Home » Eclipse Projects » Rich Client Platform (RCP) » RCP and java web start : program arguments problem(program arguments -nl fr don't work with java web start)
RCP and java web start : program arguments problem [message #501434] Wed, 02 December 2009 10:41 Go to next message
Hoang-Quan is currently offline Hoang-QuanFriend
I have developing an RCP application and in parameters "program arguments" I put the following options:
<launcherArgs>
<programArgs>-nl fr </ programArgs>
</ launcherArgs>
When I run the application from .product everything works properly.
When I deploy the application using Java Web Start the launcherArgs option is not taken.
Someone would have an idea?
Thank you.
Hoang-Quan
Hoang-Quan
[Updated on: Wed, 02 December 2009 10:42]
Report message to a moderator
Re: RCP and java web start : program arguments problem [message #501437 is a reply to message #501434] Wed, 02 December 2009 10:49 Go to previous messageGo to next message
Originally posted by: wangqs_eclipse.yahoo.com
nhq@infomaniak.ch wrote:
> Hello,
> I am developing an RCP application and in parameters "program arguments"
> <launcherArgs>
> </ launcherArgs>
> Thank you.
> Hoang-Quan
You need specify this argument in your JNLP file.
Q.S. Wang
http://www.myeclipsedev.com/
Re: RCP and java web start : program arguments problem [message #501438 is a reply to message #501437] Wed, 02 December 2009 10:58 Go to previous messageGo to next message
Wang thank you for your reply.
I've tried to make the following arguments:
<application-desc main-class="org.eclipse.equinox.launcher.WebStartMain">
<argument>-nl fr</argument>
</application-desc>
<resources>
<jar href=" plugins/org.eclipse.equinox.launcher_1.0.101.R34x_v20080819. jar "/>
<!-- Information usually specified in the config.ini -->
<property
name="osgi.nl"
value="fr"/>
</resources>
And it does not work, do it the right parameters?
Thank you in advance.
Hoang-Quan
[Updated on: Wed, 02 December 2009 11:11]
Re: RCP and java web start : program arguments problem [message #501441 is a reply to message #501437] Wed, 02 December 2009 11:13 Go to previous messageGo to next message
No Message Body
Hoang-Quan
Re: RCP and java web start : program arguments problem [message #501681 is a reply to message #501438] Thu, 03 December 2009 12:55 Go to previous messageGo to next message
> </application-desc>
> <resources>
> <jar href="
> <property name="osgi.nl" value="fr"/>
> </resources>
The line
should work. I have tried about 2 years ago, but I don't know if web
start is really a good choice. :)
Make sure that you have flushed the web start cache and included all the
locale properties files.
Q.S. Wang
icon9.gif  Re: RCP and java web start : program arguments problem [message #501888 is a reply to message #501681] Fri, 04 December 2009 10:10 Go to previous messageGo to next message
Thank you for your reply.
These options do not work.
Six months ago I made an application Eclipse RCP / Java Web Start in French and it works very well.
There are no parameters "nl" in the jnlp file. Unfortunately I can not find the source of the problem.
I continue to look ...
Hoang-Quan
RCP and java web start : program arguments problem [message #502918 is a reply to message #501888] Thu, 10 December 2009 10:25 Go to previous messageGo to next message
In searching I found the source of the problem.
When exporting from the feature.xml, the jars Language Project Babel manifest.mf file is not correct.
In fact, it miss the file header:
Manifest-Version: 1.0
Bundle-Vendor: Eclipse.org
Fragment-Host: org.eclipse.core.commands
Bundle-Version: 3.4.0.v20081123043401
Bundle-Name: org.eclipse.core.commands French NLS Support
Bundle-SymbolicName: org.eclipse.core.commands.nl_fr ;singleton=true
When I export the project since .product file, manifest.mf in jars are correct.
Someone would have any idea ...
Hoang-Quan
[Updated on: Thu, 10 December 2009 10:35]
Re: RCP and java web start : program arguments problem [message #509334 is a reply to message #502918] Fri, 22 January 2010 03:02 Go to previous messageGo to next message
Arnaud Brunet is currently offline Arnaud BrunetFriend
Hi Hoang-Quan,
I have the same problem. Do you have any solutions ?
Arnaud
Re: RCP and java web start : program arguments problem [message #509371 is a reply to message #509334] Fri, 22 January 2010 09:29 Go to previous messageGo to next message
Hi Arnaud,
It's a bug of jdk jarsigner. This bug appears when the update 1.5.0_13.
You can see this post : http://www.eclipse.org/forums/index.php?t=msg&goto=50386 2
Hoang-Quan
Re: RCP and java web start : program arguments problem [message #509386 is a reply to message #501434] Fri, 22 January 2010 10:41 Go to previous message
Thanks a lot.
Previous Topic:IProxyService
Next Topic:64 distro for eclipse.
Current Time: Tue Sep 10 07:05:43 GMT 2024
Powered by FUDForum. Page generated in 0.04529 seconds
