCYMLbl5s4s2013gDsvXBtNf/YnIf66yrH9mR2fNXYLyrDUpSuVX SlKURKUpREpS
lESlKURKUpREpSlESlKURKUpREpSlESlKURKUpREpSlESlKURKUpREpSlESl KURKUpREpSlE
SlKURKUpREpSlESlKURKUpREpSlEUFeOi8Gb9MTwK91yG75qWMNMUcM8aLJZ Yl4O4iwV2W5J
bzmdcFsy6L9i63ahklN2ugYyZ9lQhyG2RHQxDFHlAQqHMJ8leNeB2FltYKYW 8J3jrF2xZ9vs
oS3IzmFYi/FGDRAiDdHeLWwdRTYSTIXaOYxjaamERERqSMu2Bsbl1wwLhrH3 zO3MdS4Jqbkb
gubigPpB/KyjqUeLKAzbt25dpy8WEpUkUylLslAOTUbODIsVAnitfxLz55Gs F72e4aYxZzsJ
7TuON3fNG37mxFjGD5rvEyqp7xBdcqhNpM5Dl2gDUpymDkEBrPYK5oss2ZPm n0OmYqxL+5i7
nmxzlXcyleIb7ebrfcVVPutvdK7O1ptbs+muyOkU5a8omFOP2Y3NBeN9XZig wdtscI5kmjZW
N91W01FMth2kcDHaxEk2QUV1UMArGIKglAhRMJSEAvt4NYHWXgDwkmL9nWLN Xg/aOcD8O3qi
164hTNyugUNMXqQSkdS7tyumlomUQRKcEwMJzAUDHOJtDTAp4lUOl0KQpnpY +54kvI1NfcW3
M2D9rFJcY0V09nqbKgrLCcvUOKp9ddodctiLjZYeF0zGW5c5Z1xIS7Vy5j2F v2lJS6x0W5kC
rKmIxbrGTIUzlAomOABqqUA1rEzX/rL9kOD/AO6a1HNeSIt+/rQxHVzW2Thj IMoeXjWpb1bJ
qpyaLlWPVVFIDPmggZMzRHUQE4aLBqAcmvR7H2bZdr9oNpbQSGGZLQSbBxFg 1xzieibeK5Pb
G0bVsns91XZwC8RAJAFy0G5c0ZTHSF9clK2HeIlqYqWolellu3SzBZ05bAL2 McM1k1m7hRuu
kog4IRVI5FklCCU5QEBKNZuqWwELGLXta+G7GAvfFKKl2EtLrYmYW3/PwsQ5 cOX09Iqt0k2L
nmaCibhIjUTuXyaonfNg6YhD7uYM3eLV55beD8vDFzDaHfRk3a+H4rxaFyuu aDiLUKgUoKO1
N8sDk6Gu2qcVVQOKRhFQ+u0O/tfYdn2B53Ti4EmAcIOGSB+KZMXxNZHEBY+x 9s2n2i1oqtDT
DQYLiMRAJHViBNi1z5GRKnKlUhx5sG68htuYeZgcK80uJd2zUre8PBXHE33f juZj7tQkFNyq
omzWOKLFVIDC7ILEiBQI3OUSiQR0w2ZLO9mHvPJgi7s6ag7YnbzydzuIjqaj WjsF42SQQjR0
ZiR2Q6Jdl642DiYx01CpH2jAQxD+YBiDsNy0lp7Qx1S0xbC0mbGbEBerTGN7 G5B4BHYXhl44
4jwkaEq+9KoNhbjrjrAY3IW9fOIrifdjjy8jHShHsg2ZAklhwi/FNFrxw4Eb i6KZUEFTrEKZ
Qxw+OaKB+IThOM1mG2CUbjtmBs2w5hrdWXh1iNb8FZcRItl492geOTBkuqo4 ci7TVGRSPtpJ
JmS2Dk2VuQ4yWwYB/C1381N1QDtwtd4akKlN28a0gZ/6gz5kePJX8rXsMPI2 59UUv+cnNQdk
YzS49423rd2HeN9onUCDjI2RiruaYSXJZ7R5xkXBFmXFJ4BWOqgZAoismoYi hFyDsJmAxawH
CUZoL9yacFzjDmOwtDZuOAGTShHG43vFXLucMzI42eoO6FwCvLqX43ygIahV XU3NqAHiPXrw
spa9rmmOH2n5H6GDZTpfmarK/hZd6OH2J2ZCwrcn3AgDeDnrwZM3ioiG0Gyi qqU5tQEBDQOo
Otb2isi5RI4bqlUTUKBiHIbUDAPKAgIdUK+fe/7A4M3JDfeBOVLNVkZnMf7/ AMwNtQ1wYg4w
y94PePA5mHAo/wBgFJtC4ORUBHpDpnMUSanOc46Xs4EyTvvLdmrzLcFNJYhy t22VgpMw7/DW
UllxcLxsZJNjL8zVFddNEgFEClAChtguIAUBApbFkCVAMro9SqP3jHXrmUxA x2vW6LwxukFM
Mr3b2tZ2G2CmIIW86ao8z2LkZI4GeskHiqp3h1dHip0QRRKUqYm2gPqdgcJN mZvHL9O4vYNP
belrfwZwwYz1+OMS4Dczt3KhxwXCSIxj8WcaoCTFQQWDjaSiqmhSEKURqrAH UhUNgQ0/5Xtx
A+ETaxIFzIFy128LGiTJH+YENI8TAM3gnK66GUqlmIvCK4wW7mijLRtFW15W yl8RYC1H8Sys
CedPGoySbcDLuZ4piRbJwkq5J/ueKaqpiAURUIKgAXQ087GbnCfByMk7UfR6 8Sa6MQXE7fV7
2nO3Qg1FlcztBlHOAileMRbUUAOHNBRNZBuRuBd0IAAVIaS1rjYEkd4a1x/p cCM5Jwjp9FVB
DurewPjiA82kHTrHo3V/nuwpfdmtHBAOgrcZxWROGpDimweLJiIDyDsqppqF 16h0ymDlKAhI
c7iZY9rPCx9zXtExzg6YKEQfySSJzEERADAU5gEQ1AQ1+oPWqKY+ea3DK4d3 MyeNHCL+UFyk
4YOd8gqVSJemAyamgbZBAdSm0DUBAdA1qP8AOrdbeClF3LjEa6rYD/e8Tj9o xgO3Km26kg3R
iicmhB2dfkh2jlTJsLbe5UsN5SxDIgmeUCdRpGa4dv2ynsuwnaYxAAGJAmTq bDNWJ8XDCXsq
237eIfr1sfHx80FUvxDvdzG4surfTxOctWisBehDWelCpqIOx30qoDk64uim TEgsygTRufZ6
Yu0G9ESb5wjuLd/YaZeGaGHN7LWs9uy/bctVzd7YiZlYFpJyjdmu8T3pTEKq VNUxUzHKYpVD
kMIDppW+KHMY14e52BsAEYXvIAYSdJaSRYArrFHaGNx16ZptILmkkHEwT0xH DouAGZI7FZTj
