Home » General (non-technical) » Eclipse Foundation » Has Eclipse Open Source Policy Changed?
Has Eclipse Open Source Policy Changed? [message #497657] Thu, 12 November 2009 19:14 Go to next message
Bill Winspur is currently offline Bill WinspurFriend
It seems that access to the source code of Eclipse is not quite as open
as it used to be, which I assume is a policy issue to explore in this forum.
1. On Ganymede, I can see the source code of internal classes such
as:
org.eclipse.core.internal.resources.Project
simply by performing a Show Declaration... operation on selected
reference to it in the java editor. The source code then opens in
another editor pane.
2. However, on Galileo the same operation results in opening a
.class read-only pane showing psuedo-code compiled from a class
file. At the top of the listing is the following unselectable text:
"The JAR of this class file belongs to container
'Plug-in Dependencies' which does not allow
modifications to source attachments on its entries."
Has the policy of accessibility to internal code (openness) in Eclipse
changed ?
Can one conveniently browse 'internal' source in Galileo, as was
possible in Ganymede ?
Bill.
Re: Has Eclipse Open Source Policy Changed? [message #497658 is a reply to message #497657] Thu, 12 November 2009 19:24 Go to previous message
Bill,
This has nothing to do with open source policies of the foundation. Not
only that, I can still see Project when I use Ctrl-Shift-T to locate
it. Perhaps you don't have the SDK installed in your environment?
> open as it used to be, which I assume is a policy issue to explore in
> this forum.
> such
> as:
> changed ?
> Bill.
Ed Merks
Previous Topic:Has Eclipse Open Source Policy Changed?
Next Topic:Has Eclipse Open Source Policy Changed?
Current Time: Tue Apr 16 08:06:02 GMT 2024
Powered by FUDForum. Page generated in 1.75350 seconds
