Home » Eclipse Projects » Rich Client Platform (RCP) » Product export - osgi.bundle missing
Product export - osgi.bundle missing [message #498659] |
Tue, 17 November 2009 22:37 |
Krzysztof Messages: 3 Registered: November 2009 |
Dear All,
I am building an RCP application made up of a couple of plugins. There is the master plugin, which uses classes from another project (DB Connection). To enable that I added it (DB Connection) to the master plugin's Dependencies->Reuquired Plug-ins. It works fine as long as I start the application from Eclipse. When I want to export the product to create an independent application I get a " 'Export Product' has
encountered a problem" error message with the following content:
"An error occurred while collecting items to be installed
session context was:(profile=profile,
phase=org.eclipse.equinox.internal.provisional.p2.engine.pha ses.Collect,
operand=, action=).
No repository found containing: osgi.bundle,DB_Connection,1.0.0"
.metadata/.log entry for the export operation is as follows:
"!ENTRY org.eclipse.pde.core 4 0 2009-11-17 23:23:44.366
!MESSAGE An error occurred while collecting items to be installed
!SUBENTRY 1 org.eclipse.pde.core 4 0 2009-11-17 23:23:44.366
!MESSAGE session context was:(profile=profile, phase=org.eclipse.equinox.internal.provisional.p2.engine.pha ses.Collect, operand=, action=).
!MESSAGE No repository found containing: osgi.bundle,DB_Connection,1.0.0"
Apparently the export wizard cannot see the DB_Connection project somehow. Does anybody possibly know how can I solve the problem?
Many thanks in advance!
Krzysztof
Re: Product export - osgi.bundle missing [message #498813 is a reply to message #498659] |
Wed, 18 November 2009 17:16 |
Wim Jongman Messages: 423 Registered: July 2009 |
Hi Krzystof,
It looks like the configuration tab lists a product with a wrong version
number. Did the version number of the bundle increase after the product was
created?
Wim Jongman
> Dear All,
> operand=, action=).
operand=, action=).
> Krzysztof
Re: Product export - osgi.bundle missing [message #498868 is a reply to message #498813] |
Wed, 18 November 2009 21:18 |
Hi Wim,
Thanks for your reply!
You mean the version of the exported product? The export is unsuccessful, so I cannot even check the version.
Krzysztof
Wim Jongman wrote on Wed, 18 November 2009 12:16 | Hi Krzystof,
created?
Wim Jongman
> Dear All,
> operand=, action=).
operand=, action=).
> Krzysztof
Current Time: Tue Apr 16 10:20:14 GMT 2024
Powered by FUDForum. Page generated in 1.16526 seconds
