Home » Archived » Java WorkFlow Tooling (JWT) » Newbie Question/Issue: JWT Hanging on startup
Re: Newbie Question/Issue: JWT Hanging on startup [message #501139 is a reply to message #500950] |
Tue, 01 December 2009 09:21 |
Edmund Young Messages: 4 Registered: November 2009 |
Thanks a lot Marc,
I just grabbed the log entry as I started a JWT project. Looks like a conflict with an existing binding:
!ENTRY org.eclipse.jface 2 0 2009-12-01 00:57:28.148
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2009-12-01 00:57:28.148
!MESSAGE A conflict occurred for ALT+COMMAND+Q P:
Binding(ALT+COMMAND+Q P,
ParameterizedCommand(Command(org.eclipse.ui.views.showView,Show View,
Shows a particular view,
Category(org.eclipse.ui.category.views,Views,Commands for opening views,true),
org.eclipse.ui.handlers.ShowViewHandler@3b54fd7a,
[Lorg.eclipse.ui.internal.commands.Parameter;@48cd7304,,true),[Lorg.eclipse.core.commands.Parameterization;@283a30f3),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,cocoa,system)
[Lorg.eclipse.ui.internal.commands.Parameter;@48cd7304,,true),[Lorg.eclipse.core.commands.Parameterization;@463b627),
!SESSION 2009-12-01 01:13:05.835 -----------------------------------------------
eclipse.buildId=M20090917-0800
java.version=1.6.0_15
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product -keyring /Users/euser/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.jee.product -keyring /Users/euser/.eclipse_keyring -showlocation
!ENTRY org.eclipse.core.resources 2 10035 2009-12-01 01:13:15.862
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
I'll also install the 32-bit versions and see if the results are the same or different. Let me know how else I can help you, help me.
Thanks!
Ed
Re: Newbie Question/Issue: JWT Hanging on startup [message #501557 is a reply to message #501139] |
Wed, 02 December 2009 19:01 |
Marc Dutoo Messages: 71 Registered: July 2009 |
Member |
Hi Edmund
This log seems to talk about key binding conflict, we've already seen
some as you can see at :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=277436
However, I don't think that's the main problem for you.
You can change key bindings in Window > Preferences... > General > Key
by sorting them by Category.
Out of interest anyway, what's your locale ?
But I'm not sure it answers your previous problem:
"I'm relatively new to the Eclipse world, but I saw the potential of JWT
and jumped in. However, I am having difficulties getting started with
JWT. I have Snow Leopard (10.6.2) running Eclipse 3.6 (64bit) with Java
1.6 JVM (64bit). When creating a new JWT workflow I immediately run
into problems. Eclipse seems to properly setup a new JWT workflow but
begins to use a great deal of CPU (100%) and there doesn't seem to be
any errors generated. Do I need to install Java 1.5 JVM and somehow get
Eclipse to point to it. Is there something I'm missing from this
installation?"
Marc
Edmund Young a écrit :
> Thanks a lot Marc,
> ParameterizedCommand(Command(org.eclipse.ui.views.showView,S how
> View,
> [Lorg.eclipse.ui.internal.commands.Parameter;@48cd7304,,true ),[Lorg.eclipse.core.commands.Parameterization;@283a30f3),
> View,
> [Lorg.eclipse.ui.internal.commands.Parameter;@48cd7304,,true ),[Lorg.eclipse.core.commands.Parameterization;@463b627),
> same or different. Let me know how else I can help you, help me. :lol:
> Thanks!
> Ed
Re: Newbie Question/Issue: JWT Hanging on startup [message #501576 is a reply to message #501557] |
Wed, 02 December 2009 21:13 |
Hi Marc,
The binding probably aren't the issue, you're right. But after running JWT for longer, I found a runtime exception. This might be helpful. I pasted it below.
I'm located in sunny California. Well not so sunny in San Francisco today, but that's another story.
Where are you?
Ed
!ENTRY org.eclipse.jface 2 0 2009-12-01 01:37:33.396
!SUBENTRY 1 org.eclipse.jface 2 0 2009-12-01 01:37:33.400
org.eclipse.ui.handlers.ShowViewHandler@22d15c2c,
[Lorg.eclipse.ui.internal.commands.Parameter;@5efa5e8f,,true),[Lorg.eclipse.core.commands.Parameterization;@7562f00),
[Lorg.eclipse.ui.internal.commands.Parameter;@5efa5e8f,,true),[Lorg.eclipse.core.commands.Parameterization;@2b27acc3),
!ENTRY org.eclipse.core.net 1 0 2009-12-01 01:37:33.963
!MESSAGE System property http.nonProxyHosts has been set to local|*.local|169.254/16|*.169.254/16 by an external source. This value will be overwritten using the values from the preferences
!ENTRY org.eclipse.jface 2 0 2009-12-01 01:37:42.947
!MESSAGE Ignored reentrant call while viewer is busy. This is only logged once per viewer instance, but similar calls will still be ignored.
