Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE build/test problem(Test plugin not found)
PDE build/test problem [message #499545] Mon, 23 November 2009 10:27 Go to next message
Marko Tomljenovic is currently offline Marko TomljenovicFriend
Member
Hello all,
I am having a strange problem with my PDE build (Eclipse 3.5).
I am building some (extension location, no p2) features containing plugins/test plugins. After the build I am trying to run some tests using the eclipse test framework.
The bad thing is that the test plugins are not found. The following message is appearing all the time:
org.eclipse.test.EclipseTestRunner$TestFailedException: java.lang.Exception: Could not find plugin "..."
When I run the target eclipse manually the test plugins can also not be found (cannot be found at all in view plug-in registry).
But now comes the strange thing: The plugins are there, they are all located in the "plugins" folder.
I tried the following things but none of them helped:
- clean the configuration (cmd line switch -clean)
- remove all the features and just start using the plugins
Does anybody had a similar problem or has some ideas on this?
Thank you
Re: PDE build/test problem [message #499555 is a reply to message #499545] Mon, 23 November 2009 10:58 Go to previous messageGo to next message
Mickael Istria is currently offline Mickael IstriaFriend
Hello Marko,
Are you sure your test plugins dependencies are resolved? Maybe you are missing org.junit or another dependency so that your test plugin cannot be loaded...
HTH
Mickael Istria - BonitaSoft S.A.
http://www.bonitasoft.com/products/downloads.php
Re: PDE build/test problem [message #499564 is a reply to message #499555] Mon, 23 November 2009 11:29 Go to previous messageGo to next message
Member
first thank you for the reply.
But if a dependency is not resolved and therefore the plugin is not loaded shouldn't the plugin then at least be shown in the plug-in registry view as "disabled" ?
Re: PDE build/test problem [message #603515 is a reply to message #499555] Mon, 23 November 2009 11:29 Go to previous message
Member
Previous Topic:PDE build/test problem
Next Topic:How to catch delete function in launch configuration un eclipse
Current Time: Sun Nov 29 15:14:39 GMT 2020
Powered by FUDForum. Page generated in 0.02029 seconds