4+aCnHx80Fc5b1xc8bszDyFrw9442Ixsjh/OOIx9jjiInP2jPSLFmk8K8Tdu JN1Lxu71MkoR
JoVFQVdCpgYEzGx5c+eZPFG3pmwL6uIGkpauLeFwt7ltvD+fsg0lHy86kk4a nj5ddR0KejdZ
IygnBNwmqIbsoagOjP2j2NaesWDsx1N2PO94tobKjhgaS4ZYv6W4vrFpvyEr pVx8fNBTj4+a
CuYkBwiuY+w7dgsGcPZBzJXHKTmIs09uW4sM7pvnZZsLsdsWccVtB6roFEDl IDhQ+6bpokKV
NQTFIG7P+EJz6X8yuG7cJMGbNgGtoYAQWIU3aN5wskrNLSD1KTOrDplKu3BI Siw0BRRPaAR0
FM23qnm2q00d7MN1OVsU+BY4HjbKHNm5pu3xpAdKYjtLQPHE0jhBzsY6C8fH zQU4+PmgqvmU
PNbI5r5S+76tgsUrh7FzrSLseVZpqb+UErBBd64OoKgkMmVdwLcoFKUQM2V1 E2obOq56LPk5
XFvB++D4uYgRUepPOLSbWzhzejyLkV5eWXYmZTqTVI4tprmUVg6cLsHyKzQI 9aSdqkVIyM1c
6OD2EB1iQD3EAjyKzY5j24mmR9rHwNla3j4+aCtBxtWIMvZztMpSrGuFZuZY oaHFE0e7UMkI
9XYE6KRhL1BMkQeqUNK7tcNMZC5+LDisVcx9wvLutqBc3bcbmJfyVv2nc8Qq 3fxCUFFW5x9w
3c8Ucrt5N+/dqunbZdaLTKcUJBujHTzi2430rZxf/vOoPV/4sfVjWPQjs+a0 YBK8tKUrmWiU
qD2d9xLvDq2MSXeI0w2ui4Y5vKgEewk5UoAcqaqiRYxqsKPFSFUI3FQUdoCn IYVQcHKsPv2T
mWBO8lrbxDVkeIuxjW8HMlwzmIpFZ65XWRM2OLjegUQEG2hzCQoivoAjsm0+ Y2P9K/Zm1Vm0
ycJdlJEZSJvY8IuJIAJXsVvYu2U2FzQTGdjrFrQR3gxNgpWuD5QvvrNX8gay Up8snH9/P+UN
Y24PlC++s1fyBrJSnyycf38/5Q19OvHWMnrit+1YxSauidZxrNINVXb90RFI nl8pjiAB1OvW
OsnFHDPEtsd5hxiLBXAimIgorCS6LspfK5RSMYArQ5fDW4swM3iVzLv5nb0r aEgwirXlJWFR
kEofaZNnrt+kgqIE36iboUCrH2t3uREA+SAYww4dXdc2BOJea9jPTsrbdsFJ K4NXhdjRoncE
qzbJmNIIrGQSIKrNyolsIEVIB9k4DoXQmnqU/ZwqUcWK9vOI9TwNrX4n7WW1 Ii1/L18laisF
iXijhngvZL3EvGLEWCtO3I3d80bguaXRYMWu8UKknvF1zFTJtKHIQu0IamOU ocogFZ2vQum1
rZvi2ZGyr1t1hMQ0wwWYy8RKMyOGr5qqQU1UFklAEiqZyGMUxDAJTFMICAgN eWu1Qz46LwZv
0xPAr3XIbvmp1qKIXL1fz+Wirdxkx1f3tYVmv0X1hWrLsVDOyukjgo2Xmn6j hQ86oyOUnEjq
JpGTMQjl2L9+i3foyvVnYeCgTxUbYxZy8oGXe5kLKzAZrMNrFmXTAr5tEXjf MfGOlmpjnTKu
VJysQ5kxOkoUDgGyJkzBrqUdGDucvKBmIuZeysv+azDa+plqwM+cxFnXzHyb pFqU5EzLmSbL
HOVMDqplE4hsgZQoa6mDXGX/AJXLtuDHOTzAYU5usScM5mctOKt6cbWcwtxy 1ftY51IuWpzF
mIh8cihTyrsBFM5CmKYupREoDSwMrl22/jnGZgMVs3WJOJkzB2nK29BtrxYW 42asGsi6jnLo
5Sw8QxOdQx4poACoc5SlKbQoCYRpDMOd0vK3DGLHrAzLvbKF65gMZ7TsWGdP ysW0veNxtYxq
s6MQ6hUCquTkIZQSJKGAgDtCVMw6aFHTRbW4Rzg874uaOsqys+ODMxMzD9Fj EREXihEuHT50
qcE0kEUk3AnVUOcxSlIUBMYxgAAERrC51MNLcxgxryxYdXZJXA0j5HHV/wAY cWtdkjBvybux
LtVLun0aug6Q1MQANu1S7ZRMQ20Q5ijic++R7BfB/BS2sRbTvXGB3IR2OuF/ F2905hbynGB9
5fcCkbesZKVXar6FOIl3iRtgwFOXZOQpg0ZTDmSql0GFOt4/GbrtNyj0iiky u3OoXkMZIzF0
oZMR8sonSSMJeoJkyD1ShpS+/r7se1s2GNzC5rziY5dS+45QiD6RSROYg2vB gBgA5gEQ1KIa
/UHrVdC9fJJaHqiV/Nr2qPYtBpm4xp+re0b8GISsqRLXEj1kruAIClHKHgha OXDCLMXgvYj2
QcRMLfj0Gi0osRRc29tWGXNtGIQhR6ZQwBoUOQA6vVqKJC4psqjF8xZIOlGE ywfcUcujIkcF
buklzJioUhxJtFTEu0BR0110qacuU2vcdg5kZxzLGfKOr3XOd0cUdTjzoQfI IIdIXTqbICIl
00ETCAiMXwWEWK90RSU7bWGFwyLJfa3DxjCrrJKbJhKOychBAdDAIDoPIICH lVcNFQvaciPu
rAloBm6w+GF7zWEeIjG/rPw9MkSOarNGkWe/AFErVRUVdwJuZW8EoHEvTbW0 IEABEQE2vp20
rIxlmR9sTAIri3jEmroodMmpspgQwcocpR0Hqh1B6lbh4geOnYWu3tcddzp4 geOnYWu3tcdd
zqzaDW53z04xPDkFpW2mrXfjeZNvLJQPaWTrLPZLx09hMMBU43b7mCOhKTr5 8gnFuDEMqxSR
crqJottUyiVFMpSE5dgC7RtcjbWWfA+1IJ7b8daL1wlIyEe8euZe5ZB+6VUY LEXZlFy5XUW3
SKhCmIjt7svTBs6GMAzP4geOnYWu3tcddzp4geOnYWu3tcddzrcEj1zn537b rA4Tn64fJQhF
ZVMA4S72V8xlnSCb+MlnMjFkG65IzZiu5BQHAINjOBRRTV3ym8RIQqSgm1MU RABD0oLJjlnt
