Home » Modeling » OCL » eGet(ref) does not return a collection but only its first element
Re: eGet(ref) does not return a collection but only its first element [message #500523 is a reply to message #500495] |
Thu, 26 November 2009 14:22 |
--=-M6uyN/wZxXDrNQkv6XY8
Content-Type: text/plain; charset="UTF-8"
Content-Transfer-Encoding: quoted-printable
Hi, Patrick,
You are correct: the Object return signature means that OCL thinks the
eGet operation is a scalar value. The multiplicity of a feature
determines whether it is a collection value, and if so, which kind of
collection.
In the OCL 2.0 language specification, collection types are quite
different from all others. In particular, there is no facility for
testing type conformance of collections nor for casting objects to a
collection type. Collections are a completely distinct type hierarchy.
The OCL 2.1 specification will change that, and it appears from previous
traffic in this newsgroup that Ed W. is working hard to update the MDT
OCL implementation for 2.1 conformance. OCL 2.1 (the language, not the
release) will allow the cast to collection type that you need. Whether
that will actually be available in Helios is a question for the MDT OCL
committers to answer. You might check their project plan and bugzilla
for more details on what to expect.
Christian
On Thu, 2009-11-26 at 12:43 +0100, Patrick K=C3=B6nemann wrote:
> Hi Newsgroup,
>=20
> I'm trying to validate some constraints on my model using EMF Reflection.
> However, a call on eGet does not return a collection of referenced elemen=
ts (as expected) but only the first element.
> Let me show the effect (using the OCL Console):
>=20
> Evaluating:
> self.modelElement.eGet(self.ref)
> Results:
> Entity Added
>=20
> If I don't use reflection but access the model directly, I get the expect=
ed result:
>=20
> Evaluating:
> self.modelElement.oclAsType(mymodel::Entity).multiReference
> Results:
> Entity Added
> Entity subAdded
> Entity root
>=20
>=20
> mymodel::Entity is just an EClass which has a reference (multiReference) =
to itself with cardinality *.
>=20
> The context element (self) has a reference to the EReference Entity.multi=
Reference ('ref') and to EObject ('modelElement').
>=20
> I guess the problem is that EObject.eGet(EStructuralFeature) as defined i=
n the ecore model returns java.lang.Object?
> Thus ocl does not now how to treat the result correctly?
> I also tried to cast it somehow (...eGet(self.ref)->asSet(), ...eGet(self=
..ref).oclAsType(...)), but no success yet.
>=20
> I need that feature, because I want to define the constraints without kno=
wing the exact model (mymodel in this case).
>=20
> Any help is appreciated.
>=20
> Best regards
> Patrick
Content-Type: text/html; charset="utf-8"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.24.1.1">
</HEAD>
<BODY>
Hi, Patrick,<BR>
<BR>
You are correct: the Object return signature means that OCL thinks the eGet operation is a scalar value. The multiplicity of a feature determines whether it is a collection value, and if so, which kind of collection.<BR>
<BR>
In the OCL 2.0 language specification, collection types are quite different from all others. In particular, there is no facility for testing type conformance of collections nor for casting objects to a collection type. Collections are a completely distinct type hierarchy.<BR>
<BR>
The OCL 2.1 specification will change that, and it appears from previous traffic in this newsgroup that Ed W. is working hard to update the MDT OCL implementation for 2.1 conformance. OCL 2.1 (the language, not the release) will allow the cast to collection type that you need. Whether that will actually be available in Helios is a question for the MDT OCL committers to answer. You might check their project plan and bugzilla for more details on what to expect.<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<BR>
On Thu, 2009-11-26 at 12:43 +0100, Patrick Könemann wrote:
<BLOCKQUOTE TYPE=CITE>
<PRE>
Hi Newsgroup,
However, a call on eGet does not return a collection of referenced elements (as expected) but only the first element.
Evaluating:
Results:
Entity Added
If I don't use reflection but access the model directly, I get the expected result:
Evaluating:
Results:
Entity Added
Entity subAdded
Entity root
mymodel::Entity is just an EClass which has a reference (multiReference) to itself with cardinality *.
The context element (self) has a reference to the EReference Entity.multiReference ('ref') and to EObject ('modelElement').
I guess the problem is that EObject.eGet(EStructuralFeature) as defined in the ecore model returns java.lang.Object?
I also tried to cast it somehow (...eGet(self.ref)->asSet(), ...eGet(self.ref).oclAsType(...)), but no success yet.
I need that feature, because I want to define the constraints without knowing the exact model (mymodel in this case).
Best regards
Patrick
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-M6uyN/wZxXDrNQkv6XY8--
Re: eGet(ref) does not return a collection but only its first element [message #500526 is a reply to message #500495] |
Thu, 26 November 2009 14:27 |
--=-WXkZaqhsdrp91rS7yT4b
Hi, Patrick,
In the mean-time, you can work around this problem by implementing a
helper operation in a custom OCL environment. You would probably need
to do it in Java; see the "Customizing the Environment" page in the OCL
Developer Guide documentation for the example of adding a regex
"matches(String) : boolean" operation to the String primitive type. You
could similarly add an "eGetCollection(EStructuralFeature) :
Collection(OclAny)" operation to OclAny that always returns a
collection, even if it is just a singleton containing the feature's
scalar value. You still won't be able to work around the absence of a
cast operation.