!STACK 0
java.lang.RuntimeException
at org.eclipse.jface.viewers.ColumnViewer.checkBusy(ColumnViewer.java:763)
at org.eclipse.jface.viewers.ColumnViewer.refresh(ColumnViewer.java:541)
at org.eclipse.ui.navigator.CommonViewer.refresh(CommonViewer.java:358)
at org.eclipse.ui.navigator.CommonViewer.refresh(CommonViewer.java:515)
at org.eclipse.ui.internal.navigator.resources.workbench.ResourceExtensionContentProvider$3.run(ResourceExtensionContentProvider.java:294)
at org.eclipse.ui.internal.navigator.resources.workbench.ResourceExtensionContentProvider.runUpdates(ResourceExtensionContentProvider.java:306)
at org.eclipse.ui.internal.navigator.resources.workbench.ResourceExtensionContentProvider.processDelta(ResourceExtensionContentProvider.java:116)
at org.eclipse.ui.model.WorkbenchContentProvider.resourceChanged(WorkbenchContentProvider.java:106)
at org.eclipse.core.internal.events.NotificationManager$2.run(NotificationManager.java:291)
at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:285)
at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:149)
at org.eclipse.core.internal.resources.Workspace.broadcastPostChange(Workspace.java:313)
at org.eclipse.core.internal.resources.Workspace.endOperation(Workspace.java:1022)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1809)
at org.eclipse.jdt.internal.core.JavaModelManager.initializeAllContainers(JavaModelManager.java:2554)
at org.eclipse.jdt.internal.core.JavaModelManager.getClasspathContainer(JavaModelManager.java:1773)
at org.eclipse.jdt.core.JavaCore.getClasspathContainer(JavaCore.java:2652)
at org.eclipse.jdt.internal.core.JavaProject.resolveClasspath(JavaProject.java:2578)
at org.eclipse.jdt.internal.core.JavaProject.resolveClasspath(JavaProject.java:2679)
at org.eclipse.jdt.internal.core.JavaProject.getResolvedClasspath(JavaProject.java:1866)
at org.eclipse.jdt.internal.core.JavaProject.buildStructure(JavaProject.java:424)
at org.eclipse.jdt.internal.core.Openable.generateInfos(Openable.java:258)
at org.eclipse.jdt.internal.core.JavaElement.openWhenClosed(JavaElement.java:515)
at org.eclipse.jdt.internal.core.JavaElement.getElementInfo(JavaElement.java:252)
at org.eclipse.jdt.internal.core.JavaElement.getElementInfo(JavaElement.java:238)
at org.eclipse.jdt.internal.core.JavaElement.getChildren(JavaElement.java:193)
at org.eclipse.jdt.internal.core.JavaProject.getPackageFragmentRoots(JavaProject.java:1761)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerContentProvider.getPackageFragmentRoots(PackageExplorerContentProvider.java:316)
at org.eclipse.jdt.ui.StandardJavaElementContentProvider.getChildren(StandardJavaElementContentProvider.java:183)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerContentProvider.getChildren(PackageExplorerContentProvider.java:301)
at org.eclipse.jdt.internal.ui.navigator.JavaNavigatorContentProvider.getChildren(JavaNavigatorContentProvider.java:141)
at org.eclipse.jdt.internal.ui.navigator.JavaNavigatorContentProvider.getPipelinedChildren(JavaNavigatorContentProvider.java:162)
at org.eclipse.ui.internal.navigator.NavigatorContentServiceContentProvider.pipelineChildren(NavigatorContentServiceContentProvider.java:319)
at org.eclipse.ui.internal.navigator.NavigatorContentServiceContentProvider.internalGetChildren(NavigatorContentServiceContentProvider.java:255)
at org.eclipse.ui.internal.navigator.NavigatorContentServiceContentProvider.getChildren(NavigatorContentServiceContentProvider.java:604)
at org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren(AbstractTreeViewer.java:1346)
at org.eclipse.jface.viewers.TreeViewer.getRawChildren(TreeViewer.java:390)
at org.eclipse.jface.viewers.AbstractTreeViewer.getFilteredChildren(AbstractTreeViewer.java:636)
at org.eclipse.jface.viewers.AbstractTreeViewer.getSortedChildren(AbstractTreeViewer.java:602)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractTreeViewer.java:797)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:776)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:639)
