Home » Modeling » OCL » EMF with OCL
Re: EMF with OCL [message #503267 is a reply to message #502133] |
Fri, 11 December 2009 16:06 |
--=-glDIMt9zz7GfR2E6mXBz
Content-Type: text/plain
Hi, Timothy,
The Helios M4 milestone of EMF has support for pluggable constraint
languages for the definition of operations and constraints in dynamic
models (and possibly also properties; I'm not sure). Because it
supports dynamic models, you shouldn't need to generate any code at all
to test your OCL constraints. You should be able to test everything in
the reflective Ecore model editor, on "dynamic instances."
Check it out in the EMF New and Noteworthy page or in Bugzilla for
details:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=255786
https://bugs.eclipse.org/bugs/show_bug.cgi?id=255469
HTH,
Christian
On Sun, 2009-12-06 at 13:28 +0100, Timothy Marc wrote:
> Hi all,
> i want to enhance my ecore model with OCL constraints. For simple
> constraints (like the length of a string) this can be easily done, but
> what is the best strategy to test much more complex and complicated
> constraints? Allways regeneratinhg and than restarting the whole model
> and editor seems to be very unhandy. Does anyone have some good hints
> how to test the constraints? It should be possible to use the OCL
> Interpreter, i think.
> And one more question. Are the constraints being checked when the model
> is manipulated programmatically or is this only possible via the editor?
> I think i can assume the answer, but to know it is much better :-)
> Thanks a lot and a nice 2. Advent
> Timothy
Content-Type: text/html; charset="utf-8"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.24.1.1">
</HEAD>
<BODY>
Hi, Timothy,<BR>
<BR>
The Helios M4 milestone of EMF has support for pluggable constraint languages for the definition of operations and constraints in dynamic models (and possibly also properties; I'm not sure). Because it supports dynamic models, you shouldn't need to generate any code at all to test your OCL constraints. You should be able to test everything in the reflective Ecore model editor, on "dynamic instances."<BR>
<BR>
Check it out in the EMF New and Noteworthy page or in Bugzilla for details:<BR>
<BR>
<A HREF="https://bugs.eclipse.org/bugs/show_bug.cgi?id=255786">https://bugs.eclipse.org/bugs/show_bug.cgi?id=255786</A><BR>
<A HREF="https://bugs.eclipse.org/bugs/show_bug.cgi?id=255469">https://bugs.eclipse.org/bugs/show_bug.cgi?id=255469</A><BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
Hi all,
Timothy
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-glDIMt9zz7GfR2E6mXBz--
Re: EMF with OCL [message #503582 is a reply to message #503267] |
Mon, 14 December 2009 19:44 |
Timothy Marc Messages: 547 Registered: July 2009 |
Hi Christian,
that sounds promising. Just for the sake of clarity: the capability to
weave OCL constraints into the ecore model code is still present in
galileo, isn't it?
Thanks again
Timothy
Christian W. Damus schrieb:
> Hi, Timothy,
> HTH,
> Christian
>> Hi all,
>> Timothy
Re: EMF with OCL [message #503591 is a reply to message #503582] |
Mon, 14 December 2009 15:24 |
--=-5nKnxIdA2L6MEjKEW9uc
Hi, Timothy,
This is a new feature of EMF in the Helios release. And, strictly
speaking, even in Helios EMF provides only the API that extenders can
plug into. The MDT OCL component would have to provide implementations
of the EMF extension points ... I think that Kenn already provided
patches that do this, but I don't know anything more about it.
In Galileo, only MDT UML2 has code generation support for OCL-defined
constraints and operations, but it uses the Ecore environment, not the
UML environment, so it's somewhat limited by that. Hopefully that
capability of UML2 will be superseded in Helios by providers that it
plugs in to the new EMF API, but that would be a question for the UML2
team.
Christian
On Mon, 2009-12-14 at 20:44 +0100, Timothy Marc wrote:
> Hi Christian,
> galileo, isn't it?
> Thanks again
> Timothy
> > Hi, Timothy,
> > HTH,
> > Christian
> >> Hi all,
> >> Timothy
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Timothy,<BR>
<BR>
This is a new feature of EMF in the Helios release. And, strictly speaking, even in Helios EMF provides only the API that extenders can plug into. The MDT OCL component would have to provide implementations of the EMF extension points ... I think that Kenn already provided patches that do this, but I don't know anything more about it.<BR>
<BR>
In Galileo, only MDT UML2 has code generation support for OCL-defined constraints and operations, but it uses the Ecore environment, not the UML environment, so it's somewhat limited by that. Hopefully that capability of UML2 will be superseded in Helios by providers that it plugs in to the new EMF API, but that would be a question for the UML2 team.<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
Hi Christian,
galileo, isn't it?
Thanks again
Timothy
> Hi, Timothy,
> HTH,
> Christian
>> Hi all,
>> Timothy
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-5nKnxIdA2L6MEjKEW9uc--
Current Time: Thu Apr 25 13:18:48 GMT 2024
Powered by FUDForum. Page generated in 0.02610 seconds
