Strange behaviour of container feature setters [message #497921] |
Fri, 13 November 2009 14:49 |
Carsten Reckord Messages: 139 Registered: July 2009 |
Hi all,
I have a question about an - at least for me - rather unexpected behaviour of container setters in the eclipse UML2 implementation. A
typical such setter looks like this (Property.setClass_):
public void setClass_(org.eclipse.uml2.uml.Class newClass) {
if (newClass != eInternalContainer()) {
//remove from old container
//add to newClass if newClass != null
As you can clearly see, newClass is not compared to the current value of the feature (Property.getClass_()), but to the current container,
whatever feature that might come from. This leads to two problems:
1) If newClass==eInternalContainer(), but the current container feature is not Property.class_ (okay, in this concrete example there is no
other container feature with a type that makes this possible), the desired change of the container feature is discarded silently. I think
expected behaviour would be to remove the property from its current container and add it to the correct containment feature.
2) If newClass==null, eInternalContainer()!=null, BUT getClass_()==null (i.e. we currently have a container, but it's not the class_
feature, but e.g. the owningTemplateParameter feature), the Property is removed from the other container regardless. Expected behaviour in
this case would be that nothing changes, since getClass_() is already null.
To sum it up, I would have expected a correct implementation to be more along the line of
if (newClass != eInternalContainer() && (newClass != null || eContainerFeatureID() == UMLPackage.PROPERTY__CLASS)) {
Since the current implementation is found in some variations throughout the model however, I was wondering if the current behaviour should
for some reason be considered expected behaviour or if it's actually a bug?
Carsten
FUDForum. Page generated in 0.02932 seconds
