[EMF Compare] rightParent reference in DiffGroups [message #499623] |
Mon, 23 November 2009 14:53 |
Originally posted by: mail.andreasscharf.com
I'm currently getting unexpected elements if asking a DiffGroup for the
element via group.getRightParent(). Until now I thouhgt that
'rightParent' always refers to some element within the right model. But
in my DiffModel I get an element from the left model side.
Use case: Comparison of two UML Models:
ModelA
- ClassFoo
- ClassBar
ModelB
- ClassFoo
- classBarProperty : ClassBar
- ClassBar
- classFooProperty : ClassFoo
- Association (with memberends classBarProperty, classFooProperty)
where ModelA is my left and ModelB is my right.
Amongst other I get a DiffGroup with rightParent ModelA. Is that
behavior correct? I already took a look at bugzilla concerning a
possible bug but found nothing. Perhaps I understand something wrong...
Andreas
P.s.: I'm working with the HEAD revision.
Re: [EMF Compare] rightParent reference in DiffGroups [message #499839 is a reply to message #499623] |
Tue, 24 November 2009 10:58 |
--------------090006040709090104050307
Hi Andreas,
This is a problem with us having only a "right"-named reference for the
DiffGroup, and an issue I always push the fixing for later. When the
element presenting a difference is not preset in the right model ...
well I set a reference to the left model in its stead.
Correction of https://bugs.eclipse.org/bugs/show_bug.cgi?id=243447 will
see the addition of a "leftParent" reference to the diffgroup, and a
behavior change for the "rightParent" for which "null" will become an
accepted value.
Laurent Goubet
Obeo
Andreas Scharf wrote:
> ModelA
> - ClassFoo
> - ClassBar
> ModelB
> - ClassFoo
> - ClassBar
> Best regards,
> Andreas
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
org:<a href="http://www.obeo.fr">Obeo</a>
email;internet:laurent.goubet@obeo.fr
url:http://www.obeo.fr
version:2.1
end:vcard
--------------090006040709090104050307--
Re: [EMF Compare] rightParent reference in DiffGroups [message #499852 is a reply to message #499839] |
Tue, 24 November 2009 11:37 |
Laurent,
I see the problem in only having a reference called rightParent. But in
my case there indeed is a right element (parent) available and even in
that case I get the left parent.
To be able to use EMF Compare I changed the following files in
GenericDiffEngine:
private DiffGroup buildHierarchyGroup(EObject targetParent, DiffGroup
root) {
// if targetElement has a parent, we call buildgroup on it, else we add
// the current group to the root
DiffGroup curGroup = DiffFactory.eINSTANCE.createDiffGroup();
> EObject rightSideParent = getMatchedEObject(targetParent, RIGHT_OBJECT);
curGroup.setRightParent(rightSideParent);
final DiffGroup targetGroup = findExistingGroup(root, rightSideParent);
if (targetGroup != null) {
curGroup = targetGroup;
if (rightSideParent.eContainer() == null) {
root.getSubDiffElements().add(curGroup);
return curGroup;
buildHierarchyGroup(rightSideParent.eContainer(),
root).getSubDiffElements().add(curGroup);
return curGroup;
Sorry for the bad formatting. Basically I don't simply set targetParent
but ask for a right element. I guess that if no match is available I'll
get null which is ok. I executed the MatchTestSuite and DiffTestSuite
without any problems but maybe you can have a very short thought at it
and point out any upcoming errors that I'm not aware off for now.
Another question concerning tests in EMF Compare (even it doesn't fit in
this topic): Are there really no merge tests or did I just miss them?
Andreas
Laurent Goubet schrieb:
> Hi Andreas,
> accepted value.
> Laurent Goubet
> Obeo
>> Hi,
>> the element via group.getRightParent(). Until now I thouhgt that
>> But in my DiffModel I get an element from the left model side.
>> ModelA
>> - ClassFoo
>> - ClassBar
>> ModelB
>> - ClassFoo
>> - ClassBar
>> Best regards,
>> Andreas
Re: [EMF Compare] rightParent reference in DiffGroups [message #499901 is a reply to message #499852] |
Tue, 24 November 2009 13:50 |
--------------030602050502010501090608
Andreas,
The only potential bugs I can think of are UI bugs. Like getting NPEs
when selecting a group in the structure panel of the comparison editor.
I'll have a look at this when I switch back to EMF Compare.
As for the tests, no, you read well. We do not yet have merge tests, and
yes, this is bad. We're currently looking into committing the tests
provided by Stephen McCants through
https://bugs.eclipse.org/bugs/show_bug.cgi?id=294336 and all related bugs.
Laurent Goubet
Obeo
> Laurent,
> GenericDiffEngine:
> root) {
> return curGroup;
> return curGroup;
> Best regards,
> Andreas
>> Hi Andreas,
>> the DiffGroup, and an issue I always push the fixing for later. When
>> the element presenting a difference is not preset in the right model
>> ... well I set a reference to the left model in its stead.
>> will see the addition of a "leftParent" reference to the diffgroup,
>> and a behavior change for the "rightParent" for which "null" will
>> become an accepted value.
>> Laurent Goubet
>> Obeo
>>> Hi,
>>> ModelA
>>> - ClassFoo
>>> - ClassBar
>>> ModelB
>>> - ClassFoo
>>> - ClassBar
>>> Best regards,
>>> Andreas
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
version:2.1
end:vcard
--------------030602050502010501090608--
FUDForum. Page generated in 0.02841 seconds
