Home » Modeling » M2T (model-to-text transformation) » XSDMetaModel(How to walk the model?)
icon5.gif  XSDMetaModel [message #498534] Tue, 17 November 2009 11:38 Go to next message
Marco  is currently offline Marco Friend
Is XSDMetaModel the meta-model (structure of my specific XSD) or the meta-meta-model (generic structure of XSDs).
And how can I walk a concrete XML then?
What do I need to import in my java class to make the editor / checker aware of the structure (types) of the XSD?
Marco
Re: XSDMetaModel [message #498649 is a reply to message #498534] Tue, 17 November 2009 21:21 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
the xsd metamodel helps you work with the types you have defined in your xsd to generate code / do model transformation from a model that is an instance of this xsd - a xml file.
so the xsd metamodel is a (dynamic) Metamodel built from the structure of your specific XSDs.
the answer for your question on java you find within your other post
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Previous Topic:Access XSD model from Xpand java extensions
Next Topic:Re: [Acceleo] Arguments list in Generator-API
Current Time: Thu Dec 01 14:41:51 GMT 2022
Powered by FUDForum. Page generated in 0.02998 seconds
