[Acceleo] Acceleo and Rhapsody [message #497024] |
Thu, 12 November 2009 10:07  |
Sebastien Roy Messages: 51 Registered: November 2009 |
Member |
I would like to use Rhapsody as modeler in my generation chain.
Despite the Acceleo UML Model Editor can parse my Rhapsody model, the Acceleo templates do not generate anything from my Rhapsody xmi files.
What have I got to do in order to be able to use Rhapsody xmi files ?
[Updated on: Thu, 12 November 2009 11:12] Report message to a moderator
Re: [Acceleo] Acceleo and Rhapsody [message #498352 is a reply to message #497024] |
Mon, 16 November 2009 14:45  |
--------------050908010001060300010809
Sebastien,
There is no specific step to do if you rhapsody xmis are readable as EMF
models. Acceleo "not generating anything" means that your "@main"
template is never called (or you get an exception in the error log).
Could you be a little more specific about the failure you experience?
Laurent Goubet
Obeo
Sebastien Roy wrote:
> Hello,
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------050908010001060300010809--
FUDForum. Page generated in 0.02624 seconds
