Re: How to communicate between various views/models [message #498225 is a reply to message #498223] |
Mon, 16 November 2009 01:01 |
Originally posted by: wangqs_eclipse.yahoo.com
--------------000906030201050005080105
For Q1 I'd suggest Observe patter. E.g. register your view to the model
as a listener. Trigger an event for the model changes. View can then
receive the event and determine if the event shall cause a refresh of
the view.
For Q2, you can write a test plugin and run it as plug-in unit test
which will run the test in the plugin environment. You can read the
article at
http://www.eclipse.org/articles/article.php?file=Article-PDE JUnitAntAutomation/index.html
Q.S. Wang
Ewan wrote:
> Hello,
> I have really searched through a lot of documentation before posting so
> any help would be greatly appreciated.
> There are two problems that I would like to solve
> 1) I have created some views in a plugin. However, in all of the
> examples I can find on the web all of the sample view have a mock data
> model within the actual view. In my instance I have a model that I would
> like to share between various views/preferences page. For example - I
> have a preferences page that I would like to bring up and allow the user
> to change preferences. Once preferences have been changed the view would
> change some element of its presentation.
> My questions is - what is the eclipse best practice for sharing a single
> data store/model between a number of views?
> Is the best practice to go to the workbench and look up other views by
> id? This seems a bit nasty as you have the view ids spread throughout
> the code. I really dont want to use singletons either (IoC fanatic). I
> have looked at the spring OSGI integration and using spring to inject
> beans into views. However, it looks massively complex and a bit bleeding
> edge at the moment and unfortunately I can not justify using it for this
> simple requirement I have.
> 2) Second question related to the first. Looking at a lot of the eclipse
> code it is completely impossible to test/run individual views outside of
> an eclipse runtime container. When developing with swing/outside of
> eclipse I prefer to make each view/panel independently runnable. This
> would be achieved by having a main in each panel which would create a
> frame, create any mocks that the panel is dependent on, create a frame
> and add. Is there any way to do this with SWT views that usually run
> within eclipse. I generally find this very difficult as all of the
> panels are heavily dependent on the runtime and too much is required to
> be mocked out.
> Any help on either of the questions would be appreciated.
> Cheers
http://www.myeclipsedev.com/
name="wangqs_eclipse.vcf"
filename="wangqs_eclipse.vcf"
YmVnaW46dmNhcmQNCmVtYWlsO2ludGVybmV0Ondhbmdxc19lY2xpcHNlQHlh aG9vLmNvbQ0K
dXJsOmh0dHA6Ly93d3cubXllY2xpcHNlZGV2LmNvbQ0KdmVyc2lvbjoyLjEN CmVuZDp2Y2Fy
ZA0KDQo=
--------------000906030201050005080105--
Re: How to communicate between various views/models [message #501187 is a reply to message #500213] |
Tue, 01 December 2009 13:25 |
If you dont like Singletons (I also dont like them because they will be raped so often as simple access mechanism) you could use Services. This is a very independent and convinient way to access your Model.
Look for Eclipse RCP services, if you have more questions or need more details, just ask.
Greetz
Thomas
FUDForum. Page generated in 0.03131 seconds
