Page load error [message #496136] |
Sun, 08 November 2009 18:59  |
Originally posted by: mike.dean.hsc.utah.edu
With version 3.3.0 of Mylyn I am able to hit my repository (Trac), and the
queries list the tasks. However, when I try to retrieve a task, I get an
error "Page load failed with error: bad server certificate". My
configuration is identical on another machine that is still using version
3.2 of Mylyn and I receive no such error. Any suggestions?
- Mike
Re: Page load error [message #496945 is a reply to message #496542] |
Wed, 11 November 2009 14:58  |
I am having the same problem. I use mylyn with a particular repository on windows and that seems to work flawlessly. the problem is with my mac installation. i have not been able to work around the security exception problem
Re: Page load error [message #599998 is a reply to message #496136] |
Mon, 09 November 2009 12:10  |
Hi Mike,
is the error displayed by the embedded browser? Can you check the access
type in the repository settings under Additional Settings? You might want to
set it to XML-RPC to open tasks in the rich editor and not in the web
browser.
Also see this FAQ entry:
http://wiki.eclipse.org/Mylyn_FAQ#Why_do_I_get_an_error_when _accessing_secured_web_sites.3F
Steffen
> - Mike
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
Re: Page load error [message #600014 is a reply to message #496318] |
Tue, 10 November 2009 08:35  |
The error is brought up in a dialog message box (using OSX) and occurs
whether I use Firefox or Safari. I have a similar setup on another Mac but
the version of Mylyn is 3.2 and there is no problem. The repository is a
Trac repository that I have used with Eclipse for several years without
problem.
The repository does get hit successfully because the queries are all listed
- the problem is retrieving a ticket. I have it set for Web access; the
XML-RPC option did not work (got HTTP 404 error).
- Mike
On 11/9/09 10:10 AM, in article hd9ies$7fr$1@build.eclipse.org, "Steffen
Pingel" <steffen.pingel@tasktop.com> wrote:
> Hi Mike,
> browser.
> _web_sites.3F
> Steffen
>> - Mike
Re: Page load error [message #600038 is a reply to message #496542] |
FUDForum. Page generated in 0.05935 seconds