1i/jY3Dp0ZCRttxb66by6ZJyCUUuYhjsUd64NxdABTKJE0tgqfLsAXaNrPni B46dha7e1x13
OniB46dha7e1x13OobLcuzyj5GOxDBMn1x+d1FKmCeGKl5v7+LDySUlKSLZ/ IcXuV+k3cOUG
pmiahm5FwREdwbYN0mhwImJ9oUyCXxEwEwcJb5LWJZIAwTsc1oEQ5pueSFEA AWu1vNeoAfHN
d5/DqW/EDx07C129rjrudPEDx07C129rjrudIj1yI+RI7CRkUBAMjl5EEeBA I5gFQ0tlqwLX
xEb4oq2KoMs2dNnZSBNPAZKOm6YJIOlWYLcWWcJkKUpV1EzKlAhdDBshp7AZ fMERarMV8O26
7dxHSzBw3dO11k1W0m6B2+TMQ5xAwKrlA/KGpdNCbJeSpd8QPHTsLXb2uOu5 08QPHTsLXb2u
Ou50NxB5+Yg+IsdRZBhbly8svDhoozwjwrsDA1m/aYcw7xE8ouRWReyk48kn bkxCAmmB3LxV
VYxSEACkIJ9kgchQAK810W5dsviNF4oWbjTd9mSjC2pW3XqtpO2rc8jEySzB Z21Muo3UXaiY
0c2Erlmo2cpCBjJrENoYJG8QPHTsLXb2uOu508QPHTsLXb2uOu51JLiZKgBo EBREwwdY2+va
EBZl6zMBYtj3KvcVu4WwyDBKAaSy0c8j1HSKYtRXagZB+4MLZuuk2MsodwZE VlVlVJ/yuyzp
/jxAIrDyAZ0Icv8A7It+mtd8QPHTsLXb2uOu51sWE9g46YYX+wvkcAbtfcR3 v9i8w3SW3tpH
T+S3RtNNvXqD1NKzqglis2AVcGlRJ4veOfpQbt+8Ou9a8TLMVjLJImcR2U26 HCZVlEjKIlcH
AFEziQ5BEGvyRTlMUQ6oCUQHlCueHaHwUwpgpUSeL3jn6UG7fvDrvWni945+ lBu37w671pDt
D4JClulRJ4veOfpQbt+8Ou9aeL3jn6UG7fvDrvWkO0PgkKW6VEni945+lBu3 7w671p4veOfp
Qbt+8Ou9aQ7Q+CQpbpUSeL3jn6UG7fvDrvWni945+lBu37w671pDtD4JClul RJ4veOfpQbt+
8Ou9aeL3jn6UG7fvDrvWkO0PgkKW6VEni945+lBu37w671p4veOfpQbt+8Ou 9aQ7Q+CQpbpU
SeL3jn6UG7fvDrvWni945+lBu37w671pDtD4JClulRJ4veOfpQbt+8Ou9aeL 3jn6UG7fvDrv
WkO0PgkKW6VEni945+lBu37w671p4veOfpQbt+8Ou9aQ7Q+CQpbpUSeL3jn6 UG7fvDrvWni9
45+lBu37w671pDtD4JClulRJ4veOfpQbt+8Ou9aeL3jn6UG7fvDrvWkO0Pgk KW6VEni945+l
Bu37w671p4veOfpQbt+8Ou9aQ7Q+CQpbpUSeL3jn6UG7fvDrvWni945+lBu3 7w671pDtD4JC
lulRJ4veOfpQbt+8Ou9aeL3jn6UG7fvDrvWkO0PgkKW6VEni945+lBu37w67 1p4veOfpQbt+
8Ou9aQ7Q+CQpbpUSeL3jn6UG7fvDrvWni945+lBu37w671pDtD4JClulRJ4v eOfpQbt+8Ou9
aeL3jn6UG7fvDrvWkO0PgkKW6VEni945+lBu37w671p4veOfpQbt+8Ou9aQ7 Q+CQpbpUSeL3
jn6UG7fvDrvWni945+lBu37w671pDtD4JClulRJ4veOfpQbt+8Ou9aeL3jn6 UG7fvDrvWkO0
PgkKW6VEni945+lBu37w671p4veOfpQbt+8Ou9aQ7Q+CQpbpUSeL3jn6UG7f vDrvWni945+l
Bu37w671pDtD4JClulRJ4veOfpQbt+8Ou9aeL3jn6UG7fvDrvWkO0PgkKW6V Eni945+lBu37
w671p4veOfpQbt+8Ou9aQ7Q+CQpbpUSeL3jn6UG7fvDrvWvwvmCxsbJCu5yj 3UmQvyRzpOQA
Pui1pDtD4JC82JeQzI1jRez3EvGLJjhPdlxyW75o3Bc2HUY/fOt2mVJPeLro GUPspkIQu0I6
FIUocgAFZ7BXK7lmy2c0+h0y62JYPNrc82Ocq0WUVx/c7zdb7iqRN7sb1XZ2 tdneH002h1i6
5uEBaWVLmt+8sMiRL8hCnOxk58EFilHqCJDoAYAHyh0r8wnCDx1yyKURbmG6 Mg7XNsoNWVwg
qoobrFKVEREf4qrj4KcDs1JU1/6y/ZDg/wDumsdjdZGPLnFe1cVMDG1suVYe 3pmKkWtxTjhh
qV4vGrEOmZFo42tBYmAQEC/JlEBHlrFWdiA7xMw1m78j4NNsu9v+KFBis8ES AcikYmAGUAmo
AIkARECDpr1B05ZRTQxwVIVVLDWHMUwAJTFuByICHXD+wa6Ng2yrsG1itTAJ E2IkXBBkdhXN
t+xUtv2U0KhIBjIwbEEQe0KJsOcteNjWyW6Fz5k7ktCVWlpl/JRdhGinceKr 6YevwOCslFKL
HOBHREzD0hfjQaEAdTGl5C1mjizSWVdjo9woHjAZSS803QOaTIKe7UMuRNMi RhUDUTlKmUg7
QgBShoAePimOfYyiPb913jTimOfYyiPb913jV9t26vt73GsMyTGGMzJ4ZX4r PYthobAxraM2
AElxOQAHHPsUUYW8HRk8wbvBhfNj4VuheQyCyFvN5q7JWUZQSapBTUJHM3rp VvHAZMxk9Gya
XSGEnyIiFerZvBm5KrEaSjCAwkeHQl7NfWk6Rk7xl3xUoF2JBWjEAcu1OKtd Uy7CKOwRLpt2
BNo2u8Yt40L4AW63u/HeUw/smJdvismspd2IAxrZZyYh1CoEUcNCFMoJElDA QB2hKmcdNCjp
H5eEZywHLtEzVZfxDrhjky7jXKXOOc5RxyMgjsIJB7TqV2AYTI1B7xke0WW1 Wnkly1WUsxdw
livjuY6bNMN3sldMk9cGfGiQhzOFFnDg51jixKCI7wxtR+OD8cET17SeTnLU W3Ya0F8K2jmK
gLAc2TFxz544cIkgXANyrMjkVUMCxTA0bgJ1NpT43yGDaNrpyfCI5Z1TAVLN HgEYRHQALjey
