Re: [Teneo] Annotations required to support 2 associations between two classes [message #500609 is a reply to message #500597] |
Fri, 27 November 2009 06:02 |
Hi David,
See comments inline.
gr. Martin
David Wynter wrote:
> I use JOINED inheritance mapping. But I tried to put the join for the
> super class to the subclass like so
> <xsd:complexType name="Instrument">
> <xsd:sequence>
> <xsd:element minOccurs="0" maxOccurs="1" type="xsd:anyURI"
> name="underlyingdetail" ecore:reference="mddb:Underlying" >
MT>> If an Instrument has many underlying then I would expect maxOccurs="unbounded" here. If you want this reference to
share the foreign key column with the reference on the other side then you have to set ecore:opposite also here (or on
the other reference). If you don't use ecore:opposite then you need to set the JoinColumn annotation on both sides with
the same JoinColum name (if you want sharing of the same foreign key column).
> <xsd:annotation>
> <xsd:appinfo
> source="teneo.jpa">@JoinColumn(name="underlyingdetail")</xsd:appinfo >
> </xsd:annotation>
> </xsd:element>
> Then the ManyToOne from the subclass to the superclass like so
> <xsd:complexType name="Underlying">
MT>> if an Underlying is a subtype of Instrument I would expect an xsd:extension somewhere
> <xsd:sequence minOccurs="0" maxOccurs="1">
> <xsd:element ecore:reference="mddb:Instrument" minOccurs="0"
> maxOccurs="unbounded" name="underlying" type="xsd:anyURI">
MT>> If an Instrument has many Underlying and an Underlying at most 1 Instrument then I would expect maxOccurs="1"
MT>> Setting maxOccurs="1" will also solve the exception below. With maxOccurs="unbounded" you can only use
OneToMany/ManyToMany annotations (as the exception text says).
MT>> A side remark, I would expect the name of the element to be instrument as it refers to the instrument type
> <xsd:annotation>
> <xsd:appinfo source="teneo.jpa">
> @ManyToOne(optional="true")
MT>> the @ManyToOne(optional=true) is not required if minOccurs="0" as Teneo will add it automatically
> @JoinColumn(name="instrument")
MT>> If you change the name of the element to instrument then this JoinColumn is not needed (Teneo will then use the
instrument name).
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> And end up with
> Exception in thread "main"
> org.eclipse.emf.teneo.annotations.mapper.StoreMappingExcepti on: The
> feature/eclass underlying/Underlying should be a OneToMany but it
> already has a ManyToMany, OneToOne or ManyToOne annotation
> at
> org.eclipse.emf.teneo.annotations.mapper.OneToManyReferenceA nnotator.annotate(OneToManyReferenceAnnotator.java:59)
> at
> org.eclipse.emf.teneo.hibernate.annotations.HbOneToManyRefer enceAnnotator.annotate(HbOneToManyReferenceAnnotator.java:62 )
> at
> org.eclipse.emf.teneo.annotations.mapper.EFeatureAnnotator.a nnotate(EFeatureAnnotator.java:195)
> at
> org.eclipse.emf.teneo.annotations.mapper.EClassAnnotator.ann otate(EClassAnnotator.java:270)
> at
> org.eclipse.emf.teneo.hibernate.annotations.HbEClassAnnotato r.annotate(HbEClassAnnotator.java:57)
> at
> org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator .processPackage(AnnotationGenerator.java:168)
> at
> org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator .map(AnnotationGenerator.java:136)
> at
> org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java:177)
> at
> org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java:73)
> at
> org.eclipse.emf.teneo.hibernate.HbDataStore.mapEPackages(HbD ataStore.java:711)
> at
> org.eclipse.emf.teneo.hibernate.HbSessionDataStore.mapModel( HbSessionDataStore.java:160)
> at
> org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:77)
> The error is clear but it still leaves me trying to work out how I can
> have and Underlying as a subclass of Instrument and also allow an
> Instrument to have many Underlying
> thx.
> David
> Martin Taal wrote:
>> Hi David,
>> I would think that this should happen automatically if you use the
>> joined inheritance strategy.
>> http://www.elver.org/hibernate/inheritance.html
>> Have you tried that?
>> If you want to control naming you should use JoinColumn and the
>> PrimaryKeyJoinColumn annotation. There are some examples here:
>> http://www.elver.org/hibernate/ejb3_format.html
>> http://www.elver.org/download/xmlsamples/Claim.xsd
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> I have 2 classes instrument and underlying. An underlying is a type
>>> instrument. An instrument may have many underlying, each of these
>>> underlying is also an instrument. So I have underlying *..1
>>> instrument and underlying 1..1 instrument. The customer expects to
>>> see a generated database with an instrument table and a underlying
>>> table with 2 foreign keys, one for the one to many from instrument to
>>> underlying and one for the one to one due to underlying being a sub
>>> type of instrument. How do I achieve this result using XSD annotations?
>>> Thx.
>>> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
FUDForum. Page generated in 0.03512 seconds