at org.eclipse.jface.viewers.AbstractTreeViewer.internalExpand(AbstractTreeViewer.java:1585)
at org.eclipse.jface.viewers.AbstractTreeViewer.setSelectionToWidget(AbstractTreeViewer.java:2463)
at org.eclipse.ui.navigator.CommonViewer.setSelectionToWidget(CommonViewer.java:451)
at org.eclipse.jface.viewers.StructuredViewer.setSelectionToWidget(StructuredViewer.java:1711)
at org.eclipse.jface.viewers.AbstractTreeViewer.setSelectionToWidget(AbstractTreeViewer.java:2903)
at org.eclipse.jface.viewers.StructuredViewer.setSelection(StructuredViewer.java:1667)
at org.eclipse.jface.viewers.TreeViewer.setSelection(TreeViewer.java:1124)
at org.eclipse.ui.navigator.CommonViewer.setSelection(CommonViewer.java:382)
at org.eclipse.ui.navigator.CommonNavigator.selectReveal(CommonNavigator.java:362)
at org.eclipse.ui.internal.navigator.actions.LinkEditorAction$3.run(LinkEditorAction.java:101)
at org.eclipse.ui.internal.navigator.actions.LinkEditorAction$2.runInUIThread(LinkEditorAction.java:89)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:95)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3405)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3102)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
!SESSION 2009-12-01 11:14:48.155 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2009-12-01 11:15:19.789
Re: Newbie Question/Issue: JWT Hanging on startup [message #501594 is a reply to message #501576] |
Wed, 02 December 2009 23:37 |
I also found one more error that might be related:
!ENTRY org.eclipse.jface 2 0 2009-11-28 14:12:05.089
!SUBENTRY 1 org.eclipse.jface 2 0 2009-11-28 14:12:05.089
org.eclipse.ui.handlers.ShowViewHandler@6f262671,
[Lorg.eclipse.ui.internal.commands.Parameter;@31a5fdb9,,true),[Lorg.eclipse.core.commands.Parameterization;@8b49626),
[Lorg.eclipse.ui.internal.commands.Parameter;@31a5fdb9,,true),[Lorg.eclipse.core.commands.Parameterization;@7ed9d41),
!ENTRY org.eclipse.core.net 1 0 2009-11-28 14:12:05.362
!ENTRY org.eclipse.ui.workbench 4 2 2009-11-28 14:12:18.282
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 0
java.lang.ExceptionInInitializerError
at org.eclipse.dltk.ui.ProblemsLabelDecorator.decorate(ProblemsLabelDecorator.java:395)
at org.eclipse.ui.internal.decorators.LightweightDecoratorDefinition.decorate(LightweightDecoratorDefinition.java:263)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManager$LightweightRunnable.run(LightweightDecoratorManager.java:81)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManager.decorate(LightweightDecoratorManager.java:365)
at org.eclipse.ui.internal.decorators.LightweightDecoratorManager.getDecorations(LightweightDecoratorManager.java:347)
at org.eclipse.ui.internal.decorators.DecorationScheduler$1.ensureResultCached(DecorationScheduler.java:371)
at org.eclipse.ui.internal.decorators.DecorationScheduler$1.run(DecorationScheduler.java:331)
at org.eclipse.dltk.ui.DLTKPluginImages.create(DLTKPluginImages.java:462)
at org.eclipse.dltk.ui.DLTKPluginImages.createUnManaged(DLTKPluginImages.java:497)
at org.eclipse.dltk.ui.DLTKPluginImages.<clinit>(DLTKPluginImages.java:140)
... 9 more
!ENTRY org.eclipse.ui 4 4 2009-11-28 14:12:18.284
!MESSAGE Exception in Decorator. The 'PHP Problem Decorator' decorator will be disabled.
!ENTRY org.eclipse.ui 4 4 2009-11-28 14:12:18.297
!MESSAGE java.lang.ExceptionInInitializerError
!STACK 0
!SESSION 2009-11-30 23:33:58.602 -----------------------------------------------
Framework arguments: -product org.eclipse.epp.package.jee.product -keyring /Users/edmundyoung/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.jee.product -keyring /Users/edmundyoung/.eclipse_keyring -showlocation
!ENTRY org.eclipse.core.resources 2 10035 2009-11-30 23:34:21.233
Current Time: Thu Apr 25 04:01:31 GMT 2024
Powered by FUDForum. Page generated in 0.03435 seconds