HUfvNe2lnzwDcF20MxWBpwAdBEmM7UQ1+4hRxLs54DI5AFoHc1xb2EjIlQ0B kYbRlyvPzAPb
dbfgLlWwQy0hKKYS25JIuprcBKSk9dEjMvnCaBTFQRF1IuF1gRSKY4JogcE0 9s2yUNodfRvH
AvDjM3lvvHL9i5Di/tu7nE9GS7Yh9g4pKSDkNshv3ChR0OU37kxSj5VYEmej A1QQKnmBwQMI
joABjI2H/wDQV4bVzW4UW9Gqx5Mc8G3G8kXjoThiwgXTfuVF9nTcD8jvNnXy 9NdA10qHPe54
cZ8+SBrWtgQqSWdkY4e/KVARGXTLrivl4xNsu1QO0wzv/FaEdluG02Qk2CJh uyGKXYL0hdOM
dKAB0pABMtreC74ONbINY923JibisviFizijPBO4oX65b7rmi7AD7tBImvSo IiqtsagAiKpx
2SFEqZJKSzXWItrucT8JT6dXZxTSHT/NqzEFjStdIgW2ZXD6RERDQGGIG+15 dP3DQfLDSrGo
SMvJA1YPF3InlexxxCPirf8AYD8J9yxTZSj+BuyUiOazVMR2G78jByiSQSLt GAE3JVSgBjBp
oIhWBe8GJkaeoRLBPAtNkxhmZWaETE3DIsmLtoV2o7I0eNW7giL9sRdZU5G7 kiqSe8MBClKO
lSYe+bzTOKakXZ5TFHQxRvJQBAfYdfzn8vDzus7tzU7zqGuLIwyIMixsb37b m/Mo4Ypm8iO6
1uyw8BotFvPg9cp1/X47xHuOwpgZJ7cTO4FU2F8zLNmSXaikKMimzbuyN0XQ AgmUVyJlUOQo
kOYxTGAfBenBxZPb9j2kZO4aSSCbM8toeFvaYjVXKUm8M9ftnCjR2kd01WcH MoZssJ0dR0Ag
AABUg8/l4ed1nduanedOfy8PO6zu3NTvOoBIaGgGBlY2sBbSwA7BGSm+Ium5 59/zJPeV7b6L
irYl7Eg4GORZsWEyZuzaNkwImgkSLelIQpQ5ClAoAAAHUAK0/MNZOLl23g5W w9lbuhUnLCJ0
m7QXZAqItl35lW6hXDxubZEHCRwEBMUTEADFOXaIbOqTU3OXHCPZte12TWLk VHSp2lzGcKH1
arogUCmbph1VgHXa6hR5Bra+e62vRIw9mE/TW1Kq9rnOImdZ49kFcu1bJQ2r Ztw+zeRj5ZKE
bjtbMrKupVSJh7mZQ76Luhqe0t1FnQerSTh0qg4VcBKBuzJgo3DQETiXZWAo jvNQnXEqw7Ax
jsKVwuxTtBhP29OMztZaHk24KoOkTdUpij9wQHqgIAICAgA16kJfVn3K6TY2 5d0ZILrCqCKL
J+mqZQU11G6gABTCI7KyKqRtOodI5R0EogGe5jz3nO79jn/RXVtm2VNta1tR ohoiwi3PXtN1
GybLT2NznUyZJm548tO5QE24LrImVuZKawcfzyoxzmPSf3ZfM1MO27JwgZBV qi5fPFVkEBIc
dEkzlIQ4FOUpTkKYMvbPB75SbUl3lwsrHn3kjIu4Z1JyE7iFOSTh84iXfG45 ZdR29UMuogt8
idQTGEgAkYRTACVM3Mee853fsc/6Kcx57znd+xz/AKK5w94cHAmREHsMjwNx obrfCwtLYt/b
7DwUPXlkDyk31bsfbExhzJNUYqQl3jF1A3nLxbwhpRyd1IpC7Zuklzt3CxxO o2MoKJtChsaE
KAZ9XA+08KIWfujLfhTbqF1OrKY29Fx0nKOGUWq0jyuAYM1N0muDZBMXKwCZ JAx9k+ggbZKA
SFzHnvOd37HP+inMee853fsc/wCis3NxUnU8gc/Aj6nxKuCMYcbkfcH5gHtu ouyLZaoTJblM
sjLTCCzONtRGxILx6JiIOHypzLulUym6YCGXUUMUB5QKIAPUryY7ZYWGOGKN rYsoY337Zcjb
dvTNvuSWPItGgzERKrxqz1msuq1Vctds0U12XLFZq7R6cyS6ZxKYsm8x57zn d+xz/oqPLtzP
5cLAu97h9feYSx4SfjVU0pGEl7sZtnjU6iRFkyqIqKgcgmSVTUKBgARKoQwc hgEdalV9SoXn
M3VGta1sLVoLIbhDZOJ9jXdhddE/aFoYe3C5uC3MH7ZQjW1qtpdeKfxarxJv xMXDTabSLgxm
zVwg0MuYzkyBl1l1VpLxHdb+ds8n/wB5FB/92vq1pLNVlmX/AGjMbYZ+X9xd 7If/ANLXgubF
Cw7sXiZOw8TbOkl4aVF0ugrdCRCCQ7VwjptpgoJR1V1DUvLsjy1k8uc1XbAK kClafz+Xh53W
d25qd517Le48SHenFLYtdXUu0G7uxY2odfkZdSs55HwKmFFliZScVsL44IKz MdIVZqggk0Zu
p6ylnL7iSACRsgoqlIopm3afJ0iSZTGMopsAdQ4m37DvB6Yg5kl2Yl3YzuGW aCYsSZlEHZNW
BTFEp1CInXXEVzAYxBVE/ImOwQpAOsKuUeXJiPHpAs/tm10CCbZA612LFAR6 2osuryDXr8/l
4ed1nduanedeBsn6L+wdh2kbRRoQ8ZGXGOwEkdlrcF6m0e2fae1UjTqVJBzs 0eYAK2W4PlC+
+s1fyBrJSnyycf38/wCUNaFIXleD9gux4jZxN8iYm1z5KDpqAhrpxOvZdYh3 g5cqOOZdnF3i
gm059FB01HX6Dr355HwK8uF612WNfcZc0hfWEkuwSdzceVjccPLrLptpFIhT gkoRZAd41XKC
hi70pTal0AS6lKIa1YmEeLbjDG3MEMRX8axtC3UG5F2LKfcy0hNGQOVRMXT5 ZBsGyZQu2chE
Q2vkQEpdS1tfP5eHndZ3bmp3nTn8vDzus7tzU7zrqbttdtPAPldYO2ak5+I/ NbhStP5/Lw87
rO7c1O86/KmIN2Il21WVmlLqAamvVQA1EdA/8z69cs8j4FbwtypWlt8R7mdy KkO0b2Uq7RBA
Vmqd7HMoQFhVBERKDPUNsW6+zr8luVNNdg2md4pjn2Moj2/dd40nkfApCy9K xHFMc+xlEe37
