Home » Eclipse Projects » Standard Widget Toolkit (SWT) » freezing swt gui
freezing swt gui [message #499731] Mon, 23 November 2009 21:21 Go to next message
larsk is currently offline larskFriend
Is there a way to "freeze" the update of the gui while I am making some changes and then after a while make the gui to update again? Is there maybe a way so I can make the program so I have to update the gui manually by running some function?
I hope that someone understands what I want to do.
Re: freezing swt gui [message #499942 is a reply to message #499731] Tue, 24 November 2009 14:48 Go to previous messageGo to next message
Grant Gayed is currently offline Grant GayedFriend
I think Control.setRedraw() is what you want here. If not then please
follow up.
Grant
<larsk7@gmail.com> wrote in message news:heeuc4$e5s$1@build.eclipse.org...
Re: freezing swt gui [message #500866 is a reply to message #499942] Sun, 29 November 2009 21:39 Go to previous messageGo to next message
Grant Gayed wrote on Tue, 24 November 2009 15:48
follow up.
Grant
Thanks for your reply!
I tested .setRedraw() but my gui is still changing when setRedraw is set to false.
In my application I set the setRedraw on a shell to false and then I dispose all the composites and labels on the shell. Then the app waits for some seconds and then I put some new composites and labels on the shell. But I don't want the gui to redraw/update/change until all the new composites and labels is put on the shell.
Is this the right way to go? Is it going to work with setRedraw when i dispose the composites and labels?
Re: freezing swt gui [message #501023 is a reply to message #500866] Mon, 30 November 2009 17:16 Go to previous messageGo to next message
I've looked into this a bit closer, and it appears that this case is not
currently working on Cocoa (it does work for me on win32 and gtk). I assume
you're using Cocoa? If so then this may not be supportable there (see the
"Note...hint" comment in setRedraw()'s javadoc). However it would not hurt
to log a report for this with swt to be investigated (
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=SWT ).
However if you're not on Cocoa then this should work. Does the snippet
below work for you? And if so, can you modify it to more closely resemble
your case and show the problem?
public static void main (String [] args) {
final Display display = new Display();
final Shell shell = new Shell(display);
shell.setBounds(10,10,200,200);
shell.setLayout(new GridLayout());
Composite composite = new Composite(shell, SWT.BORDER);
composite.setLayout(new FillLayout());
final Composite topComposite = composite;
composite = new Composite(composite, SWT.BORDER);
composite.setLayout(new GridLayout());
Button button1 = new Button(composite, SWT.PUSH);
button1.setText("Button 1");
Label label1 = new Label(composite, SWT.NONE);
label1.setText("Label 1");
shell.open();
display.timerExec(2000, new Runnable() {
public void run() {
System.out.println("shell.setRedraw(false);");
public void run() {
System.out.println("dispose the top Composite");
topComposite.dispose();
public void run() {
System.out.println("create some composites and
label2 and button2");
SWT.BORDER);
SWT.BORDER);
SWT.BORDER);
new Label(composite, SWT.NONE).setText("Label
2");
SWT.BORDER);
SWT.BORDER);
new Button(composite, SWT.PUSH).setText("Button
2");
shell.layout();
public void run() {
System.out.println("shell.setRedraw(true);");
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
display.dispose();
Grant
"larsk" <larsk7@gmail.com> wrote in message
news:heuplr$mu2$1@build.eclipse.org...
> > follow up.
> > Grant
to false.
Re: freezing swt gui [message #501036 is a reply to message #501023] Mon, 30 November 2009 18:46 Go to previous messageGo to next message
Thanks for your help testing!
Yes, I am working with cocoa. To bad that it doesn't work. Is there another way to do this that works under cocoa?
Grant Gayed wrote on Mon, 30 November 2009 18:16
Re: freezing swt gui [message #501260 is a reply to message #501036] Tue, 01 December 2009 16:53 Go to previous messageGo to next message
Perhaps you could use a StackLayout to first lay out your new set of
controls on a Composite that's not the top control (therefore not visible),
and then set this Composite to be the top control once all of its children
are there and ready to be shown? (then dispose() the no-longer-on-top
Composite with the old set of Controls now that it's no longer visible).
Grant
news:hf13ul$gi4$1@build.eclipse.org...
assume
the
hurt
&component=SWT ).
Re: freezing swt gui [message #501574 is a reply to message #501260] Wed, 02 December 2009 20:34 Go to previous message
Thanks for all help!
I have written a bug report to eclipse.
But I will also test your suggestion to create a new composite and then dispose the old one.
Grant Gayed wrote on Tue, 01 December 2009 17:53
Grant
Previous Topic:Is there a practical limit to the number of columns in a Table?
Next Topic:Get the TableEditors objects hosted in a TableItem
Current Time: Thu Feb 25 14:22:51 GMT 2021
Powered by FUDForum. Page generated in 0.01739 seconds
