Re: Synchronize view not up to date [message #498262 is a reply to message #498257] |
Mon, 16 November 2009 09:07 |
David Balažic Messages: 130 Registered: July 2009 |
> Do you mean that 'src' folder is incoming addition(somebody added it) or
> outgoing addition (you added it)? Please, provide detailed steps how to
> reproduce the problem?
It had incoming changes (somebody else commited them to the svn server).
I'm not sure. This happens non-deterministically. I don't know what exactly triggers it.
>> Then I right click the project and this appears in the console:
>Did you just righ-click the project without calling Update action and you
>have update data in Console?
I right clicked on the "src" item in the tree (not the project, as I wrote before,
sorry, that was a mistake from me) and clicked Update in the popoup menu.
After that the update was performed and the lines in the log appeared (the ones
I posted before).
David
[Updated on: Mon, 16 November 2009 09:08] Report message to a moderator
Re: Synchronize view not up to date [message #502212 is a reply to message #497084] |
Mon, 07 December 2009 09:22 |
Igor Burilo Messages: 435 Registered: July 2009 |
Hello David,
We know that there can be problems in Sync view with Outgoing mode,
unfortunately they're not always reproducible, but they happen on some
specific circumstances. I created bugs for Team component about it
(unfortunately from short inspection I didn't find them), because Sync view
isn't created by Subversive, it's a Team component and they manage modes.
I also saw that you created bugs on Bugzilla, we'll review them.
Thanks.
> Hi!
> I see this problem since years (from eclipse v3.3 IIRC).
> Now I use v3.5.1 with the latest subversive plugin.
> Symptom:
> - the view in Synchronize (for example Outgoing mode) is not displaying
> all items
> - going to other mode (Incoming) and back "fixes" it: now everything is
> displayed as it should
> Right now I did this:
> - start eclipse
> - work for a while (change a few versioned files)
> - go to Team Synchronizing perspective
> - click Populate (view was in Outgoing mode)
> Result:
> - one of the projects I worked on and had a few files changed is not
> displayed at all (other projects with changed files are)
> - I click on Incoming mode and again on Outgoing and now the missing
> project with files is there
> Is there an open bug on this?
> If you know the problem, then switching mode is an easy workaround, but it
> is still a bit annoying.
> Regards,
> David
FUDForum. Page generated in 0.04877 seconds
