Home » Eclipse Projects » SWTBot » Get the tree node(Get the tree node)
Get the tree node [message #502025] Fri, 04 December 2009 15:03 Go to next message
I have a tree structure as shown below:
root
Project1
Element1
The "root" node is hidden. Project 1 has a context menu with one of the menu items as "Open project".
Selecting "Open Project" menu item opens expands the tree and on expanding "Element 1" is present at the first node. It works fine upto this point. "Element 1" has a context menu with menu item "Manage Element 1". I want to select this and click to open up a view. I'm unable to do so. I need help.
These are few lines of the code that I was trying to achieve what I want.
SWTBotTree tree = tree();
SWTBotTreeItem[] array = tree.getAllItems();
//There has to be atleast one project in the tree view
assertTrue(array.length > 0);
SWTBotTreeItem treeNode = tree.getTreeItem("Project1);
treeNode.select().contextMenu("Open Project").click();//works
//tree.select("Element 1").contextMenu("Manage Data Elements");//tried but did not work
// treeNode.getNode("Data Elements").select().contextMenu("Manage Data Elements")//tried but did not work
treeNode.select().contextMenu("Manage Data Elements");//tried but did not work
Can anyone let me know how to go about?
Thanks.
Re: Get the tree node [message #502030 is a reply to message #502025] Fri, 04 December 2009 15:24 Go to previous messageGo to next message
> but did not work
Any reason why its treeNode.getNode("Data Elements") and not
treeNode.getNode("Element 1") ? I'll figure its only a copy-paste error ;)
> not work
I did something similar and it would look like this:
treeNode.expand().getNode("Element 1").select().contextMenu("Manage Data
Elements").click();
It only adds an expand() call, but that worked for me... Although you
said that your treeNode was already expanded.
If it stills doesn't work, look closely at the thrown exception and
search for what is really failing. Might be it can't find your sub-item
or your context menu...
Hope this helps.
Pascal Gélinas | Software Developer
*Nu Echo Inc.*
http://www.nuecho.com/ | http://blog.nuecho.com/
*Because performance matters.*
Re: Get the tree node [message #502035 is a reply to message #502030] Fri, 04 December 2009 15:52 Go to previous messageGo to next message
thanks for the reply.
Yes that was copy paste problem.
The node expands when "Open Project" menu item is selected. I tried your suggestion again, but it did not help.
I get the following error and here is the stack trace:
org.eclipse.swt.SWTException: Failed to execute runnable (org.eclipse.swt.SWTException: Widget is disposed)
at org.eclipse.swt.SWT.error(SWT.java:3884)
at org.eclipse.swt.SWT.error(SWT.java:3799)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.j ava:195)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4312)
at org.eclipse.swtbot.swt.finder.finders.UIThreadRunnable.run(U IThreadRunnable.java:76)
at org.eclipse.swtbot.swt.finder.finders.UIThreadRunnable.syncE xec(UIThreadRunnable.java:172)
at org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot.syncExe c(AbstractSWTBot.java:475)
at org.eclipse.swtbot.swt.finder.widgets.SWTBotTreeItem.getItem s(SWTBotTreeItem.java:659)
at com.compwuare.dataprivacy.bottests.DataElements.CreateDataEl ementTest.testOpenProject(CreateDataElementTest.java:47)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at junit.framework.TestCase.runTest(TestCase.java:168)
at junit.framework.TestCase.runBare(TestCase.java:134)
at org.eclipse.swtbot.swt.finder.SWTBotTestCase.runBare(SWTBotT estCase.java:228)
at junit.framework.TestResult$1.protect(TestResult.java:110)
at junit.framework.TestResult.runProtected(TestResult.java:128)
at junit.framework.TestResult.run(TestResult.java:113)
at junit.framework.TestCase.run(TestCase.java:124)
at junit.framework.TestSuite.runTest(TestSuite.java:232)
at junit.framework.TestSuite.run(TestSuite.java:227)
at org.junit.internal.runners.JUnit38ClassRunner.run(JUnit38Cla ssRunner.java:79)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.r un(JUnit4TestReference.java:46)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:467)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:390)
at org.eclipse.swtbot.eclipse.core.RemotePluginTestRunner.main( RemotePluginTestRunner.java:64)
at org.eclipse.swtbot.eclipse.core.UITestApplication.runTests(U ITestApplication.java:117)
at org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.java:71)
at java.lang.Thread.run(Thread.java:595)
Caused by: org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:3770)
at org.eclipse.swt.widgets.Widget.error(Widget.java:463)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:336)
at org.eclipse.swt.widgets.TreeItem.getItems(TreeItem.java:783)
at org.eclipse.swtbot.swt.finder.widgets.SWTBotTreeItem$18.run( SWTBotTreeItem.java:661)
at org.eclipse.swtbot.swt.finder.widgets.SWTBotTreeItem$18.run( SWTBotTreeItem.java:1)
at org.eclipse.swtbot.swt.finder.finders.UIThreadRunnable$3.doR un(UIThreadRunnable.java:169)
at org.eclipse.swtbot.swt.finder.finders.UIThreadRunnable$1.run (UIThreadRunnable.java:89)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3855)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3476)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at com.compuware.frameworks.workbench.Application.start(Unknown Source)
at org.eclipse.swtbot.eclipse.core.UITestApplication.start(UITe stApplication.java:56)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Re: Get the tree node [message #502039 is a reply to message #502035] Fri, 04 December 2009 16:11 Go to previous message
Hmmmm, the dreaded "Widget is disposed" :P
I don't know what's the underlying logic or what you are really doing in
your test case, but here's my guess:
When you "Open the project" the previous tree item "Project1" gets
disposed and replaced by another tree item widget that is expandable.
What you could try is this:
SWTBotTree tree = bot.tree();
treeNode = tree.getTreeItem("Project1");
treeNode.getNode("Element 1").select().contextMenu("Manage Data Elements");
If this still doesn't work, I can't really think if anything else
without knowing the details...
Hope this helps.
*Nu Echo Inc.*
Previous Topic:Hyperlink text
Next Topic:New SWTBot build
Current Time: Tue Jul 08 21:05:30 EDT 2025
Powered by FUDForum. Page generated in 0.07079 seconds