HTH,
Christian
> Hi Newsgroup,
>=20
>=20
> Evaluating:
> Results:
> Entity Added
>=20
ed result:
>=20
> Evaluating:
> Results:
> Entity Added
> Entity subAdded
> Entity root
>=20
>=20
>=20
>=20
>=20
>=20
>=20
> Best regards
> Patrick
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Patrick,<BR>
<BR>
In the mean-time, you can work around this problem by implementing a helper operation in a custom OCL environment. You would probably need to do it in Java; see the "Customizing the Environment" page in the OCL Developer Guide documentation for the example of adding a regex "matches(String) : boolean" operation to the String primitive type. You could similarly add an "eGetCollection(EStructuralFeature) : Collection(OclAny)" operation to OclAny that always returns a collection, even if it is just a singleton containing the feature's scalar value. You still won't be able to work around the absence of a cast operation.<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
Hi Newsgroup,
Evaluating:
Results:
Entity Added
Evaluating:
Results:
Entity Added
Entity subAdded
Entity root
Best regards
Patrick
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-WXkZaqhsdrp91rS7yT4b--
Re: eGet(ref) does not return a collection but only its first element [message #500536 is a reply to message #500526] |
Thu, 26 November 2009 14:41 |
--------------050403020707000205070003
Patrick, Christian,
Compliance with OCL 2.1 will not allow usage of eGet() because of a flaw
in the code itself.
bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=287052 describes the
same problem and the exact location of the code rejecting all other
values other than the first of the returned collection.
----------8<----------
if (value instanceof Collection) {
Collection<?> collection = (Collection<?>) value;
return collection.isEmpty() ? null : collection.iterator().next();
---------->8----------
I wanted to get rid of this bug, yet haven't found a more intelligent
workaround than the patch attached to that bug. And it seems I didn't
manage to convince Ed that this not working was an issue.
Laurent Goubet
Obeo
Christian W. Damus wrote:
> Hi, Patrick,
> cast operation.
> HTH,
> Christian
>> Hi Newsgroup,
>> Evaluating:
>> Results:
>> Entity Added
>> Evaluating:
>> Results:
>> Entity Added
>> Entity subAdded
>> Entity root
>> Best regards
>> Patrick
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------050403020707000205070003--
Re: eGet(ref) does not return a collection but only its first element [message #500541 is a reply to message #500536] |
Thu, 26 November 2009 15:05 |
--=-Fvyo5utFkOeY6l0l5y0l
Hi, Laurent,
Support for OCL 2.1 will have to revise this code. It is only as it is
now because of the need to coerce a collection value to a scalar.
Probably when support for casting to CollectionTypes is implemented,
this coercion of collection values should be eliminated altogether.
The actual reason why it was implemented in the first place (I think)
was to support the "indeterminate upper bound" (-2) of
EStructuralFeatures in feature maps (XSD-isms).
Christian
On Thu, 2009-11-26 at 15:41 +0100, Laurent Goubet wrote:
> Patrick, Christian,
> in the code itself.
> Laurent Goubet
> Obeo
--------8<--------
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Laurent,<BR>
<BR>
Support for OCL 2.1 will have to revise this code. It is only as it is now because of the need to coerce a collection value to a scalar. Probably when support for casting to CollectionTypes is implemented, this coercion of collection values should be eliminated altogether.<BR>
<BR>
The actual reason why it was implemented in the first place (I think) was to support the "indeterminate upper bound" (-2) of EStructuralFeatures in feature maps (XSD-isms).<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<PRE>
Patrick, Christian,
in the code itself.
bug <A HREF="https://bugs.eclipse.org/bugs/show_bug.cgi?id=287052">https://bugs.eclipse.org/bugs/show_bug.cgi?id=287052</A> describes the
Laurent Goubet
Obeo
</PRE>
</BLOCKQUOTE>
<BR>
--------8<--------
</BODY>
</HTML>
--=-Fvyo5utFkOeY6l0l5y0l--
Re: eGet(ref) does not return a collection but only its first element [message #500547 is a reply to message #500526] |
Thu, 26 November 2009 15:45 |
Patrick Konemann Messages: 116 Registered: July 2009 |
Hi Christian
Thank you for the information, that was helpful.
The eGetCollection workaround works fine :-)
Cheers
Patrick
On 26-11-2009 15:27, Christian W. Damus wrote:
> Hi, Patrick,
> cast operation.
> HTH,
> Christian
>> Hi Newsgroup,
>> Evaluating:
>> Results:
>> Entity Added
>> Evaluating:
>> Results:
>> Entity Added
>> Entity subAdded
>> Entity root
>> Best regards
>> Patrick
Current Time: Fri Mar 29 04:39:03 GMT 2024
Powered by FUDForum. Page generated in 0.04153 seconds
