Write Image uploaded by Upload Widget to File [message #501507] |
Wed, 02 December 2009 15:31 |
hannes Messages: 12 Registered: October 2009 Location: Germany |
im trying to write the FileInputStream of an uploaded jpeg to a file.
Im using the following code
if(uploadItem.getContentType().equals("image/jpeg"));{
ImageRegistry registry = new ImageRegistry(Display.getCurrent());
registry.put("image", ImageDescriptor.createFromImage(new Image(Display.getCurrent(), uploadItem.getFileInputStream())));
Image image = registry.get("image");
byte[] imageData = image.getImageData().data;
try {
fos = new FileOutputStream(properties.getProperty("imagePath")+uploadItem.getFileName());
fos.write(imageData);
fos.close();
} catch (Exception e1) {
e1.printStackTrace();
But this throws the following Exception
## total: 2395521
filename : IMGP0847.JPG
path : IMGP0847.JPG
content-type : image/jpeg
stream : java.io.FileInputStream@4b12d9
2009-12-02 16:36:08.250::WARN: ERROR: /rap
org.eclipse.rwt.internal.resources.ResourceRegistrationException: Failed to register resource 'image-11362219'.
at org.eclipse.rwt.internal.resources.ResourceManagerImpl.register(ResourceManagerImpl.java:239)
at org.eclipse.rap.ui.internal.servlet.ResourceManagerFactory$ResourceManagerWrapper.register(ResourceManagerFactory.java:130)
at org.eclipse.swt.internal.graphics.ResourceFactory.registerImage(ResourceFactory.java:346)
at org.eclipse.swt.graphics.Image.init(Image.java:178)
at org.eclipse.swt.graphics.Image.<init>(Image.java:121)
at gui.apps.BannerUpload.handleUploadFinished(BannerUpload.java:128)
at gui.apps.BannerUpload.access$1(BannerUpload.java:105)
at gui.apps.BannerUpload$2.uploadFinished(BannerUpload.java:77)
at org.eclipse.rwt.widgets.UploadEvent.dispatchToObserver(UploadEvent.java:92)
at org.eclipse.rwt.internal.events.Event.processEvent(Event.java:44)
at org.eclipse.swt.events.TypedEvent.processEvent(TypedEvent.java:129)
at org.eclipse.rwt.widgets.internal.uploadkit.UploadLCA$1.run(UploadLCA.java:78)
at org.eclipse.rwt.lifecycle.ProcessActionRunner.executeNext(ProcessActionRunner.java:57)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.readAndDispatch(RWTLifeCycle.java:238)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:981)
at org.eclipse.rwt.widgets.Upload.performUpload(Upload.java:251)
at gui.apps.BannerUpload$1.widgetSelected(BannerUpload.java:67)
at org.eclipse.swt.events.SelectionEvent.dispatchToObserver(SelectionEvent.java:194)
at org.eclipse.swt.events.TypedEvent.executeNext(TypedEvent.java:169)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.readAndDispatch(RWTLifeCycle.java:240)
at gui.AppStarter.startApp(AppStarter.java:60)
at gui.AdDeskNavBar$1.widgetSelected(AdDeskNavBar.java:50)
at gui.AdServerControl.createUI(AdServerControl.java:59)
at org.eclipse.rwt.internal.lifecycle.EntryPointManager.createUI(EntryPointManager.java:92)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:227)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:115)
at org.eclipse.rwt.internal.lifecycle.UIThread.run(UIThread.java:80)
Caused by: java.io.IOException: Read error
at java.io.FileInputStream.readBytes(Native Method)
at java.io.FileInputStream.read(Unknown Source)
at java.io.BufferedInputStream.fill(Unknown Source)
at java.io.BufferedInputStream.read1(Unknown Source)
at java.io.BufferedInputStream.read(Unknown Source)
at org.eclipse.rwt.internal.resources.ResourceUtil.getAvailableCount(ResourceUtil.java:203)
at org.eclipse.rwt.internal.resources.ResourceUtil.readBinary(ResourceUtil.java:187)
at org.eclipse.rwt.internal.resources.ResourceManagerImpl.register(ResourceManagerImpl.java:234)
... 36 more
Can anyone help me please ?
I also tried to write out the InputStream byte by byte, but this also dont work.
hannes
[Updated on: Wed, 02 December 2009 15:42] Report message to a moderator
Re: Write Image uploaded by Upload Widget to File [message #501698 is a reply to message #501507] |
Thu, 03 December 2009 14:09 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi hannes,
it's look like your image input stream can't be read. Check it if it is
already closed or not.
Best,
Ivan
On 12/2/2009 17:31, hannes wrote:
> Hello,
> byte[] imageData =
> try {
> fos = new
> fos.close();
> ## total: 2395521
> path : IMGP0847.JPG
> stream : java.io.FileInputStream@cb754f
> 2009-12-02 16:28:07.796::WARN: ERROR: /rap
> org.eclipse.rwt.internal.resources.ResourceRegistrationExcep tion:
> Failed to register resource 'image-16491778'.
> at
> org.eclipse.rwt.internal.resources.ResourceManagerImpl.regis ter(ResourceManagerImpl.java:239)
> at
> org.eclipse.rap.ui.internal.servlet.ResourceManagerFactory$R esourceManagerWrapper.register(ResourceManagerFactory.java:1 30)
> at
> org.eclipse.swt.internal.graphics.ResourceFactory.registerIm age(ResourceFactory.java:346)
> dont work.
> Regards,
> hannes
Re: Write Image uploaded by Upload Widget to File [message #501910 is a reply to message #501507] |
Fri, 04 December 2009 12:42 |
Yep i did close it .
These lines were executed before the other lines of my first post
try {
if (uploadItem.getFileInputStream() != null) {
uploadItem.getFileInputStream().close();
} catch (IOException e) {
e.printStackTrace();
And i only get the Exception for binary Files, like Images.
i tried also this way, with same results.
Dont work for binary files, all other file are fine.
try {
InputStream fin;
int ch;
StringBuffer strContent = new StringBuffer("");
try {
fin = uploadItem.getFileInputStream();
while ((ch = fin.read()) != -1) strContent.append((char) ch);
fin.close();
catch (Exception e)
I also tried it with a buffered read , same results.
Works with e.g. text files , dont works with binary files
try {
InputStream is = uploadItem.getFileInputStream();
BufferedReader reader = new BufferedReader(new InputStreamReader(is));
StringBuilder sb = new StringBuilder();
String line = null;
try {
while ((line = reader.readLine()) != null) {
sb.append(line + "\n");
is.close();
System.out.println(sb.toString());
catch (Exception e)
[Updated on: Fri, 04 December 2009 13:15] Report message to a moderator
FUDForum. Page generated in 0.03969 seconds
