[ATL] combined rules don't work [message #50794] |
Thu, 05 July 2007 12:37  |
Originally posted by: heggly.gmx.net
I got two rules (returnType and moduleName) accessing the same metamodel and
creating instances of EClass and EAttribute respectively.
Every rule on its own works fine, but when trying to use both rules in one
module (test.atl) I get this strange error message...
Any ideas???
Thanks a lot,
Felix.
****** BEGIN Stack Trace
message: trying to register several rules as default for element
IN!<unnamed>: 'returnType' and 'moduleName'
A.main() : ??#28 null
local variables = {self=test : ASMModule}
local stack = []
A.__matcher__() : ??#3 null
local stack = []
A.__matchmoduleName() : ??#36 null
local variables = {a=IN!<unnamed>, self=test : ASMModule}
local stack = []
NativeOperation public static void
org.atl.engine.vm.nativelib.ASMTransientLinkSet.addLink(org. atl.engine.vm.StackFrame,org.atl.engine.vm.nativelib.ASMTran sientLinkSet,org.atl.engine.vm.nativelib.ASMTransientLink)
args = [TransientLinkSet {TransientLink {rule = 'returnType', sourceElements
= {s = IN!<unnamed>}, targetElements = {t = OUT!<notnamedyet>}, variables =
{}}}, TransientLink {rule = 'moduleName', sourceElements = {a =
IN!<unnamed>}, targetElements = {b = OUT!<notnamedyet>}, variables = {}}]
****** END Stack Trace
Execution terminated due to error (see launch configuration to allow
continuation after errors).
Re: [ATL] combined rules don't work [message #50825 is a reply to message #50794] |
Thu, 05 July 2007 13:51   |
Frédéric Jouault Messages: 572 Registered: July 2009 |
You get this error message because you try to match the same element (at
least) twice with standard rules.
You may not actually want to do this, and your guards may accidentally
make the sets of matched elements overlap. Please, check if it is the case.
However, if you really do want to match the same element several times,
you may use (unique) lazy rules to achieve this.
Frédéric Jouault
Felix Förster wrote:
> Any ideas???
> Thanks a lot,
> Felix.
> local stack = []
> local stack = []
> local stack = []
Re: [ATL] combined rules don't work [message #50852 is a reply to message #50825] |
Thu, 05 July 2007 14:29   |
Hey, thanks,
that was exactly the case.
They do that in the Family2Person example also so I thought it must work.
However in the example they use conditional which exludes one rule or the
other.
Felix.
"Fr
Re: [ATL] <superimpose...> within <am3.atl ...> doesn´t work [message #51075 is a reply to message #51045] |
Fri, 06 July 2007 13:22   |
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Jeanette Kelling a écrit :
Hi Jeanette,
> I use Ant to run my ATL transformation, but within <am3.atl ...> I can´t
> use the element <superimpose path= ...>,
> but all other elements like inmodel, outmodel and library work.
> The following error message appears, when I use the superimpose element:
> The <am3.atl> type doesn´t support nested "superimpose" element.
> For developing my transformation I use ATLBundle_20070217 and the UML2_2.0.2
> plugin.
> What´s the problem? What can I do to make it work?
I think the problem comes from the fact that the bundle contains a
version of the org.eclipse.gmt.am3.tools.ant plugin which doesn't
support the use of superimposition.
You may try to checkout the latest versions of ATL & AM3 from the
Eclipse CVS by following the process described in
http://wiki.eclipse.org/ATL/How_Install_ATL_From_CVS/.
Note that for AM3 the repository path is "/cvsroot/technology". You then
have to select the "org.eclipse.gmt/AM3" folder and to checkout the
following plugins:
* org.eclipse.am3.core
* org.eclipse.am3.tools.tge
* org.eclipse.am3.ui
* org.eclipse.gmt.am3.dsls.km3
* org.eclipse.gmt.am3.tools.ant
> Thanks in advance for your help
> Jeanette
Hugo
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
FUDForum. Page generated in 0.01495 seconds
