Home » Language IDEs » Java Development Tools (JDT) » TreeViewer with special rendering for items(org.eclipse.jface.viewers.TreeViewer)
TreeViewer with special rendering for items [message #501960] Fri, 04 December 2009 10:27 Go to next message
Question about TreeViewers :
The basic rendering often presented as examples is a class implementing the interface ILabelProvider which defines two methods public Image getImage(Object element) and public String getText(Object element). This instance of ILabelProvider is parameter of the setLabelProvider method on the Treeviewer.
The question is :
Is it possible to build a TreeViewer with special rendering for items visible in the tree (setting a more sophisticated rendering with StyledText for instance)?
I want for example to have a particular background color for special items in the tree or special fonts, ...
Any help would be appreciated.
Re: TreeViewer with special rendering for items [message #502027 is a reply to message #501960] Fri, 04 December 2009 15:11 Go to previous messageGo to next message
cdsosi wrote:
Best asked on eclipse.platform.swt, probably.
Re: TreeViewer with special rendering for items [message #502218 is a reply to message #502027] Mon, 07 December 2009 04:40 Go to previous messageGo to next message
I 'll also try on eclipse.platform.swt (Wink) but i think anyone can help on this forum as Java Outline display special rendering for types on member variables!!
Re: TreeViewer with special rendering for items [message #502401 is a reply to message #502218] Mon, 07 December 2009 20:11 Go to previous messageGo to next message
cdsosi wrote:
> I 'll also try on eclipse.platform.swt (;)) but i think anyone can help
> member variables!!
Have you taken a look at the jdt.ui code that does that? If you have a question
about how or where a feature in JDT UI is implemented, this is a good forum to
ask in but it will help if you can be specific about which particular JDT
feature you're asking about, and where you've already looked.
Re: TreeViewer with special rendering for items [message #503710 is a reply to message #502218] Tue, 15 December 2009 07:23 Go to previous messageGo to next message
cdsosi wrote:
See org.eclipse.jface.viewers.DecoratingStyledCellLabelProvider.
Dani
> Regards
Re: TreeViewer with special rendering for items [message #503881 is a reply to message #501960] Wed, 16 December 2009 03:48 Go to previous message
Thanks Dani for your reply.
I 've already had a look at the class you mentioned and that is, for the moment, enough for what I wanted to do...
Previous Topic:Delete Me
Next Topic:JavaRuntime.getDefaultVMInstall() throws a NullPointerException on Mac OS X
Current Time: Fri Apr 18 12:27:54 EDT 2025
Powered by FUDForum. Page generated in 0.04166 seconds