rvGnFMc+xlEe37rvGk8j4FIWKxiwFwMzEWyhZWYDBi076hmr8r5tEXjbjWTa ouikOmVcqTkh
yFUAiqhQOAbQFUMGuhh10W1uDj4POx7mjr1srIdgzDzMO/RfREvF4XxLd0xd JHBRJdFVNuB0
lCHKUxTlEDFMUBAQEK3S7cQLssCONMX2xs2EaEVBI7qXvRRsmU48gFEyjMAA R06nVrXE80No
K/tWImFRv+bigmP/AMtUbwC0qQwlbpevkktD1RK/m17VJ8T7DVujNnjVIEvO WjgJe8cnuGJG
okNpbEIO0O9QObXl05B05A5Orrbo1yXBc89ZsquygTRi82qdq/hp870qo8z3 oBpq3TKJfkum
Aw8oaacuoVluX56PG31fR/wXgq02cB7z60VaktClmwupmj9Xq3wOgqm7JM+3 OWO2U9epx336
vVecBLij7qtTM3NxkgLpFTEF4mC4gbpjJ2nCJmDpg15DFENfL05OSpuydvtz lyt1PXqcc9+L
1djml7nA2MfVHNOAAqXbrv217EteSvi+LmYQ0LDMFn0xMSrwjdqxaokFRVdZ VQQIkmQhTGMc
wgUpSiIiABWPwpxisbG7C628aMMJ7mnbV3wDOat2S4sqhxti6QIugtu1ilUT 2k1CG2TlKYNd
DAAgIVCOY6TYWvi9aOLGYIeP4L23svJJJEdhrbU8kuVVpcEymOvHI5vslEim pEotwUkg4SXI
Qj+E9Pgr5DY4MLLgTa6mA1nh/wC5WlbYhErLDdWSkrjaRMetJvlthFBMTqG6 vIAeUHlj9Ty6
iHEbNbI2K6nVJJgVinbrFu6dtFY4qxlSrKoJEAVzu0Em+hnBBMorokUCqiKm iKol26+lHkhb
KyTATCqksguBCBqY4JLEUEoB5YiBBDT6tVsLmOwywRPdMfizdl73Q9s+OSmF XCbPZTFFcyZC
FBw4WKkgntGKYzlZRJoUOMmBQpGTsGvn7Xs/t72htey7J7LIYarnBzyxtQA4 YZTDHPYcT3uk
OGIAUyDGIFbto0nbBtVZ0zSZigSIEw6oSARhZaWkicQjIq0+GuKRL/txjNLR izFV9Ftn6Ldc
olMZBdMDpn0EAEo6DoYohqUwCA68gjXt1wtVjRknKSs5lXxcZWJC4jrWVJ4p KNINSFbyKUlz
MFQ6SMqeQK3F0JSb0WgAAGAxgKXUQyWSu3bvg7VRnbjxeuO8U37ZR63kbpZO GztJN0RsdNud
JwcyqRygkZQ6ZtkCKOTlIkgmBEU4oy18GZYTqTuy+szsJejp87xxuG6oi1Xe KssrbqqRppZ5
GvDQ6D4Y8xtN0tsqI7QHADHKBw5O3ZRtdN1Nu3MwPDf2jTEhwcwEWJEkFxAD oGpAK8nYq9ba
vZLKzmYajiBEgwC15kkSIxBsm+cZlWubZustkniBO4QW9j5ZsteltMlXc5ZU VdLNeYZJJlAx
hVZlV3qegCXlOUA6YOXlrCWhnyyv3FYeG98XLjLbtnq4sQjKTse3r0uFlHyc kRykmomikgdY
RWVAFCFMVIVNDDoAjyCNHrPy3Z3eiZsy9LwwPuFOMt2/71cyiMU8tBlbjdCW aSSTd9HItjFk
nG8Ms3O5O+U329OYxETgImJolycHPnGLYUbYj2zb6kGt55eLPsadjbSuKzEG sI7jm6yTpvIu
Jhk7cptynX3xF4rfH3hTiCe0VNSrUXB7QXcd3yzFUu7IhgkzBPOF6L2Br3AZ DFzyLAO3Nxi0
xwF1d5/wwGSCLzFHytv8XotK7k8TkrFOxUn4wohIqRXNAq2wLre8X2v7C2tj b458Z2P3VTPh
vmXwCxkn5y1cIccrPuqUtl1xa5I227mavnEStqIbpymgoYyB9SmDZOBR1KPW qi2KeWPNKtmB
nH1qYSzzuKWxzjriY3aynokDDHr2ApbirspFniSu9aPNlVUhkyGOkYDIAsbV MP3wZuT/ADC4
M4rWbO422rfcYXDXCVazW724Z2zzRrw6i7MxiRyMFHpO12mrQVSqyKqaxBU0 3JzKKqBaiWv6
LjEAXyk7vEbcIcIg54rGWEHOqHNAcBmBbOJeRnx6MGRlFx0pHRbml/CpzS/h Vr/NL+FTml/C
qmMK+FbBzS/hU5pfwq1/ml/CpzS/hUxhMK2JGQ21iE2uqYArWcvXzNP8Ypr8 6u69qOkNuQQJ
tdVYofjCucmH+TLMVwjeZjHpS7eEyx3wrsLC3E8bWsqzsEbtJb4gopGspZ25 drkSOZ0J1ZQQ
KBg1KBBDa02SgaZqjsP0QiGeua6j0rnx4wNLfTtc+/4Qhu9KeMDS307XPv8A hCG70rdZroPS
ufHjA0t9O1z7/hCG70p4wNLfTtc+/wCEIbvSiLoPSufHjA0t9O1z7/hCG70p 4wNLfTtc+/4Q
hu9KIug9K58eMDS307XPv+EIbvSnjA0t9O1z7/hCG70oi6D0rnx4wNLfTtc+ /wCEIbvSnjA0
t9O1z7/hCG70oi6D0rnx4wNLfTtc+/4Qhu9KeMDS307XPv8AhCG70oi6D0rn x4wNLfTtc+/4
Qhu9KeMDS307XPv+EIbvSiLoPSufHjA0t9O1z7/hCG70p4wNLfTtc+/4Qhu9 KIug9K58eMDS
307XPv8AhCG70p4wNLfTtc+/4Qhu9KIug9K58eMDS307XPv+EIbvSnjA0t9O 1z7/AIQhu9KI
ug9K58eMDS307XPv+EIbvSnjA0t9O1z7/hCG70oi6D0rnx4wNLfTtc+/4Qhu 9KeMDS307XPv
+EIbvSiLoPSufHjA0t9O1z7/AIQhu9KeMDS307XPv+EIbvSiLoPSufHjA0t9 O1z7/hCG70p4
wNLfTtc+/wCEIbvSiLoPSufHjA0t9O1z7/hCG70p4wNLfTtc+/4Qhu9KIug9 K58eMDS307XP
v+EIbvSnjA0t9O1z7/hCG70oi6D0rnx4wNLfTtc+/wCEIbvSnjA0t9O1z7/h CG70oi6D0rnx
