Re: Issues about LabelProvider and TreeViewer [message #504948 is a reply to message #499162] |
Wed, 23 December 2009 17:21 |
Originally posted by: eclipse.ahoegger.ch
Hi Javier
a possible solution would be painting by yourself. You should be able to
implement it analog the table example (following the link).
http://www.eclipse.org/articles/Article-CustomDrawingTableAn dTreeItems/index.html#_tr12J
BR
Andreas
Javier wrote:
> Hi Folks:
> Firts of all, thanks for you help. I talk you about my problem:
> I'm developing a plug-in to parser a file and view the results as a
> tree, using a TreeViewer. For each leaf, I use a LabelProvider with a
> text and icon. I have a class that extends LabelProvider and here, I've
> implemented methods getText() and getImage(). I see, the icon is always
> in the first position and then the text. Is there any way to change
> that? I'd like to put the text first and icon, next.
> If that is not possible, is there any other way to paint a tree, putting
> text and icon? Using another class instead of TreeViewer? I hope I've
> explained well.
> Your comments will be well received.
> Thank you very much.
Re: Issues about LabelProvider and TreeViewer [message #504975 is a reply to message #504948] |
Wed, 23 December 2009 17:16 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Use a StyledTextLabelProvider
Tom
Am 23.12.09 18:21, schrieb Andreas Hoegger:
> Hi Javier
> BR
> Andreas
> Javier wrote:
>> Hi Folks:
>> I've implemented methods getText() and getImage(). I see, the icon is
>> always in the first position and then the text. Is there any way to
>> change that? I'd like to put the text first and icon, next.
>> putting text and icon? Using another class instead of TreeViewer? I
>> hope I've explained well.
Re: Issues about LabelProvider and TreeViewer [message #603860 is a reply to message #504948] |
Wed, 23 December 2009 22:04 |
Tom
> Hi Javier
> BR
> Andreas
> Javier wrote:
>> Hi Folks:
FUDForum. Page generated in 0.01937 seconds