4wNLfTtc+/4Qhu9KeMDS307XPv8AhCG70oi6D0rnsrwBVyJJmVjOG7z4JuSg ItzucexWTKf9
yJ0+Khtl101LqGocmoVvHAb5mcf8wGWzEPDzM5fZbuvHA/HS5cMJG9OJlbqX CSLMgKb1VMnS
lUMRwUg6cpt2BjCJhMYSK6NKUoiUpSiJSlKIlKUoiUpSiJWKvbyMOv5H5Zay tYq9vIw6/kfl
lqr+oVIzVdMIbja2dYcjPKLLlWf3xcW+BqBjLvVizj5uimUA6ZQ27RSTKXyg IAcgBWWxUu1p
f2XC9lnqDpB7G2y9XWj3wiVdg6TbnVSN1eQQMUpynDkHQBAa1LCO87xjoN6y icE7ilEW153M
CUkzk4dJJbanpEREhXD9JUADbEg7RC6iU2moaCObxive9XWBl6NnWAdzsk17 SkSLPF5OFMRE
otlA2zglIHOJSgIiIFKY2mugCPIPnScHdouyBiC0DLX8wFf7Icb76j6ujBfK Nn9aJ/khVLst
fzAV/shxvvqPq6MF8o2f1on+SFdFD4jvXErKt1R64Be1SlK61zpUezVi48u5 l27h8bOKNFXK
h2rXmS1NuUxMIlJqZARHQNA1ERHk6o1IVKIo08T3MX2fP/czTvevEvhdj66O CjnG9JQwBoBl
IJkI6dblb1KFKIooWwdxscAJXGMDM4CGgge3WI6h1uVtXoKZc8RVtN7fsIbT qbVoxw6f5rUz
UpkihJ1levF7s8cuu3VtnXZ3tlxhtNetq1rXbmyAWveqe5vK2sO5YnL0knhh CrhyhoPIdkPl
clT9M3haVuysVBXBdEcwfTrs7WEZvHqaSsguRE6xkkCGEBVOCSSiglKAiBEz mENCiIZGpkpA
VRluCNy1uDidfLzgicxjamE+CFuCIj1+WPr8+NC5ZPS5YHe4dbfg6rd0pJRV E8aFyyelywO9
w62/B1PGhcsnpcsDvcOtvwdVu6UkoqieNC5ZPS5YHe4dbfg6v4bggssJ/ksu GBw/x4G234Oq
3lKSUVfMMMlI4M3Zb89YCkBGxlvteJMragYFrFsG7YzhVwcEm7RFNIgisuso YQLqJjibl5Sn
sHSlQiUpSiJSlKIlaHipl7w1xHZyEgfDy1Rn3+625ySthm7WNs7BenFZI+38 bLsBtAOgaaaa
BpvlKSQirqOQ+FENBh7AEB6oeJrDd5VjJTg2sNJvY5s4dYWu91ruuNYTQSmx rprptMR010D1
qs7Spkoqo+NU4DdhHBv3GLe7wrwq8Ezl3X/b8A8Fj6jqO3gnbo8vX+V9W0pS SkBVEHgiMsxh
ExsumB4iPVEcDrb8H08aGyy+lzwP9w62/B9W7pSSip8vwPeWZYdtPAPB1sfT TeMcH4FuYP4j
JMSiH6eWvAPA3ZcBKYg4WYfaGDQf94sfr9weL8n3KuRWOta8LSviKNO2VdEd MMSu3DUzyLep
uEgXQWOiukJ0xENtNVM6Zy66lOQxRABAQqFEBVHa8Dbl0ZKAq0w2sZMwAIAY lnMgHQfq7ivY
W4IbA1ZHcGs60Sl5P2u12hBD7pUQEKuDSilU7JwP2BaZQBO1LXLp1DFt9uA+ vuta8S3A54Fr
KCqeBgwEeqBI4pQ9YCaVcmlEVWsNODfhMDnaknhM9jIwXEg1eSTdqwITj52x VyIgocCAY2wV
y4ApRNs/HTdQdk5bRpioKZRWIUpxKG0UptQAfLAB0DX1gr9UoiUpSiKvOJSR Fs0UAdYu1xO1
7jdtgNygmuD6HRBUA82Ca6xQN1QBQ2nVqNML+E7wbxAx7Lg00a3UhAyT0Yq0 cUX0ecls3PMp
mUBxFsXojsqrE3ZgKPIRY6axEjHMkIG3TMJdr6xswEFcDaypWcItbtwMhQiF GpVEznfRCpTG
4yukXZ0QOHIIjqIcmmoh6cRjbHM41tDKZaroI0aGTM1agWF3aJkzAZMSFB/o USiACXQOQQAQ
6ledvGteQV1hpLAvZZNG8divIRzJIE0EsUTGSRKPSkFS2SKn0DytpRQ5x08s 4j5dVyuX56PG
31fR/wAF4Kp/s64j3ffbi5zwL2MB5ibtEZSBkRWTAtskT6bcqKE5RIIhoYeQ Q10HUArLiQ6d
IZsMaiIOVCAN8RwiBDiHLzsQlX2UgvMKlWwCk/K9bR7PwszC24uiKaza7DA6 IIaCCxrNgjK6
/V2xNUq5W7uRi8CYJia3rhXEnGvjrG1n7lI2rpUelUSRMQ3V0HQR0HUB5QEK j7BZVNaAzOHS
OBgC/nJREOuFowYCHrgNbHl9jST1h2PBvJGRSamhptc6TCVXa7ahJBApTGFE 5BNoChwABEQ6
Yah7gHOLcrfVWaOiMSl7n9b+hO7e0mU73r0LWlLRsa2I2ybJwwnoeGh2CLGI iIrD2RbtWLVI
gJpIIpJtgIkmQhSlKQoAUpSgAAABWk4gzFk4b33C2tONbpNHSUPIyEjOpXlI bqIRaqskt6uQ
V9QQEzwu2qGoIgXbOAJAoqluniYW3553F23SXfFUD3m1k6CyPP639Cd29pMp 3vWEeI2S/fqS
Tiwbx3qy29U3drTRCmPsgXXZKiBeXQBENNBERHqiIjn7NsqFgpVV20cyixjM lyiWQnHbogfG
xMAgRZU5QMAlDQwBqHX5Rr1LuvKOtFshv2y7t48V3UdGMiAZd2ppqIEARAAA AARMYwgUodUQ
1DXVlatSGIOjslUeyk+zhPav5FXTEwkajExlmXamg3TAiRBsuVMOgeWJjNxE wj1RERERHURE
RGvY5/W/oTu3tJlO96wSt24qxSQys9hKiLEobRyxE8Dp4mXyxFEyKZR06xFD j1gGtkhpqKuK
KQnIN+m6aOkwUQXSHkMUf4+UB8oQHQQEBAQAQEKyFc1XE8eYI+asA1ogLwc/ rf0J3b2kyne9
Of1v6E7t7SZTvevdXcINUDunS5EkkyCdRVU4FKQoBqIiI8gAAeWNam1vu+7p S5qYeYdIu4we
VB/NS4seNE8o6KYIqnEo+UJwT16vU5aPq4BfyBPySyz/AD+t/QndvaTKd705 /W/oTu3tJlO9
69S1b2RuB44gpSJXipdmUDuYt4Yom3YjoCqZiiJVUxEBDaKPIIaGAoiAVm6l ry4SEssfz+t/
QndvaTKd705/W/oTu3tJlO96yFKtLkssfz+t/QndvaTKd705/W/oTu3tJlO9 6yFKS5LLx25e
yDu4WDULYudMVXqRAUcWhIpJl1OAamOdACkL1zGEAAOURAKhrgrvmp5t/tml PgnbdTpBfLxn
9dp/lBUF8Fd81PNv9s0p8E7brSiSagnQ/RUf1fXNW9pSldaxSlKURKUpREpS lESlKURKUpRE
rm3cma3HXLxlnx+yVBiRNSuMcHiklZ+EE3NSyzmReM7sX3sG9FdUxlFeJkcO yCcREQLEH5eS
uklQTiXwd+X3FbO7Y2fq6FJ0t6WFEKsI1g1kCEi3upHJEHDpAUxMqu3K8eAi cDl2OMqagbUN
K4Wuqhr7sdZw/hkOMfxENwA/hDyeCvjcymXM67SHN/xCQAf4RixEcS0BVnuH NqXIAnmQdw2H
CNyz1ivsObWipxzzVkJe65KQjmjJs5lDpmcuHhyKLFMINkd8oUpigVRUwCP5 bcKLnPsawr7u
rEfCRGWi7GTtycdX4vgHeVkxq0QvLJtZlmDS4BKqLxq0MZymumsomco6nSLs GKNm8R+Dwy94
tnxdLiCM6/RxmWh17jRJJggMc5i0E02TlgoiQirdZMySSwHE5xBUgGDQOlrw w+Qtq9wkvzBf
GzNbizijD4gWmvbsgF9ScVtMGSqKiRxbFYR7VMFRKoIisqRVQRKXUw6aDc1K he6q8YnWMZAw
0dHl0wSYABaYmLGgp0wxlNphtgTmQJEnn0ZF5veJgitlvcL7jtduLN3YSQ+H 9oJu5LG6BtrB
pc7Z0oEvby8y/jZN85KDgu8WRCElliCmJCAQW4mKbptqQOG4vO+7RwKwsZ2L IYjFGex+tqJl
4vCm7VYSbmWK4uAWYN3abtpsCqAAHTLpF1ABEwaaht2G3BI5WsLr+wGxJgJO 615PL1ar2CtA
76TQOWUI6RMkd1IgCAC4cgKjhQpyCkAHdLDsjtAAS5mGyz2JmWTspO+5aXaB YmIMZeMRzJXS
T3z5iY5kU1t4mfaRETjtFLsmHQNDlo1lMCi1xnDVYXGM2NewZHMuawvcDm55 bkEY94fVfEB1
N4A0e5j+Ogc4Nacw1oOa5s4JcIbjrlkt7EKzoFPEZZ1cGPrOycObDxsRmr3u ixQCDGRfOZFC
LF2/kW6hETrNkG7hcDFUAeMETA4py1I8J5niicFH0rNYJ8ynMVia0gpLF2by +Xqwg0oJeOVd
c2Od11upTRNwmDFQoLiimdQiplwIOyE+5h+C1y+Zi8b3+YmXvC9bZu14wiSt 5SzphBmdjIxi
rgzGXREyBx44mk7cthE4nRUbrGTUSOGmmZDJNiAWwAtQvCG49BNc3QkhvXmn ADICXc7rinFx
iOZ/F9Om2AabW30+1ry1UOe6kS/rdEdzd2M5mXYXuOUB8YnEANFobVAZ1el4 uxnT8OJrRmCW
ThAJnScF88d/31ingFh81xMwvxBiMUbYu+Rm71w+j3SLJdWKUZlbgzIq8XFv /bJyLpKnWMVR
MSgYuyIDDcNmCxOzMZ5cGrilCQUVMQF7Y2WrBuG0cso2IlGnSZtF10hcAdU+ ykQygEUTA47W
zu9Q0nqN4LTCK1bNs2Lw1xpxHte6rKuOanGOJMXIxy80+ezBzqSpnQPGK7JY rk5wMYnFilIZ
NMUgT2A09zATgxcC8vVy2bdlrX3fEq9smfuyZYLXDMIOTPHVxKgq/FycG5Tq gBw1TEDFMGo7
YqVchrnunLA8f5nEQRAFgCWgwDxwiVQY2tbGeMH/AChrxBmbk4HESRwkxJqf lxzdcIlgpwYu
FONl54qWxeqV3zhGEhfMphVcUwrZceB5Ey0jLEayy7qWKZVFs3IZPiZEN8Bl DGKXUL55QsW3
WOeXu38T3uMFiX6rJEWE11YatlkId7sLHIAoorOHCiJigUCKJnVOYihTlEeT QIwsbg1V8JsP
DYU4M57McrRt9nNHf2xGw763lCW+kdRwooybi5h1RXbGM4Edl4LkxN0nsHJo O1K2V7LPYWU3
CkuFNgS0zJprTD+Yl5u4nhF38rJPXKjp27XOmRNPeKLKHMIJkIQuoAUhQAAq Q4ONQm0kEaiw
tpa8mc/zAyLVBDm4OEg6HrX1k9ERlF7EQ6RKUpVFKUpSiJSlKIlKUoiUpSiJ SlKIlc+fifb5
V5y/t+MRPyY6ug1c+fifb5V5y/t+MRPyY6iLoNSlKIlKUoiUpSiJSlKIlKUo iVir28jDr+R+
WWsrWKvbyMOv5H5Zaq/qFSM1X/AvyHLerC5/hFJVsmN/zvd9+ouU96K1reBf kOW9WFz/AAik
q2TG/wCd7vv1FynvRWvP/d9y6ndYKFctfzAV/shxvvqPq6MF8o2f1on+SFUu y1/MBX+yHG++
o+rowXyjZ/Wif5IVvQ+I71xKpW6o9cAvapUD39wnWQzDaYSg7izKwbldVsVc p4BFxKogQTGK
AGWZJKplPqUdSCYDAAlEQ0MURwfjvfB2+mF/6JS/eldUhY4HaKylKrX473wd vphf+iUv3pTx
3vg7fTC/9EpfvSkhMD9FZQddOSuTNjZir4dY7YVmtbNVf0rj3L4hXy2xUwhe 3q+VjGKraHnV
IxmtEmU4vHoEOi0FsJCJg7IG/EVzEBQl
Re: CreateViewAndElementRequest wont create anything [message #502551 is a reply to message #502538] |
Tue, 08 December 2009 19:20 |
Ugo Sangiorgi Messages: 44 Registered: July 2009 |
Member |
Hi Artur, sorry, it IS working now. :)
Altough i must agree with you that it should be a GMF command, if i just create a Command to set the model objects on my model, it doesnt work (editor gets dirty, nothing is added nor showed up).
It only works within a AbstractEMFOperation (which cannot be converted to a Command).
Even though it throws an exception, this surprisingly does not keep me from changing the model (?)
There should be a less complicated way of doing this.
But its working anyway.
Thank you so much!
Artur Kronenberg escreveu:
> didn't quite get your post - does it work now? Or do you need any more
> help?
> Normally, if you are working within the DND policy, you shouldn't need
> an AbstractEMFOperation, since the Command itself should take care of
> that (it is after all an GMF command).
> If you don't have writing permissions that means that at least your code
> is working, you would just have to figure out, how to get that writing
> permission.
Re: CreateViewAndElementRequest wont create anything [message #502795 is a reply to message #502734] |
Wed, 09 December 2009 17:39 |
Ali Koudri Messages: 118 Registered: July 2009 |
Forget it,
doing so disable moving view parts in the diagram. Instead, I have
overriden the preventDropElement() method in the same class. It works
better,
Cheers.
exquisitus a écrit :
> Hi Ugo,
> I have asked quite the same question just before you and nobody answered
> me. Actually I had the same problem and after extensive debugging I have
> resolved my problem in a different manner. I noticed that the Drop
> request was processed twice: by my XXXDragDropEditPolicy which returns
> an executable command and by my XXXCanonicalEditPolicy which return an
> UnexecutableCommand. Since the two commands were chained, this resulted
> in an unexecutable command. Then I have overriden the
> undertandRequest(req) method of my XXXCanonicalEditPolicy this way:
> @Override
> public boolean understandsRequest(Request req) {
> if (RequestConstants.REQ_DROP_OBJECTS.equals(req.getType())
> || req instanceof DropObjectsRequest)
> return false;
> if (RequestConstants.REQ_CREATE
> .equals(req.getType())) return true;
> return super.understandsRequest(req);
> And it worked !
> Cheers.
> Ugo Sangiorgi a écrit :
>> Hello,
>> I have a DragDropEditPolicy and i want to create a command inside
>> getDropObjectsCommand to add a node into a compartment.
>> But i want to set some parameters of my model before inserting it (i
>> mean, to create the EObject, set the properties, and then create the
>> EditPart)
>> I have a getCreateElementAndViewCommand took from GMF itself, but this
>> doesnt seems to work:
>> CreateViewAndElementRequest req = new
>> CreateViewAndElementRequest(MolicElementTypes.Sketch_3001,ed itor.getDiagramEditPart().getDiagramPreferencesHint());
>> this.getCreateCommand(req); //this have canExecute() = false
>> Does anybody have a clue on how can i do that?
>> thanks
Current Time: Thu Apr 25 12:57:40 GMT 2024
Powered by FUDForum. Page generated in 0.03227 seconds
